Author Topic: Duck Viper and Eagle Group Buy  (Read 1156511 times)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: Duck Viper and Eagle Group Buy
« Reply #1350 on: Fri, 17 July 2015, 10:01:15 »
What is the programming system for the viper?
O2D programmer from Duck. You need to download dfu-programmer and put it in the same folder as O2D
Offline ideus
  • Björkö.
« Reply #1351 on: Fri, 17 July 2015, 15:51:12 »
Thank you very much for the reference. By the way, your banner for the Beige set is awesome!
Offline Sed8op8
  • Keyboard Padawan
« Reply #1352 on: Sun, 02 August 2015, 11:37:49 »
Does anyone know where I can find a set of acrylic inserts for the viper. Just got one and would love to buy some if someone had extras ! Thanks all
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #1353 on: Tue, 04 August 2015, 07:16:51 »
Where is dfu-programmer?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1354 on: Tue, 04 August 2015, 07:18:40 »
http://sourceforge.net/projects/dfu-programmer/files/dfu-programmer/0.7.0/
I have a word file that will help you, let me find it.
Offline sethk_
  • www.kbdhub.com
    • My webstore
Offline Lurch
« Reply #1356 on: Tue, 04 August 2015, 07:24:09 »
PM elton, he should be able to help you.
And thanks for the reminder; I need to do the same. :thumb:
Quote from: Flyersfan1
  • Frenzy Classic.
« Reply #1357 on: Tue, 04 August 2015, 07:29:13 »
Thanks sethk_   :thumb:
  • Frenzy Classic.
« Reply #1358 on: Tue, 04 August 2015, 22:55:20 »
There is issue in while I flash firmware.
Please help me. Laptop can't detect viper :(
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1359 on: Tue, 04 August 2015, 22:59:41 »
Did you hold FLIP button down?
  • Frenzy Classic.
« Reply #1360 on: Tue, 04 August 2015, 23:02:11 »
Yes, I did.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1361 on: Tue, 04 August 2015, 23:17:16 »
Yes, I did.
What happened when you plugged it in while holding the FLIP down?
  • Frenzy Classic.
« Reply #1362 on: Tue, 04 August 2015, 23:25:12 »
Yes, I did.
Nothings is happen. Leds is not light, there is no sign :(
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1363 on: Tue, 04 August 2015, 23:37:25 »
Yes, I did.
This is supposed to happen when FLIP key is held down then plugged in. What does it say in terms of Drivers installing? When you plug it in w/ FLIP held down, go to device manager and look for Atmel tab, if it isn't there,look for unknown devices.
  • Frenzy Classic.
« Reply #1364 on: Wed, 05 August 2015, 00:05:52 »
Yes, I did.
Right, everything happen like you said.
When I hold FLIP key & plug in, there is messenger dectecting unsucessful driver.
Then I open device manger to manual install driver, everything is good except I can't flash firmware.
  • Frenzy Classic.
« Reply #1365 on: Wed, 05 August 2015, 02:02:21 »
I fixed this issue by flip program. Anyway, thanks for your support, sethk_  :thumb:
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1366 on: Wed, 05 August 2015, 02:11:55 »
Yep, glad you could fix it. I am better at KMAC program than Duck's program :(
Offline phatdood9
« Reply #1367 on: Fri, 07 August 2015, 23:46:15 »
I think I broke my pcb somehow resoldering the switches to gateron blues :-( on my duck viper. Every key works except the 7 key.
Is it possible to get a new pcb? Any tips on fixing it?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1368 on: Fri, 07 August 2015, 23:56:33 »
take a picture, I might be able to tell you how depending on the damage
Offline phatdood9
« Reply #1369 on: Sat, 08 August 2015, 12:10:28 »
imgur link : http://imgur.com/n8GlUK8
Firmware confirmed to be working for a while when I was using ergo clears :-( I can think of two things I did wrong:
-  I might have pulled too hard when removing the switch
-  I accidentally sprayed a some melted solder from my desoldering iron on the board when trying to clear it out
« Last Edit: Sat, 08 August 2015, 12:13:27 by phatdood9 »
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1370 on: Sat, 08 August 2015, 12:12:45 »
could you get a closer pic?
Offline phatdood9
« Reply #1371 on: Sat, 08 August 2015, 12:27:46 »
direct link:
http://i.imgur.com/n8GlUK8.jpg
or closer?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1372 on: Sat, 08 August 2015, 12:29:20 »
direct link:
or closer?
A clear photo closer would be nice, so I can see the joints
Offline phatdood9
« Reply #1373 on: Sat, 08 August 2015, 12:39:43 »
Here ya go:
http://i.imgur.com/1IrcwUZ.jpg
The 7 key is to the left of the screw hole
edit: also tried a few different switches in the slot, so it shouldn't be an issue with teh switch itself
« Last Edit: Sat, 08 August 2015, 12:47:25 by phatdood9 »
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1374 on: Sat, 08 August 2015, 13:28:48 »
Here ya go:
plug it in, take a pair of tweezers, and try to jump the connection, like you would for anything else. The only thing I could guess is that the switch is bad.
Offline phatdood9
« Reply #1375 on: Sat, 08 August 2015, 13:55:50 »
Here ya go:
tried to jump it with a spare wire, every key registers except the 7  :-[
whose my best bet in the USA to possibly fix it?  :'(
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1376 on: Sat, 08 August 2015, 13:58:42 »
Here ya go:
I do soldering services, but not repairs :( what do you think you might have done? is there something wrong with the diode?
