Author Topic: [Ebay UK] Dell 227KN (AT101W?) US layout  (Read 5006 times)
Offline IBI
« on: Sun, 31 May 2009, 09:48:17 »
Linky.
I'm not sure if this is an AT101W or not, a quick search suggests it may be, but also suggests it could be a quietkey version. Can anyone say for sure?
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline ch_123
« Reply #1 on: Sun, 31 May 2009, 11:12:03 »
The back of my AT101W (which I did a switch swap with a worn out AT102W) says DP/N 0227KN. Also, all the quietkeys said "Quiet Key" on the front, and were smaller than the ATs. You could always ask the seller to check if it is says AT101W on the back, but I'd be 99% sure that that is the real deal.
There's always the possibility that it could be a rubber dome AT, I think they were called the AT101R or something like that.
Offline watduzhkstand4
« Reply #2 on: Sun, 31 May 2009, 11:40:24 »
That looks very much like a at101w. Now I really want to get my hands on another one.
I asked the guy to take another picture to show the back of the keyboard. Once he sends me the picture or posts it online, I'll come back.
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline IBI
« Reply #3 on: Sun, 31 May 2009, 12:39:13 »
Quote from: ch_123;93521
Do you still have the AT102W? I'd be interested to know it's part number. The back of my (black) AT102W says DP/N 010PXP.
@watduzhkstand4: Go for it, it's a new seller but he's got enough odd bits up for sale that he seems unlikely to be dodgy. It's probably not the cheapest you'll find but it does look nice and clean (as far as you can tell through the haze of jpeg artifacts) and seems like a good buy if you don't mind the US layout.
Offline ch_123
« Reply #4 on: Sun, 31 May 2009, 13:07:40 »
The 102W was a "2425C". I think it was an older model, as it had a coiled PS/2 cable, whereas the 101W I had had a straight one. It also had a different style of label which didnt have DP/N in front of the model number.
Offline lal
« Reply #5 on: Sun, 31 May 2009, 13:24:29 »
According to my notes 0227KN is the part number of the standard beige Dell AT101W. The auction says:
Condition: New
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline CX23882
« Reply #6 on: Sat, 06 June 2009, 03:03:23 »
They have 7 of these remaining.
I bought one and picked it up this morning. I can confirm that it is an AT-101W with black Alps switches and that it is brand new. Mine is a rev A01 board and has a colour-coded PS/2 plug.
« Last Edit: Sat, 06 June 2009, 03:07:03 by CX23882 »
Offline IBI
« Reply #7 on: Sat, 06 June 2009, 09:12:02 »
The new link appears to be here, but he's put the price up by £4
