Author Topic: Duck Viper and Eagle Group Buy  (Read 1137797 times)
Offline cphead
Re: Duck Viper and Eagle Group Buy
« Reply #450 on: Wed, 03 September 2014, 09:02:23 »
Here's an interesting video I found for those who are in this GB:
Sounds quite different! Part of it is probably due to LED vs no LED.
This was my video, the Kmac is 59g clear and the Eagle is from my friend, assembled with 62g clear, I just did a quick comparison. The different in sound firstly come from the lubing, the kmac and the eagle were lubed by different ppl as u can see in this video that i press the switches only, the sounds are totally differnt.
Secondly, the eagle was assembled with 2x3x4mm led. If u put on the GMK keycap, it scratch the inside of the keycap and it will make keycap can't be bottom out, it acts likes an unexpected O-ring lol, however it works well with SP keycap. My advice is assembled with 1.8mm led.
I personally dont think the springs can create the different in sound that much ^^
Best regards.
This is probably why I didn't like the clears on my Orion. It was assembled with the square leds and the switches felt scratchy as hell to me : /
Just clip/sand the edges of the LEDs down  ;)
Offline doublin
« Reply #451 on: Wed, 03 September 2014, 10:00:38 »
Hey there elton5354, I just received a pretty last minute invoice for Duck Eagle and while I was thrilled about it, is it possible that I pay the invoice tomorrow instead of today? Thing is, I just bought something using my paypal and pretty much short on cash atm. I can probably get the money by tomorrow and pay it.
Offline elton5354
« Reply #452 on: Wed, 03 September 2014, 10:02:34 »
Yeah, no problem.
Offline ceflame
« Reply #453 on: Wed, 03 September 2014, 11:04:24 »
Now I'm scared to use 2x3x4 leds.. anyone else have the same experience with the leds?
Offline adrl
« Reply #454 on: Wed, 03 September 2014, 11:07:36 »
I guess I'll be ordering some 1.8mm leds.
Offline jameslr
« Reply #455 on: Wed, 03 September 2014, 12:25:59 »
damn, I bought all 2x3x4 LEDs. Guess I'll have to go get some 1.8mm LEDs too. Good thing I'm using SIP sockets so it really doesn't matter if they don't fit right. I can just swap them out later.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #456 on: Wed, 03 September 2014, 12:52:50 »
2x3x4 LEDs should fit just fine. They typically sit below the top of the switch top. See for yourself in these photos courtesy of Photoelectric.
Offline cphead
« Reply #457 on: Wed, 03 September 2014, 12:55:59 »
Nothing wrong with 2x3x4 LEDs. They definitely touch the cap when you bottom out with thicker caps on the middle rows, but you can sand/clip the edges for better fit.
Offline bazh
« Reply #458 on: Wed, 03 September 2014, 13:42:58 »
I used 2x3x4mm led on my 38GT with GMK Olivetti, never experienced that "unexpected O-ring" problem
HHKB Pro2 white
Newbie again
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #459 on: Wed, 03 September 2014, 13:54:48 »
But like, where my Viper at, doe?
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #460 on: Wed, 03 September 2014, 13:56:16 »
where am I going to get Alps keys for this thing that don't suck... SP?
« Reply #461 on: Wed, 03 September 2014, 13:57:21 »
Unless I missed something, they're not supplying an Alps plate either. Can Matias switches be PCB mounted?
Offline jwaz
  • * based mod
« Reply #462 on: Wed, 03 September 2014, 14:02:58 »
wait... for real? how are you going to make an Alps compatible PCB and not include the proper plate?
Included in this set:
Aluminium housing (Aluminum 6061) in black, silver, blue-gray, or red
MX Reinforcement plate (STS-304 1.5T)  ???
PCB presoldered
Fixing bolts
« Last Edit: Wed, 03 September 2014, 14:04:40 by jwaz »
  • Keyboard Hipstar
« Reply #463 on: Wed, 03 September 2014, 14:07:43 »
I guess they didn't wanna shoulder the costs of manufacturing the alps plates, when most people were gonna be using mx switches.
Didn't they supply the specs so people could get one cut?
Offline jwaz
  • * based mod
« Reply #464 on: Wed, 03 September 2014, 14:10:16 »
nothing I can do about bad taste... but there really should be an option for an Alps plate...
guess we'll just have to make one? kind of irks me that it wasn't an option since we've already had a few hhkb style MX-based boards and this is the first Alps one so I felt like the non-MX crowd should have been catered to more.
Offline elton5354
« Reply #465 on: Wed, 03 September 2014, 14:18:33 »
I have the drawing for the alps plate if anyone wants.
Offline jwaz
  • * based mod
« Reply #466 on: Wed, 03 September 2014, 14:20:10 »
Yeah, post 'em up in the OP?
Maybe I'm vastly underestimating the amount of people that grabbed this thing for Alps compatibility.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #467 on: Wed, 03 September 2014, 14:34:22 »
Yeah, I'll run some if other folks are interested!!!
