Author Topic: Duck Viper and Eagle Group Buy  (Read 1156514 times)
Offline tjweir
Re: Duck Viper and Eagle Group Buy
« Reply #1300 on: Sat, 28 March 2015, 19:40:49 »
Any idea why my left control (which is on capslock, HHKB layout) continually blinks?
It flashes to indicate the layer you're on.
(I think)
Offline radio_killah
  • Chinchillin'
« Reply #1301 on: Sat, 28 March 2015, 20:32:40 »
(I think)
Any idea how to turn it off?
Offline ithinkimkorean
« Reply #1302 on: Sat, 28 March 2015, 21:48:37 »
How do I get the capslock to stop blinking?
Go to http://duck0113.tistory.com/84
Scroll down to instructions section which is quite readable using google translate in chrome.
Go to section 2 part 4 (Called: "Layer the status indicator (LED) display method change" if using google translate)
Follow instructions.
Hope it helps ;)
edit: I think the mode you want is called LLN.
Thanks! Still took me a bit since I couldn't find the c/m key -_-
^ I had same thing
  • Chinchillin'
« Reply #1303 on: Sat, 28 March 2015, 23:41:07 »
Hope it helps ;)
^ I had same thing
I mapped the c/m key to my layout but I can't figure which setting turns it off :(
edit: I am an idiot. You have to type out the command.
« Last Edit: Sun, 29 March 2015, 12:56:25 by radio_killah »
Offline tjweir
« Reply #1304 on: Sun, 29 March 2015, 13:29:53 »
Gist of the .hex for hhkb layout in case you're having issues with O2D.
https://gist.github.com/tjweir/c7ed2c2871f9acb05bc6
Offline dothm
« Reply #1305 on: Mon, 13 April 2015, 04:40:05 »
Whens the next group buy?
Ergo Clear White Carbon Filco TKL
Offline kacase
  • All things bright and beautiful.
    • 9di
« Reply #1306 on: Mon, 13 April 2015, 04:42:33 »
Elton is very busy at the moment with the Orion V2 GB and afterwards probably another Lightsaver round. So I'd guess even if there is enough demand the group buy still wont start before Q4 2015
Orion V2 | Rama M65-A | Rama M67-A aka. Exent | Keycool TKL | Cherry MX Board 3.0
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #1307 on: Mon, 13 April 2015, 10:55:02 »
An even better question is when should we expect that V2 Viper/Eagle to be released.  :p
Offline evolveS
  • ಠ_ಠ
« Reply #1308 on: Mon, 13 April 2015, 11:01:40 »
Hopefully with the Orion V2 style acrylic bottom!
"money comes and goes, but doubleshots are forever"
-a petty thief
Offline Latin00032
« Reply #1309 on: Mon, 13 April 2015, 11:35:16 »
The main thing that turned me off from the original Viper GB is the keyboard angle.
I'd hope a new version can have the acrylic part to have a reduced typing angle.
Offline Khers
  • Schrödinger's box
« Reply #1310 on: Mon, 13 April 2015, 12:28:48 »
I ultimately decided to stay out of the Orion V2 GB in anticipation of either a rerun or a V2 of the Viper (ideally with a reduced angle). Given the timeframe that was mentioned here, I might have second thoughts on that decision. Otoh, my wallet will be happier for it ;).
Offline Yslen
« Reply #1311 on: Thu, 16 April 2015, 08:06:16 »
Definitely getting a viper next time around if it happens. Almost bought in last time, but money was an issue. Such an awesome looking board.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1312 on: Thu, 16 April 2015, 08:10:02 »
I'm going to try to get a blue/grey Eagle if there is a R2 (depending on what the case looks like if they change it).
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline azhdar
  • Praise the AZERTY god
« Reply #1313 on: Thu, 16 April 2015, 08:17:39 »
Finger Crossed for an ISO compatible PCB for the ViperV2.
Azerty Propagandiste
Offline ideus
  • Björkö.
« Reply #1314 on: Thu, 16 April 2015, 08:23:35 »
I think you can do that with a GON pcb.
Offline azhdar
« Reply #1315 on: Thu, 16 April 2015, 08:28:03 »
Interesting idea never though of it.
Would have to look at the construction of the viper case to see if it fits.
