Author Topic: Duck Viper and Eagle Group Buy  (Read 1156489 times)
Offline swimmingbird
  • keyset hoarder
Re: Duck Viper and Eagle Group Buy
« Reply #1600 on: Fri, 11 March 2016, 21:36:30 »
I'm trying to update my viper with new firmware but when I go to upload the firmware through the O2D software I get a message saying "Check Atmel USB Driver"
When I connect the board with the flip button down (caps lock) and go to device manager the viper shows up as a "ATm32U4DFU" under Universal Serial Bus devices
What do?
Hey swimmingbird, hopefully I can help you out.
Just ignore the showing up as "ATm32U4DFU" and "Check Atmel USB Driver" errors you are getting now.
Have you tried using FLIP? Download here: http://www.atmel.com/tools/FLIP.aspx
I use it to flash my Viper, as well as my HHKB running TMK.
Just plug in the Viper while holding down Caps Lock.
And follow the instructions at the very bottom of the page here: http://duck0113.tistory.com/84
Duck gives you instructions on how to flash using FLIP software. (translate using chrome)
Make sure you select ATmega32U4 at the beginning or else it won't flash properly.
Tried this but I'm getting a message saying "AtLibUsbDfu.dll not found" followed by "Could not load dynamic library" when selecting usb as the connection option
Okay I managed to fix it... what I had to do was go to the device manager and manually specify to install the default atmega32u4 driver rather than just let it do it the automatic way
After I did this the device showed up on Device Manager under Atmel devices (which did not exist before in my device manager)
After this I ran the O2D software and it worked perfectly
Thanks for all your help
« Last Edit: Fri, 11 March 2016, 21:52:46 by swimmingbird »
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #1601 on: Sat, 12 March 2016, 13:30:58 »
I know this was mentioned a while back, but does anyone know the dimensions of the screws that mount the plate/PCB to the case? I think they are torx t4, but I have no idea about the length, TPI or diameter.
Offline lootbag
« Reply #1602 on: Fri, 25 March 2016, 10:58:42 »
Anyone have a CAD file of the plate for the Viper?
I want to lasercut an acrylic plate to try out.
Also, I want to replace the SMD LEDs on the bottom.
I believe they are 3528 type but just want to verify.
Looking to use these ones: http://world.taobao.com/item/521700558134.htm?spm=a312a.7700825.1997196601.213.rTv02N
I don't think I received the original bolts as I bought mine second hand.
The bolts are M2x0.4 (thread and pitch), length could range from 5-10mm.
The head could be torx T4 but the ones I am using are philips head.
« Last Edit: Fri, 25 March 2016, 11:02:50 by lootbag »
Offline ntelope
« Reply #1603 on: Fri, 01 April 2016, 18:06:57 »
I might be selling my duck eagle sometime soon. Thought maybe people here would be interested in it
Offline bocahgundul
  • a seal
« Reply #1604 on: Fri, 01 April 2016, 18:16:36 »
nothing to see here
« Last Edit: Fri, 01 April 2016, 18:19:44 by bocahgundul »
Offline ntelope
« Reply #1605 on: Fri, 01 April 2016, 22:59:47 »
nothing to see here
hello seal.
I'm an antelope.
Offline bocahgundul
  • a seal
« Reply #1606 on: Fri, 01 April 2016, 23:30:55 »
nothing to see here
hello seal.
I'm an antelope.
Hi antelope
Offline R4WBIT
« Reply #1607 on: Tue, 19 July 2016, 07:24:31 »
Anyone got a clue in what Duck is doing? Been a while since we saw an update from him and I'm still hoping for another round of the viper!
Sent from my LG-H815 using Tapatalk
Offline kawasaki161
« Reply #1608 on: Tue, 19 July 2016, 07:59:21 »
He is probably still finalizing stuff to start the Blackbird GB. I'd actually love to see another Viper/Eagle/anything but Blackbird and Lightsaver GB before he starts with the Blackbird, since I'm not interested in the other ones and do not yet have the money for the Blackbird, which would then be delayed long enough for me to save up, haha.
Offline aaron6301
  • Pixel Pusher
« Reply #1609 on: Tue, 19 July 2016, 09:52:10 »
I think you're right. As the Octagon V2 R3 shipment has been sent out, Duck is likely working on the Blackbird GB. I'm hoping that the Eagle/Viper GB will surface soon after.
Offline mrboovn
« Reply #1610 on: Thu, 22 September 2016, 09:41:09 »
Hey guys,Viper and Eagle V2 is cominggg  :p :p :p :p
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #1611 on: Thu, 22 September 2016, 09:42:22 »
yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Offline ReverbSlush
  • 16/52 RNG score
« Reply #1612 on: Thu, 22 September 2016, 09:43:10 »
Very interested in a viper... helll yea
Offline Fictiouz
  • That "White" Guy
« Reply #1613 on: Thu, 22 September 2016, 09:43:57 »
YES. OMF. **** MY WALLET.
Offline aaron6301
  • Pixel Pusher
« Reply #1614 on: Thu, 22 September 2016, 09:44:47 »
Exciting times ahead!... can't say the same for my wallet -_-
Offline tikhonovdanya
« Reply #1615 on: Thu, 22 September 2016, 10:01:18 »
Hope the price won't be much different from the first gb  :)
Offline duhhey
« Reply #1616 on: Thu, 22 September 2016, 10:02:35 »
FINALLYY :OOOOOOOO
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1617 on: Thu, 22 September 2016, 10:07:13 »
Nice. Hope there's a diffuser-less case option.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #1618 on: Thu, 22 September 2016, 10:11:03 »
omg! octagon v3 soon?  :-\
Offline E3E
« Reply #1619 on: Thu, 22 September 2016, 10:19:43 »
Some things I've noticed:
• Centered USB port which is done to accommodate the acrylic diffuser inserts, I'd imagine.
