Author Topic: Duck Viper and Eagle Group Buy  (Read 1156794 times)
Offline Rewind
  • Street Fighter
  • Drive slow, homie
Re: Duck Viper and Eagle Group Buy
« Reply #350 on: Sun, 17 August 2014, 20:27:19 »
Ugh I think I need one of these
Before I pull the trigger I've got some questions because I'm a total MX noob, I'm sure a lot of these have been answered already so I apologize in advance:
What PBT keycap sets come with a short right shift so I could replicate a HHKB layout?
Is this stab kit sufficient for the Viper?
Any pics of the red anodization?
The keycaps can be found on old cherry 1800 boards, or tsangan kits.
The stabs are fine. You'll have to decide if you want a 7x spacebar or standard size.
I think you can see an example of red anodization on one of the other boards, orion or kingsaver, not sure.
Offline ComradeSniper
  • HHKB Pro
« Reply #351 on: Sun, 17 August 2014, 20:33:36 »
Awesome, thank you. Looks like I'm in on round 2 (I assume there's still room in round 2?) for a black Viper.
Offline Synjin
« Reply #352 on: Sun, 17 August 2014, 20:56:49 »
Hmm anyone in the socal area want to build together? I'll need the help/guidance... Lunch will be on me.
That's actually a great idea, never thought of this
If anyone can assist me with the same request but from the Wisconsin Stevens point area it would be super awesome though I highly doubt anyone from my small town even knows of GH
Offline Xenderwind
« Reply #353 on: Sun, 17 August 2014, 21:16:54 »
Hoff is probably the closest, and I think hes in Milwaukee.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
« Reply #354 on: Sun, 17 August 2014, 21:26:29 »
Oh hey!  I'm in the Fox Cities!  :D  Let's do this.  Synjin, shoot me a PM if you want to meet up for a build.   :thumb:
Offline Synjin
« Reply #355 on: Sun, 17 August 2014, 21:28:41 »
not sure since it only says wisconsin =) Milwaukee is quite far too but hey, it seems there are many people willing to help out anyways. Btw when soldering everything together, I'm thinking of using a lead free solder since I have a baby and I get paranoid about the lead part.
Will it make much of a difference or would you guys still recommend a solder with lead in it? What size of solder should I use if I use one that has no lead?
I sent you a friend request :P
« Reply #356 on: Sun, 17 August 2014, 21:45:43 »
I'm only an hour away!  :P  That's not far at all.  :)
Offline Synjin
« Reply #357 on: Sun, 17 August 2014, 22:12:26 »
Definately won't mind driving there and building together
Offline paobit
« Reply #358 on: Sun, 17 August 2014, 22:49:35 »
I'm jealous  :p
Offline jorgenslee
« Reply #359 on: Sun, 17 August 2014, 22:53:13 »
I hope there's a live streaming for the meetup build. Would love to watch the build process.
« Reply #360 on: Sun, 17 August 2014, 23:39:56 »
Sure thing.  :)  I might not have the most desk space to support two simultaneous builds, but I'm sure we can work something out.   :thumb:
Haha, you guys will watch streams of anything!   :p
Offline kle5635
« Reply #361 on: Sun, 17 August 2014, 23:48:02 »
Paid... right on time ;D been having some financial issue but it's all good now
Offline Synjin
« Reply #362 on: Mon, 18 August 2014, 00:06:52 »
You guys can watch a stream for the comparison of a first time builder and trying out soldering together with a pro GH bawss
Offline bazh
« Reply #363 on: Mon, 18 August 2014, 00:49:34 »
Viper/Eagle group build live stream :))
HHKB Pro2 white
Newbie again
Offline adrl
« Reply #364 on: Mon, 18 August 2014, 01:44:02 »
Would watch.
Offline paobit
« Reply #365 on: Mon, 18 August 2014, 05:49:55 »
I would def 2nd that group build stream!
