Author Topic: Help me to decide  (Read 2171 times)
Offline HotKillerZzz
  • Ammesia
Help me to decide
« on: Sun, 27 July 2014, 00:49:06 »
Kbt race I vs Poker 2
I know the rAce has backlit whereas the poker doesn't. But I also did some research and realized you can just solder the LEDs on.
So what do you recommend? No need to compare the price as I can get them at the same prices.
Offline Lingj
Re: Help me to decide
« Reply #1 on: Sun, 27 July 2014, 00:57:12 »
I have the Poker II and I like it a lot. I find that the Race has a weird layout for me. Reminds me of the lightsaver since all the keys are so close together. Also if you want Backlighting you can just add your own LEDs or there are some purchasing options that already have leds inside.
Offline Hundrakia
« Reply #2 on: Sun, 27 July 2014, 00:59:06 »
I was weighing the same two keyboards for a time, I realised that I just am too much in love with my larger shift keys haha
Offline user 18
« Reply #3 on: Sun, 27 July 2014, 01:00:32 »
A lot of people here will tell you to get the Poker, it's one of the favourites in the community.
Are you comfortable accessing arrow keys through the function layer? Would you miss the function keys? Do you have any interest in aftermarket keycaps? If you're comfortable with the tradeoffs inherent in the 60% Poker form factor, that's definitely my recommendation as it has a lot more customizability than the race.
If you need the function keys, or aren't comfortable with function layer arrow keys, the race is a better choice. Of the two, my personal decision would be for the Poker, but I'd be considering a FC660C/M as well -- don't know if that's an option for you.
Another factor you may want to consider is the switch options you have with each board.
Avatar by ashdenej
Offline epzy
  • HHKB Fiend
  • ded
« Reply #4 on: Sun, 27 July 2014, 01:33:39 »
The Poker 2 with ABS keycaps comes with LEDs. :)
P.S. decide on which layout you want, then you'll have your answer.
  • Ammesia
« Reply #5 on: Sun, 27 July 2014, 02:19:56 »
Does anyone have both keyboards? So that i can have a look at them side by side? Im fine with both layouts, but the race looks weird. So i want to compare them side by side. Thanks.
Offline Sniping
« Reply #6 on: Sun, 27 July 2014, 02:53:48 »
I think it would be better for you to compare the Poker with the Pure.
Edit: Actually, that's a bad comparison. I personally would go with a 60% with an arrow cluster.
« Last Edit: Sun, 27 July 2014, 02:55:22 by Sniping »
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #7 on: Sun, 27 July 2014, 02:56:50 »
Keycool 84.
Find a place still selling the old ones with Cherry switches and you are good to go.
« Reply #8 on: Sun, 27 July 2014, 03:25:22 »
Not my pictures: http://imgur.com/a/zyrJD
  • Ammesia
« Reply #9 on: Sun, 27 July 2014, 03:42:40 »
Ok, i will go with the race.