• Much longer diffuser inserts than the Octagon v2 and Orion v2 from what it seem (note the backside).
• Some strange aluminum bottom option shown on the Eagle v2  :-X
Offline SixtyLife
« Reply #1620 on: Thu, 22 September 2016, 10:47:46 »
yesssssssssssssss
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline airs
« Reply #1621 on: Thu, 22 September 2016, 12:15:04 »
Awesome! Where are these pics from? Any idea on the timeline?
Octagon v2, LZ CLS
Offline merlin64
    • MechMerlin
« Reply #1622 on: Thu, 22 September 2016, 12:20:13 »
Ahh I've been waiting for this for awhile.
Offline megaforce
« Reply #1623 on: Thu, 22 September 2016, 12:54:51 »
god bless
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline Gatix
  • #!/bin/sh
  • console.log
« Reply #1624 on: Thu, 22 September 2016, 12:57:09 »
Sweet jeebus
Offline SevenU
  • Grimace is Black
« Reply #1625 on: Thu, 22 September 2016, 12:57:52 »
This is what I've been waiting for. And Xondat told me it wasn't going to run again, psssh.
Sent from my KIW-L24 using Tapatalk
Something, Something, blah, blah, blahbitty, blah
Offline E3E
« Reply #1626 on: Thu, 22 September 2016, 13:45:50 »
With Duck's current design paradigm? I doubt that. That's his thing. Pinhole indicators and integrated diffusers define the current gen style.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1627 on: Thu, 22 September 2016, 14:19:22 »
I know, but one can hope.
WTB/WTS/WTT ---->
Offline Khers
  • Schrödinger's box
« Reply #1628 on: Thu, 22 September 2016, 14:49:01 »
You and I can always hope for an Eagle/Viper V3 without diffuser and pinholes... :)
Offline Dreamre
    • kbdlife
« Reply #1629 on: Thu, 22 September 2016, 15:30:01 »
Woah, look at the side profile of the Eagle V2...
Offline xondat
  • i'm not a star
« Reply #1630 on: Thu, 22 September 2016, 15:47:23 »
Uhh... I never said that!
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #1631 on: Thu, 22 September 2016, 15:49:28 »
« Last Edit: Thu, 22 September 2016, 15:51:13 by nickheller »
Offline SevenU
  • Grimace is Black
« Reply #1632 on: Thu, 22 September 2016, 15:55:08 »
You've convinced me. I believe you.
Offline xondat
  • i'm not a star
« Reply #1633 on: Thu, 22 September 2016, 16:06:09 »
:confused:
Offline fublamchu
  • ㅋㅋㅋ
« Reply #1634 on: Thu, 22 September 2016, 17:54:29 »
Ahh! This probably will be my first Kustom! Btw, is the space/cutout in the alu. case meant for weight inserts?
LZ-CE VBlacks
910-CE
  • keyset hoarder
« Reply #1635 on: Thu, 22 September 2016, 18:43:07 »
my anus wallet is ready
Offline Weiss
  • Impulse buying at its finest
« Reply #1636 on: Thu, 22 September 2016, 19:08:55 »
If you're talking about in the direct center of the case, then yes, that space is typically meant for a weight insert.
Offline fublamchu
  • ㅋㅋㅋ
« Reply #1637 on: Thu, 22 September 2016, 19:11:41 »
Ah I see, thanks for the info!
LZ-CE VBlacks
910-CE
Offline yookwh
« Reply #1638 on: Thu, 22 September 2016, 20:43:01 »
Following this post very carefully now. Hope to get at least one of these  :thumb:
Offline alienman82
« Reply #1639 on: Sun, 25 September 2016, 11:54:31 »
kinda want an eagle for POM. hasn't been much love for 60% from korea in a long time ...
Offline SevenU
  • Grimace is Black
« Reply #1640 on: Sun, 25 September 2016, 14:19:48 »
So, since the post has basically changed to the Viper and Eagle buy. When can we expect this to open?
Offline xondat
  • i'm not a star
Offline zeta
« Reply #1644 on: Sun, 25 September 2016, 20:09:14 »
Posting to add my interest.
Offline Dreamre
    • kbdlife
« Reply #1645 on: Sun, 25 September 2016, 21:17:01 »
http://kbd4u.co.kr/product/detail.html?product_no=63&cate_no=1&display_group=2
I guess that pretty case was just a proto and it won't happen...
Offline WarCommand
« Reply #1646 on: Sun, 25 September 2016, 22:07:48 »
Offline Weiss
« Reply #1647 on: Sun, 25 September 2016, 22:40:37 »
Definitely looking to get a Viper out of this.
Maybe even an Eagle if I get lucky, gotta have something that's completely stock in layout.
Offline RocketGruntJake
  • Brb, gotta grow some flowers
« Reply #1648 on: Sun, 25 September 2016, 23:40:55 »
Really excited for this buy as well
Offline Bigpock
« Reply #1649 on: Mon, 26 September 2016, 00:39:57 »
Im so in this. So So So so so so in this
