Author Topic: Duck Viper and Eagle Group Buy  (Read 1156658 times)
Offline minho
  • i'm kind of back
Re: Duck Viper and Eagle Group Buy
« Reply #150 on: Sat, 02 August 2014, 22:00:21 »
no, only 2x keys and higher need stabilizers.
Offline loud_asian
« Reply #151 on: Sat, 02 August 2014, 22:01:32 »
where are you guys getting stabs from?
Ivan has a gb for stabs right now. I think it would probably arrive before this GB ships.
I also ordered an extra set from GON's website when I got my NerD TKL.
He does?
Where?
http://geekhack.org/index.php?topic=60789.msg1406270#msg1406270
So we'd need a:
7x plate mount space bar stab
(2) 2x plat mount stab for the left shift and the enter key?
First off these are pcb mounted stabs you need.  And the stabilizers you need depends on what layout you want.  But you will need a spacebar, left shift, enter, and potential backspace+right shift depending on what layout you prefer.
I mean for a viper in hhkb layout
The OP says that a plate is included
Does the 1.75x right shift need a stab? I assume the backspace is 1.5x or something on a hhkb layout
If you go for a layout that follows exactly like a HHKB you'll have the bottom layout in this picture. The bottom layout only requires 2 2x stabs and 1 7x stab
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #152 on: Sat, 02 August 2014, 22:03:25 »
He does?
Where?
So we'd need a:
1.75x keys do not need a stab (caps lock, hhkb right shift). I think stabs are only for keys 2x and up.
Offline feizor
« Reply #153 on: Sun, 03 August 2014, 01:05:19 »
He does?
Where?
So we'd need a:
No stab needed for 1.75x shift.
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #154 on: Sun, 03 August 2014, 03:55:08 »
When are we gonna get invoiced?
Sorry for my lack of patience.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline loud_asian
« Reply #155 on: Sun, 03 August 2014, 19:08:44 »
elton said a few pages back that once he founds out how much shipping costs, he'll start invoicing
Offline elton5354
« Reply #156 on: Sun, 03 August 2014, 21:37:50 »
I haven't updated the spreadsheet yet or anything for that matter..
I just received the weight of each unit. I'll start invoicing maybe tomorrow or Tuesday.  I'll update the spreadsheet tomorrow night as well.
Viper
Housing : 1206g
PCB : 84g
Plate : 139g
Accessories : 4g
Eagle
Housing : 1128g
PCB : 89g
Plate : 143g
Accessories : 4g
Packaging is 0.69 kg
Oh and there won't be any ALPs plate available.
Offline Lingj
« Reply #157 on: Sun, 03 August 2014, 21:45:19 »
Nooooooooooooooooooooooooooooooooo  :blank:
Offline elton5354
« Reply #158 on: Sun, 03 August 2014, 21:54:13 »
They haven't tested ALPs on the PCBs and I don't think they are planning on doing it as well.
Using ALPs requires a plate so...
Offline jorgenslee
« Reply #159 on: Mon, 04 August 2014, 09:08:56 »
Viper
Housing : 1206g
PCB : 84g
Plate : 139g
Accessories : 4g
Eagle
Housing : 1128g
PCB : 89g
Plate : 143g
Accessories : 4g
Wow, never knew the case is that heavy. It's even heavier than Hammer case I think.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #160 on: Mon, 04 August 2014, 09:14:31 »
Viper
Housing : 1206g
PCB : 84g
Plate : 139g
Accessories : 4g
Eagle
Housing : 1128g
PCB : 89g
Plate : 143g
Accessories : 4g
Yeah, Hammer cases weigh around 1.1kg.
Offline elton5354
« Reply #161 on: Mon, 04 August 2014, 17:14:29 »
The biggest weight is the packaging. That weight accounts only for the box.  With bubble wraps and all, it weighs a little over .8 kg, but I guess they aren't going to add that to the total packaging weight..
Either way each set w/ packaging will weigh a little over 2 kg, so you'd have to look at the 2.5 kg shipping rate.
If you want to make your own ALPs plate, I have the file for it.  Let me know if you want it.
« Reply #162 on: Tue, 05 August 2014, 09:41:45 »
Sigh. Thanks elton. If they haven't tested functionality then I really don't want to spring for the board only to find out something is wrong with the PCB. Guess I'm not getting one of these after all.
Offline geniekid
« Reply #163 on: Tue, 05 August 2014, 10:10:02 »
I feel your pain.  If there was a PCB only option I'd take the risk and worst case have an MX board, but Elton says there will be no PCB only option :(
  • Keyboard Hipstar
« Reply #164 on: Tue, 05 August 2014, 20:00:44 »
I-invoicing today?
Offline elton5354
« Reply #165 on: Wed, 06 August 2014, 19:40:29 »
Okay, I asked TrueCustom if he could get a smaller box for single unit orders to reduce the weight under 2 kg for cheaper shipping and he has done it today.  I'll start organizing everything tonight for invoice over the next few days.
If you order 1 unit, we will use .56 kg packaging weight and 2 units and more will be .69 kg.
There are 40 vipers and 31 eagles available immediately.  They just need to produce PCBs, plates, and anodizing the cases.
The rest will have to wait 2 months for the next round..
Offline Xenderwind
« Reply #166 on: Wed, 06 August 2014, 19:48:26 »
Awesome!  Thanks for the updates and getting us reduced shipping elton.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline minho
  • i'm kind of back
« Reply #167 on: Wed, 06 August 2014, 19:48:51 »
Will these be distributed in order of order submissions on the form?
Offline osi
« Reply #168 on: Wed, 06 August 2014, 19:49:43 »
Yay. There will be a next round!
