Author Topic: [GB] RGB Modifiers in DSA Profile  (Read 35638 times)
Offline ntw
« on: Mon, 28 July 2014, 07:40:23 »
STATUS: ACTIVE
Do you wish to have more colors on your DSA profile keycaps? The RGB Modifiers in DSA Profile groupbuy is live on http://www.pimpmykeyboard.com/deals/rgb-modifiers-in-dsa-abs/.
The primary objective of this groupbuy is to provide a RGB mod to complement the DSA Dolch keycaps. But you are welcome to get to mix with other DSA keysets that you have. There will be two sets different sets, one for standard layout and another for Winkeyless layout. They will be made using Doubleshot ABS in White(WFK) legends.
Color Codes:
Standard Set Features:>>http://www.pimpmykeyboard.com/deals/rgb-modifiers-in-dsa-abs/
2* 1.25u CTRL (RA)
2* 1.25u ALT (BFK)
1* 2.25u SHIFT (VCS)
1* 2.75u SHIFT (VCS)
WKL Set Features:>> http://www.pimpmykeyboard.com/deals/rgb-modifiers-in-dsa-wkl/
2* 1.5u CTRL (RA)
2* 1.5u ALT (BFK)
1* 2.25u Left SHIFT (VCS)
1* 1.75u Right SHIFT (VCS)
1* 2.75u Right SHIFT (VCS)
Offline taylordcraig
Re: [GB] RGB Modifiers in DSA Profile
« Reply #1 on: Wed, 06 August 2014, 13:01:52 »
bumping cause i bought some and this needs more exposure
Offline ntw
« Reply #2 on: Thu, 07 August 2014, 15:50:47 »
im thinking the ppl here are really satisfied with how their DSA keysets looked like and thus the lack of interest? :(
« Reply #3 on: Thu, 07 August 2014, 17:55:47 »
Granite offered RGB modifiers in text icon and blank. The only difference being the text was sye-sub black on pbt, instead of double-shot white abs.
That's where the lack of interest is coming from. I personally bought some to match the text with DSA dolch, and am surprised more people aren't doing that.
Offline Mercury7
« Reply #4 on: Thu, 07 August 2014, 21:03:19 »
The colors are good but I think the pictures ("mock ups") aren't drawing buyers in
Offline geniekid
« Reply #5 on: Fri, 08 August 2014, 08:25:48 »
Pretty much this.  The legends in the mock up aren't very appealing and there's nothing in the description to suggest the legend would be different than what's pictured.
Offline Harrowed
  • My wallet has been hacked
« Reply #6 on: Fri, 08 August 2014, 08:39:57 »
Things above plus no ISO nor Ergodox compatibility.
Ergodox MX Blues | Rosewill RK-9000
Offline ntw
« Reply #7 on: Sat, 16 August 2014, 03:48:50 »
last 6 days to go
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #8 on: Wed, 20 August 2014, 23:44:57 »
What is the font on these modifiers? Do they match the font on the DSA Dolch set? If so, I can go for it, but if the font is different, it'll look weird, and I'll stick to the blanks I have.
Mmm... machined aluminum
Offline justnits
« Reply #9 on: Thu, 21 August 2014, 01:05:00 »
it should be the same as dsa dolch, just instead of dark grey/black, it's red, green and blue for the respective modifier keys.
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline DanielT
« Reply #10 on: Thu, 21 August 2014, 06:46:31 »
For DSA doubleshot there is only one font (at least for the moment), the standard SP font, so yes these mods will match Dolch DSA
Offline chrisq
« Reply #11 on: Thu, 21 August 2014, 07:04:07 »
I would be all over these, but I prefer icon-modifiers.
Changed my mind, I will get these, hopefully it reaches MOQ!
« Last Edit: Thu, 21 August 2014, 07:14:09 by chrisq »
Offline chrisq
« Reply #12 on: Fri, 22 August 2014, 13:14:26 »
We did it!  :D
Got this in the banner on reddit/MK, I choose to think it might have helped:
http://www.reddit.com/r/MechanicalKeyboards/comments/2e6oq6/buying_last_chance_to_get_rgb_modifiers_for_dolch/
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #13 on: Wed, 08 October 2014, 08:59:10 »
Did WKL make it? I ordered both but only got the 1.25 mod kit... ?
Offline chrisq
« Reply #14 on: Wed, 08 October 2014, 10:05:58 »
Nope, unfortunately WKL didn't make it.
WK barely did.
Offline limitz
« Reply #15 on: Wed, 08 October 2014, 10:23:13 »
Put these on my CODE w/ DSA Dolch. Looks absolutely beautiful. Previously, I had used DSA blanks from SP's inventory to create a pseudo-RGB modifier set. However, the colors were a bit off (the red didn't match the red escape key found in the DSA Dolch buy), and the green was more of a lime, than forest green.
However, after putting these caps on, I could never go back to the DSA blanks. This set looks so much better.
Offline chrisq
« Reply #16 on: Wed, 08 October 2014, 12:56:52 »
This is exactly what I plan to do, the novatouch just needs to arrive first.
Now the dsa dolch is on a keycool84, but since the wkl failed I don't have a fitting key for right shift  :mad:
« Reply #17 on: Wed, 08 October 2014, 12:58:42 »
Sad about WKL fail too, we should try to run it again I'd pick up 5 for the cause.
Offline KHAANNN
« Reply #18 on: Tue, 31 March 2015, 19:34:38 »
Anyone have these for sale?
I think this was a brilliant idea, it would be great to see these as a regular key shop items