Offline tjweir
« Reply #366 on: Mon, 18 August 2014, 05:58:14 »
Look at how awesome this community is, Good Guy Hoff.
Offline YongJK
« Reply #367 on: Mon, 18 August 2014, 09:35:40 »
hey elton,
I have submitted the form yesterday.
Could you send me the invoice as soon as possible ?  :thumb:
Keyboard: PLU ML87 Mx Blue
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #368 on: Mon, 18 August 2014, 10:39:36 »
I spent all day Saturday making these.  62g ergo clears lubed with blue stickers and sip sockets so I can hot swap LEDs on a whim.
74920-0
74922-1
74924-2
Offline Fnzzy
« Reply #369 on: Mon, 18 August 2014, 10:43:42 »
Nice work! I also ordered brown switches today to make some 60g browns. Not sure if I should add SIP sockets though. I usually don't swap LEDs but I guess it can't hurt.
Offline Synjin
« Reply #370 on: Mon, 18 August 2014, 10:50:53 »
What are sip pockets? What kind of lube did you use? Would I be able to do what you did with a regular cherry clear switch and some 62g springs? Sorry for all the questions.
Does the color from anodizing scratch of overtime including on the black case? I was curious because if it does, I will switchmy blue-gray to a plain silver instead.
Offline pmh1410
« Reply #371 on: Mon, 18 August 2014, 10:53:32 »
hey elton,
Me too, pls help me invoice. Thanks Elton :)
« Reply #372 on: Mon, 18 August 2014, 10:56:46 »
Thanks, Fnzzy! I think you'll be happy in the long run if you add the sip sockets. Otherwise, you would have to desolder the led just to open the switch again. Not that anyone plans on opening the switch again after its mounted and soldered but if you have to its convenient. As for making the sip fit in the switch it took some filing down of the plastic edges which was the least favorite part of assembling the switches for sure.
Offline Thechemist
« Reply #373 on: Mon, 18 August 2014, 10:59:33 »
Wouldn't it be easier to remove the sip sockets from their housing?
« Reply #374 on: Mon, 18 August 2014, 11:03:01 »
I know a lot of people do that, but then they just jangle around in the switch until they are soldered.  I'm sure that would work too, but I decided to keep the plastic housing so they would be aligned without having to be soldered into the PCB first.
Offline YongJK
« Reply #375 on: Mon, 18 August 2014, 11:03:49 »
hey elton,
I thought u got ur vipers / eagles  :D
Offline Thechemist
« Reply #376 on: Mon, 18 August 2014, 11:08:40 »
I have temp leds that I cut the leads even and push them in the switch, solder the sip sockets in and remove them afterwards.
« Reply #377 on: Mon, 18 August 2014, 11:11:12 »
Well, that would probably save me some time assembling so maybe I'll give that a shot for the next set of SIPs. Thanks for the tip.
Offline pmh1410
« Reply #378 on: Mon, 18 August 2014, 11:59:44 »
hey elton,
Yeah but it's not mine. I like red housing ;)
  • HHKB Pro
« Reply #379 on: Mon, 18 August 2014, 14:22:10 »
Oooooh this is a good idea. I was undecided on LEDs but I'm totally gonna do this now.
Offline pmh1410
« Reply #380 on: Mon, 18 August 2014, 17:09:32 »
Paid, Many thanks Elton ;)
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #381 on: Mon, 18 August 2014, 17:26:16 »
Man, I had a dream about this board.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline Synjin
« Reply #382 on: Mon, 18 August 2014, 22:12:44 »
Elton can you add a black eagle to my order? Would it be possible for you to ship them together for a cheaper shipping cost?
Offline Synjin
« Reply #383 on: Tue, 19 August 2014, 22:11:10 »
Just paid off 2nd half of my invoice for the eagle.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #384 on: Tue, 19 August 2014, 22:14:42 »
Updated everything needed for now. If I missed anything, let me know..