Offline elton5354
« Reply #169 on: Wed, 06 August 2014, 19:53:26 »
Yes.  That would be most fair.
Offline minho
  • i'm kind of back
« Reply #170 on: Wed, 06 August 2014, 20:11:48 »
What is the deadline to pay after invoice? 24 hours?
Offline Fnzzy
« Reply #171 on: Wed, 06 August 2014, 20:14:39 »
Great news, thanks for the update. Can't wait!
Offline asassdsd
  • Call me "Jelly"
« Reply #172 on: Wed, 06 August 2014, 20:18:14 »
Elton Ive sent u an email about changing my order, have u receive it?
This isn't an alternative or troll account, I've been using this username for at least 10 years. Try typing it, is so fast and easy!
Recently acquired: Leopold fc660c with PBT   Currently: Bro-less    Clack-less    Mummy-less
I am currently at : Santa Cruz, CA
Offline jameslr
« Reply #173 on: Thu, 07 August 2014, 11:21:36 »
Anyone interested in selling their R1 spot for Black Eagle?
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline Xenderwind
« Reply #174 on: Thu, 07 August 2014, 11:24:04 »
Not sure when the spreadsheet was last updated but it only shows 27/31 eagles.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #175 on: Thu, 07 August 2014, 11:24:50 »
Offline jameslr
« Reply #176 on: Thu, 07 August 2014, 11:30:05 »
K - I just ordered then. Not sure if it's going to make it in R1 if he's already submitted though :/
Offline Xenderwind
« Reply #177 on: Thu, 07 August 2014, 11:41:49 »
I would imagine the 31 they had available would be just for elton's GB and they would order the pcb/plates for those regardless.  Only thing left would be to pick the color for annodizing.  And even if no one ordered the last 4 I would assume they would just annodize them anyway and sell them as leftovers.
Though there is also a fairly high chance that elton hasn't been updated the spreadsheet and there are already others ahead of you for the remaining 4 eagles.
Offline tjweir
« Reply #178 on: Thu, 07 August 2014, 15:57:15 »
This picture makes me happy I picked Blue-grey.
  • Keyboard Hipstar
« Reply #179 on: Thu, 07 August 2014, 16:06:07 »
Right?
So, after invoicing, will we just be waiting on the cases being anodized before they'll be ready to ship?
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #180 on: Thu, 07 August 2014, 16:10:22 »
Right?
It sounded to me like PCBs as well, but I could be misinterpreting.
Offline Xenderwind
« Reply #181 on: Thu, 07 August 2014, 16:15:10 »
  • Keyboard Hipstar
« Reply #182 on: Thu, 07 August 2014, 16:18:11 »
Any ideas on how long that generally takes?
Offline osi
« Reply #183 on: Fri, 08 August 2014, 09:14:47 »
Definitely in for round 2!! Form filled out!!
  • Keyboard Hipstar
« Reply #184 on: Sat, 09 August 2014, 03:40:51 »
How does Duck get this uniform glow in his Eagle and Light Pad?
I don't think I've ever seen it so smooth.
Offline feizor
« Reply #185 on: Sat, 09 August 2014, 04:10:48 »
+1 I would also like to know. I suspect it's shining onto the red PCB and the camera exposure enhances the effect.
« Reply #186 on: Sat, 09 August 2014, 08:52:29 »
I got a very similar effect with mine: I'm using blank cherry POM, which is very opaque. The light bounces off the nice stainless steel plate and gets that effect. I suspect it's just the fact that none of it can shine through the thick cherry keycaps he has on there.
Offline bazh
« Reply #187 on: Sat, 09 August 2014, 09:30:52 »
shouldn't be that hard, especially when Duck use SS plate, which is support backlit lighting better than alu one.
This is my 38GT, using a red alu plate
« Last Edit: Sat, 09 August 2014, 09:32:42 by bazh »
HHKB Pro2 white
Newbie again
Offline minho
  • i'm kind of back
« Reply #188 on: Sat, 09 August 2014, 12:43:19 »
What kind of keycaps is that? I have thick IMSTO PBT, and the back lighting on my NerD TKL can shine through the keycaps...
Offline elton5354
« Reply #189 on: Sat, 09 August 2014, 13:13:30 »
I'm sending invoices now.  If I missed sending one with combined shipping because you want to send it to someone to have it soldered, please PM me.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #190 on: Sat, 09 August 2014, 13:16:32 »
Noice! ;D
Offline minho
  • i'm kind of back
« Reply #191 on: Sat, 09 August 2014, 13:27:52 »
PAID AND DAMN EXCITED :D
Offline elton5354
« Reply #192 on: Sat, 09 August 2014, 13:28:00 »
Oh Crap....I've sent them in CAD and not USD...please do not pay..I'm going to change the invoice...I'm going to refund you minho...
« Reply #193 on: Sat, 09 August 2014, 13:29:07 »
Whoops, I just paid.
Offline elton5354
« Reply #194 on: Sat, 09 August 2014, 13:30:22 »
Sorry about that. I'll refund those who paid...
Offline minho
  • i'm kind of back
« Reply #195 on: Sat, 09 August 2014, 13:35:08 »
doh. np :p
  • Keyboard Hipstar
« Reply #196 on: Sat, 09 August 2014, 14:53:21 »
Man, that was the fastest transition from excited to disappointed I've had in a while  :-\
Offline elton5354
« Reply #197 on: Sat, 09 August 2014, 14:54:08 »
Lol sorry I'm taking a break.  I'll continue invoicing in a moment.
  • Keyboard Hipstar
« Reply #198 on: Sat, 09 August 2014, 15:14:56 »
  • Keyboard Hipstar
« Reply #199 on: Sat, 09 August 2014, 16:39:10 »
Paid!