Offline geniekid
« Reply #468 on: Wed, 03 September 2014, 15:25:14 »
I would definitely be interested in the plate drawing :)
Offline elton5354
« Reply #469 on: Wed, 03 September 2014, 17:37:29 »
Here's the download link for the alps plate drawing.
http://www.filedropper.com/viper-eagle-alps1
From the drawing it looks like it uses Dell ATW101 stabilizers
« Last Edit: Wed, 03 September 2014, 17:41:26 by elton5354 »
« Reply #470 on: Wed, 03 September 2014, 17:40:12 »
****. *Now* everyone offer to make plates :( :( :(
Offline elton5354
« Reply #471 on: Wed, 03 September 2014, 17:41:54 »
You can still order...;)
  • Kitteh Overlord
  • Say WHAAT...
« Reply #472 on: Wed, 03 September 2014, 17:45:09 »
What could the Captain possibly need plates of...
« Reply #473 on: Wed, 03 September 2014, 18:55:57 »
I would be all over this if it came with an ALPS plate.. :(
« Reply #474 on: Wed, 03 September 2014, 19:16:41 »
I'd be in for an Alps plate, Maow. :)
Offline Lingj
« Reply #475 on: Wed, 03 September 2014, 19:21:47 »
Alps plate please ^^. Would be my first alps board.
« Reply #476 on: Wed, 03 September 2014, 19:51:22 »
Ditto, I'm looking between duck mini and eagle.  ;)
  • Kitteh Overlord
  • Say WHAAT...
« Reply #477 on: Wed, 03 September 2014, 20:02:36 »
wel I'll shoot Shawn an email  and see what we can do
Offline Synjin
« Reply #478 on: Wed, 03 September 2014, 20:41:58 »
I have both the eagle and viper ordered but It would be awesome of I could get an alps plate as well =)
« Reply #479 on: Wed, 03 September 2014, 20:48:21 »
Sweet! :D thanks!
Offline jwaz
  • * based mod
« Reply #480 on: Thu, 04 September 2014, 10:57:32 »
keep the alps hype aliiiive! thanks Maow, is it worth starting an IC just to gauge prospective orders?
Offline Gh05tx
« Reply #481 on: Fri, 05 September 2014, 12:00:58 »
Does anyone know where I could buy some stabilizers?  Ivans gb is over and gons shipping is kind of expensive. Thanks in advance
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #482 on: Fri, 05 September 2014, 15:34:12 »
I'm fairly sure some vendors have picked up some stabs from ivan's buy. Keep your eyes open :)
Offline paobit
« Reply #483 on: Fri, 05 September 2014, 15:50:11 »
wondering the same thing
Offline Fnzzy
« Reply #484 on: Fri, 05 September 2014, 16:05:08 »
http://www.qwer.io/ have some stabilizers.
  • Keyboard Hipstar
« Reply #485 on: Fri, 05 September 2014, 16:52:03 »
I bought some from imsto.
They're not authentic Cherry, just so you know.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #486 on: Fri, 05 September 2014, 17:05:17 »
Yeah, I guess we should make it official! Somebody wanna make one... ?
Outside of sending files to Shawn and mailing out plates... Ok, I need a P.R. person... Who wants it?
You would be responsible for everything BUT pick up, packing and mailing...  :confused:
P.S. Your first job is making the IC!
« Last Edit: Fri, 05 September 2014, 17:07:01 by ApocalypseMaow »
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #487 on: Tue, 09 September 2014, 15:18:44 »
This is how I feel about getting my Viper.  PLEEEEEEASE!!!!!!!
« Reply #488 on: Tue, 09 September 2014, 15:34:59 »
Alps plate IC here.
Offline jorgenslee
« Reply #489 on: Tue, 09 September 2014, 18:12:42 »
How about the side acrylic? Does someone know where we can source that?
Offline xybre
  • clickityclackclickityclack
    • Music and Stuff
« Reply #490 on: Tue, 09 September 2014, 20:11:51 »
Yeah I think it'd be a good idea to get the specs and have some made up. I'm interested in getting some clear and maybe some colour tinted sides depending on the cost.
GON NerD 60 & Duck Eagle & Unicomp Ultra Classic & Das Keyboard Ultimate
  • Keyboard Hipstar
« Reply #491 on: Tue, 09 September 2014, 20:18:57 »
The frosted ones look *****in'.
The only local place I have is Tap Plastics, but I've heard they don't have the right thickness.
Offline geniekid
« Reply #492 on: Wed, 10 September 2014, 08:33:54 »
I already asked once and was denied, but I'm going to try again - PCB only orders please!
  • Keyboard Hipstar
« Reply #493 on: Fri, 12 September 2014, 16:28:01 »
Any updates on shipping?
Offline billnye
  • ability man
« Reply #494 on: Sun, 14 September 2014, 18:26:16 »
Really looking forward to this! :D
Offline exitfire401
  • The Force is Re/\l
« Reply #495 on: Sun, 14 September 2014, 18:27:32 »
Offline Synjin
Offline ceflame
« Reply #497 on: Sun, 14 September 2014, 19:13:45 »
It's pretty much mid September now... I'm dying here waiting for an update
Offline Fnzzy
« Reply #498 on: Sun, 14 September 2014, 20:27:51 »
I am not that much in a hurry. I need to wait until I get my stabs and springs from the recent group buys to build it but I wouldn't mind getting it soon nontheless :P Really looking forward to an update.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #499 on: Sun, 14 September 2014, 20:31:24 »
elton told me in PM that they're supposed to ship late september, so until then...
