Author Topic: Help with fountain pen?  (Read 2268 times)
Offline minho
  • i'm kind of back
« on: Sat, 26 July 2014, 22:34:14 »
So during my trip to China, my grandparents got me this fountain pen from a company called Fuliwen. I believe the model is Fuliwen 2001, but I can't find any information about it (and there were no instructions included either).
If anyone can shed any light as to what kind of ink I should get for it (cartridges, a bottle, etc.), I would greatly appreciate it! Any basic care tips for fountain pens would be nice as well (but those I can find online too. I just can't seem to find any pens with internals like this one).
Pictures:
http://imgur.com/a/vWABq
posted in an album with descriptions.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: Help with fountain pen?
« Reply #1 on: Sat, 26 July 2014, 22:45:17 »
Pictures:
looks like a decent aeromatic filler with a fine steel nib (great ball iridium tip), can't see the feed?-- nothing to extravagent
take it apart again and soak the nib unit, feed, filler in water over night with a drop a dish soap
take out and let dry for a couple hours and check out "noodlers inks"
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline minho
  • i'm kind of back
« Reply #2 on: Sat, 26 July 2014, 23:07:46 »
Pictures:
I'm not completely sure I understand what you're saying. do you mean I should take this component http://i.imgur.com/n7M6jDt.jpg in water with a drop of dish soap over night? Is this like "breaking in" the pen?
« Reply #3 on: Sun, 27 July 2014, 00:07:34 »
The crimson part contains the aerometric filler. Essentially it's a sac that suctions in ink through the nib. The Silver part in this picture
Contains your feed and nib and is referred to as a whole as the section.
When you first get a fountain pen, new or not, you should always flush the pen. This means you submerge the nib in water with a bit of dish soap. There's other ways to clean and flush the pen but this is the easiest way. For new pens, this is to clean out any machining residues or chips. For old pens, it's to clean out old inks and whatever else is in there.
What I would do is, reassemble the pen. Then squeeze and squirt out water like 5-10 times. Then take the pen apart again and submerge just the section (the silver part in the picture above) in water up to the end of the nib (the metal part where you write with). Let it sit overnight. Then wipe it clean, then assemble it and squeeze in and squirt out clean water again.
So you don't need a converter or anything because that button you're pressing down on is a ink hold mechanism called an aerometric filler. To fill the pen, you'll submerge the entire nib up to the section then press on the bar like 5-6 times. Wipe it clean and write. I highly recommend Noodler's and Diamine Inks.
Check out these videos from Brian Goulet for more information on the basics of fountain pens.
« Last Edit: Sun, 27 July 2014, 00:09:11 by CPTBadAss »
Offline iri
« Reply #4 on: Sun, 27 July 2014, 03:50:12 »
i don't recommend diamine's burnt sienna though.
-Ray Bradbury
Offline minho
  • i'm kind of back
« Reply #5 on: Mon, 28 July 2014, 05:18:00 »
Thanks all for replies!
Few final questions:
How is this ink? Seems to have good reviews on Amazon, and as I am a little dubious of this pen's performance, I would rather have an ink that flows well. Not sure the color will matter too much to me - never had anything else before, so I don't really know what I'm missing out on.
Second, how often should I clean out the pen? I honestly have no idea how fast I will go through a tube of ink - should I just flush it every time I finish a tube of ink, and at least once a year? (whichever is more often?)
« Reply #6 on: Mon, 28 July 2014, 05:47:43 »
Hmm I'm no expert on the noodlers blacks but I've heard xfeather is nice. You won't need the eel's lubricating properties since you don't have a piston filler.
I usually flush my pens when I run out of ink. However, I write fairly often with my pens. Gouletpens recommends once a month as a general rule of thumb.
