Author Topic: Left-handed five button USB mouse.....  (Read 2072 times)
Offline patrickt
« on: Mon, 01 June 2009, 22:28:37 »
I just got my Endura keyboard from Unicomp and love it and now I'm obsessing on my mouse. I have a Microsoft Laser Mouse 6000. I like it. I want another one. They're discontinued and I haven't found one yet that I can order to be delivered in Mexico.
So, I'm looking for a mouse that can be used left-handed, has five buttons, and  connects via USB. I haven't found one. I have used a trackball but haven't in years and as I recall I frequently had driver problems but a trackball that meets those specs would be possible if it had dependable drivers and three buttons were programmable.
If you know of one that fits, thanks.
Offline IBI
« Reply #1 on: Tue, 02 June 2009, 09:28:54 »
There's no shortage of mice meeting that criteria, the Microsoft Sidewinder X3 and Cherry Ergo-shark spring to mind, plus the expensive ones like some of the vertical mice and the contour mouse have left-handed versions and five or more buttons.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline patrickt
« Reply #2 on: Tue, 02 June 2009, 15:18:02 »
The Microsoft Sidwinder X3 must be the replacement for what I have. I'll check it out...when it's released.
Offline cnt
« Reply #3 on: Sun, 07 June 2009, 20:21:35 »
Microsoft IntelliMouse Optical 1.1A
Filco FKBN104M/EB
Offline huha
« Reply #4 on: Sun, 07 June 2009, 21:12:59 »
I don't like Logitech, but how about the Logitech MX 610 Left-Hand Laser Cordless Mouse?
5 Buttons and a 2d scroll wheel to boot. What could you want more?
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline ricercar
  • mostly abides
« Reply #5 on: Mon, 08 June 2009, 14:01:15 »
I used a Contour leftie for two years at one workplace, and always found it to be clumsy. They finally made a mouse with the primary button on the right, but then they super-sized it and made it an odd shape. I usually keep my small pieces of office equipment when I leave an employer (sue me) but the left hand Contour mouse stayed at that office when I left.
YMMV
Edit:
I've been using this "mouse" for six months on the left hand:
http://www.gogamer.com/Monster-Gecko-Pistol-Mouse-FPS-Controller-Accessories_stcVVproductId4758968VVcatId451798VVviewprod.htm
PROS:
  • 1) Your hand rests on the desk naturally without a twist, pinky down, thumb up. Decreases my RSI by leaps and bounds.
  • 2) It's perfectly symmetrical, so there's no left/right muscle memory difference to overcome.
  • 3) It's under $10 so the experiment is cheap
  • 4) the primary and secondary buttons are tactile (slightly clicky)
  • 5) the scroll wheel has physical notched action
  • 6) the scroll wheel uses the thumb, which naturally rests away from the wheel without stress.
CONS:
  • a) It looks like a gun. Your coworkers might start whispering. I've considered, since the risk is under $10, chopping off the gun barrel with a hacksaw, so it looks weird instead of like a weapon.
  • b) my huge hands had to learn how to avoid the secondary mouse button (where grip meets the underside of the trigger guard). In fact, I had to learn to rest my middle finger on the trigger guard, or else rest my pinky along the base or my four-finger grip was always triggering the secondary button.
  • c) The laser is far from the grip, magnifying the slightest wrist movement. Learning curve is non-trivial.
EDIT EDIT
This Monster Gecko Pistlgrip mouse is no longer made, hence the closeout price that varies widely by retail establishment.
« Last Edit: Mon, 08 June 2009, 14:25:51 by ricercar »
