Author Topic: Is replacing a Poker II case easy?  (Read 1408 times)
Offline Roibhilin
  • Saver of Humens
« on: Sun, 27 July 2014, 19:49:20 »
Hi guys, I have a new acrylic Poker case coming soon and I was just wondering if replacing it required any desoldering or generally anything besides removing case screws+putting the PCB in the new case.
I don't need to remove the plate, right?
QFR | Poker II | Quickfire TK
Re: Is replacing a Poker II case easy?
« Reply #1 on: Sun, 27 July 2014, 19:55:48 »
Just unscrew and screw it into the new case.
Offline cjhard
  • Claudia the Magnificent
« Reply #2 on: Sun, 27 July 2014, 19:57:39 »
Make sure to loosen the screws all together first, otherwise you will strip the last screw you try for.
I learned this from experience.