Offline phatdood9
« Reply #1377 on: Sat, 08 August 2015, 16:10:16 »
Here ya go:
no idea  :'( its probably something I did when desoldering the old switches. The only thing I can think of is that I ripped out the internal part of the pad by not removing all of the solder
Offline E3E
« Reply #1378 on: Sat, 08 August 2015, 18:24:53 »
Believe me, I went through hell when I desoldered my Octagon's switches because they had short-legged SIP sockets that were very difficult to desolder even with ample solder and a desoldering iron. ChipQuik was the best way to remove those kinds of SIP sockets for me. Especially since the melt temp is lower than the housing's melting point.
Anyway, I went through having to fix SMD RGB LEDs that went out, replacing diodes, and repairing pads and traces. It was hell, but I was determined not to let my baby, my first korean custom, be a $400 brick. I kept at it and ended up fixing it perfectly.
I can say I'm 90% sure I can fix your PCB if you'd trust me to work on it. If not, that's alright! I know I'm not very well known around here and my reputation doesn't precede me, haha. The PCBs are dual-layered as far as I know and even if a through hole or pad is completely ripped, I have ways of restoring the connection. That's what it seems it might be in your case.
Here ya go:
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1379 on: Sat, 08 August 2015, 18:26:13 »
Or just wait for leekus 75% pcb
Offline E3E
« Reply #1380 on: Sat, 08 August 2015, 18:33:47 »
Say what? No, my Octagon PCB is fine, though picking up a spare 75% Leeku was something I had in mind if I wanted to swap layouts. I've heard word of a carbon fiber 75% plate down the line, so that's what I'd get it for. Screw desoldering the Octagon again.
My previous post was talking about repairing phatdood9's Viper PCB. :P
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1381 on: Sat, 08 August 2015, 19:23:50 »
That was a suggestion to phatdood
Offline E3E
« Reply #1382 on: Sat, 08 August 2015, 19:30:08 »
Oh, I see! It seemed relevant to me given the context and what not. Not a bad idea, but also not a viper. D: I'm sure fixing it is top priority.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1383 on: Sat, 08 August 2015, 20:00:13 »
Oh yeah, face palm
Offline phatdood9
« Reply #1384 on: Sat, 08 August 2015, 21:51:23 »
If you think you can do it, I'd be glad to send it over.
BTW, is it possible to cut any board (leeku?) so it fits the viper case?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1385 on: Sat, 08 August 2015, 22:03:59 »
no. if you can't get it working, maybe email duck and see if you could buy one off of him.
Offline E3E
« Reply #1386 on: Sun, 09 August 2015, 00:04:21 »
Sure thing, send me a PM if you'd like. I'm a charitable sort of person so I'm not really looking to make money off of helping you out; just pay shipping and I'll do my best to fix it up for you.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1387 on: Mon, 10 August 2015, 16:42:48 »
Anyone know what kind of screws the Viper / Eagle use?
Offline E3E
« Reply #1388 on: Mon, 10 August 2015, 17:06:52 »
Here, these are the specs from the Lightsaver thread I found and used for reference when looking for info for my Octagon:
Screws: the 10 little screws you need to attach the plate to the case are size M2 in Torx T6 with a 0.4mm pitch (called "coarse" or "normal") and 5mm length.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1389 on: Mon, 10 August 2015, 23:56:51 »
Offline trenzafeeds
  • **** off
« Reply #1390 on: Tue, 11 August 2015, 02:39:24 »
I know this is a massive long shot, but I've had some luck doing this on other old Group Buy pages. Does anyone still have a kit they might want to sell?
demik will never leave.
Unless he gets banned.
Offline Sed8op8
  • Keyboard Padawan
« Reply #1391 on: Tue, 11 August 2015, 05:24:56 »
Keep the faith trenza.... I just had someone surprise me with a new viper  :eek:
@elton thanks for the acrylic inserts good sir 8)
This was probably mentioned here but did anyone come up with a good simple way to attach the acrylic inserts to there viper ?
Offline FreeChemicals
« Reply #1392 on: Tue, 11 August 2015, 05:42:05 »
What JaccoW wrote is pretty useful: https://geekhack.org/index.php?topic=56877.msg1551072#msg1551072
Offline E3E
« Reply #1393 on: Tue, 11 August 2015, 12:06:36 »
I use double-sided fabric tape, which is pretty much 100% adhesive without a backing like duct tape or masking tape. http://www.michaels.com/10340764.html
EDIT: JaccoW's method might be better if you want to remove them easily. The stuff I use has a lot of adhesion. It can be pulled off without an issue though, but you'd have to reapply it if you want to have the sides stick again. It holds really well though. I also only apply the tape on the outer parts of the insert, like near the edges.
« Last Edit: Tue, 11 August 2015, 12:10:36 by E3E »
Offline retrochick
  • goodbye my wallet
« Reply #1394 on: Tue, 11 August 2015, 19:06:50 »
Soooooooo... can I join the 'i missed out but would very much like a viper to k thx bai' bandwagon? guys? guys?!  :p
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #1395 on: Tue, 11 August 2015, 19:15:52 »
Pretty sure there's one or two Vipers for sale in classified's right now.  Two silver and a black one but they're already built.
Offline retrochick
  • goodbye my wallet
« Reply #1396 on: Tue, 11 August 2015, 19:25:39 »
Thanks dude, ya I think I looked at Glitched's classified & another one, but am looking for an unassembled kit because well, monies  :'(
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #1397 on: Tue, 11 August 2015, 19:26:28 »
Yeah, the unassembled bit is tricky.  You could always wait for the second run/V2 of these. ^___^
Offline retrochick
  • goodbye my wallet
« Reply #1398 on: Tue, 11 August 2015, 19:45:15 »
JK, i can wait.
Offline trenzafeeds
  • **** off
« Reply #1399 on: Tue, 11 August 2015, 22:34:57 »
Whooaaa, hold on, is there definitely going to be a second run?