I suppose the 2nd batch can pay later.  I'd say 2 weeks after the 1st batch's deadline.  After the deadline, there can be NO changes to your order.  This is because they need to anodize the cases and the colours will be set once they start.  Address can be changed of course.
PMed you about combining an order for a couple of us in the Bay Area
Offline elton5354
« Reply #385 on: Tue, 19 August 2014, 22:32:45 »
Yeah, I haven't gotten to that yet. I'll change your invoice and refund the difference to those involved.
Offline Xenderwind
« Reply #386 on: Tue, 19 August 2014, 22:46:18 »
Did you ever get around to fixing the invoices of those who were misscharged shipping?  I'd hate to see you lose money by organizing this GB.
I believe it was germany, canada, switzerland, and the netherlands orders that were undercharged going through the list.   I think james also posted a list earlier in the thread of the undercharged countries.  But you should double check yourself.
Offline elton5354
« Reply #387 on: Wed, 20 August 2014, 23:56:54 »
Thanks I'll deal with that.
As for the unpaid first batch orders, I'm going to cancel them and move the 2nd batch paid orders to the first batch. This will probably quicken the process and besides they had their chance to pay.
Jwaz: I'll hold off on you since you're combining your order with 2 others.
Offline Altuz
« Reply #388 on: Thu, 21 August 2014, 00:37:18 »
**** I missed this!
Is it still possible to order?
I've always wanted the Viper!
Offline elton5354
« Reply #389 on: Thu, 21 August 2014, 00:46:44 »
Yes you can. You'll be in the 2nd batch which will be ready a month after the 1st.
Offline jinq-sea
« Reply #390 on: Thu, 21 August 2014, 04:49:48 »
I got e-mailed to say that my invoice for this was cancelled, but didn't get sent the invoice when it was issued. How weird. If there's a second batch going ahead, how can I get in?
Thanks.
Offline elton5354
« Reply #391 on: Thu, 21 August 2014, 10:43:19 »
Thanks.
Weird.  Maybe it went to your junk mail?  Refill the order form and I'll invoice you again.
« Reply #392 on: Thu, 21 August 2014, 11:13:03 »
Sometimes Paypal fails to send the email notifications, but if you go to your Paypal account, it will show up in your activity.
Offline xybre
  • clickityclackclickityclack
    • Music and Stuff
« Reply #393 on: Thu, 21 August 2014, 12:23:57 »
Strangely it was the opposite for me, it didn't show up in Paypal, I had to click the email link before it did. I assumed it was protection from letting people spam your Paypal inbox and trying to make it look official somehow.
GON NerD 60 & Duck Eagle & Unicomp Ultra Classic & Das Keyboard Ultimate
Offline elton5354
« Reply #394 on: Thu, 21 August 2014, 21:07:57 »
BTW, there won't be any 2nd batches since there aren't much leftover from the main batch.  They are making enough and will be finished next week.  They will all be shipped together.
Also, the timeline they gave me for their shipping time is around mid September.
Offline Synjin
« Reply #395 on: Thu, 21 August 2014, 21:41:39 »
So all of the orders will be shipping together as one massive order?
Offline elton5354
« Reply #396 on: Thu, 21 August 2014, 21:48:26 »
Yes. Their boxes only fit 4 sets max. though.
Offline Synjin
« Reply #397 on: Thu, 21 August 2014, 21:51:53 »
Thats a lot of boxes to go through ^_^ Looking forward to receiving my eagle and viper. I'm assuming that time of arrival for the people who ordered will be approximately Oct or November?
Offline elton5354
« Reply #398 on: Thu, 21 August 2014, 21:54:28 »
You'll receive them usually 3-5 days after the sets are shipped.  Very fast since you guys are paying top bucks for shipping. ;)
Offline Synjin
« Reply #399 on: Thu, 21 August 2014, 22:07:52 »
You just got me even more exited ^_^ Btw does the viper and eagle already come with the side led? if not, what are the appropriate led that we can use for these?