Offline ideus
  • Björkö.
« Reply #1316 on: Thu, 16 April 2015, 08:35:42 »
It doesn't, at least the Nerd60 does not; because, it does not have the cuts at its corners; however, you could get one of the Sprit's cases that can hold a rectangular PCB but has overlapped covers for the corners; by the way, Sprit's PCB also support the HHKB layout and ISO, but again, with no cut outs.
Offline FoC_Tow
  • Brokehlicious
« Reply #1317 on: Thu, 16 April 2015, 09:43:56 »
+2 for Viper with 7° acrylic bottom!  :thumb:
Edit: Not sure if it would require a redesign of the case as it seems to be a single piece design atm.
On the other hand a two piece case could also include a proper plate mount. (with the plate mounted to the case, instead of the pcb mounted to the case and the plate floating free on the switches poker style)
To me a real plate mount seems like a much cleaner solution, and I always feel like the free floating poker plates tend to have a bell like effect. (So I honestly don't think of poker as plate mount, to me poker is a pcb mount + plate support pretty much, considering you could even assemble without plate)
« Last Edit: Thu, 16 April 2015, 09:54:42 by FoC_Tow »
Offline fatcupcakes
« Reply #1318 on: Thu, 23 April 2015, 02:31:37 »
I just got a built version of the eagle with the standard layout like the poker. Is there a function layer for this?
Offline tjweir
« Reply #1319 on: Thu, 23 April 2015, 06:34:22 »
Depends on how it was programmed.  If you visit duck0113.tistory.com and grab the O2D mapper, you'll be able to write whatever layout you want.
If you run into problems, post back here and we'll help.
Offline awhitedev
« Reply #1320 on: Sat, 02 May 2015, 10:15:51 »
Unfortunately, I joined GH after this group buy was already well on its way. I see there are talks of a Viper V2... that would be very exciting! I hope we see it this year sometime!  :cool:
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #1321 on: Sun, 03 May 2015, 18:31:32 »
Does anyone know the slope of the Viper? Thanks!
Offline Vintage
« Reply #1322 on: Sun, 03 May 2015, 18:57:19 »
11 degrees
CM QFR w/ MX Reds  | Logitech G900
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1323 on: Sun, 03 May 2015, 19:00:57 »
Offline Sed8op8
  • Keyboard Padawan
« Reply #1324 on: Mon, 04 May 2015, 05:43:19 »
agreed.... I had some car trouble and I couldn't do Orion v2 so I really hope there is another Duck GB that I like as I want to build my own Duck this year!
Offline GL1TCH3D
« Reply #1325 on: Sat, 09 May 2015, 23:58:10 »
For those with experience in the duck Viper. How do I reprogram the keyboard?
I followed the instructions, installed the Atmel driver, downloaded flip and got Flip to recognize the keyboard.
My only problem is that I can't create the hex files through the custom keymapper.
When I make my layout and click save I get a constant invalid filepath error.
Offline jonathanyu
« Reply #1326 on: Sun, 10 May 2015, 00:01:32 »
Not sure is this the same problem with my butterfly in the past.  But try to rename the file first before saving.  The default file name doesn't work for my butterfly, so this may be the same problem.
Offline GL1TCH3D
« Reply #1327 on: Sun, 10 May 2015, 00:24:42 »
nop, even if I try saving my layout using something else it doesn't work
NVM I figured it out =S
Got my duck viper up and running
« Last Edit: Sun, 10 May 2015, 01:06:23 by GL1TCH3D »
Offline appleonama
  • Trollo en USA
« Reply #1328 on: Mon, 18 May 2015, 23:39:07 »
Just bought a Eagle from some user and /r/mech and this is a nice keyboard! Heavy as well :D
I had to desolder each switch to add sip sockets and fix the stabs since they were a bit wonky. The leds are currently green and I will be changing them once I receive the new leds in the mail.
Now my question is how do I customize the layout? I don't even know where the FN key is. Also anyone know where to get some new SMD leds I don't like the red ones that are already soldered to the keyboard.
The switches are 62g clears and space bar is a black gateron.
« Last Edit: Mon, 18 May 2015, 23:40:48 by appleonama »
Offline deci
« Reply #1329 on: Tue, 19 May 2015, 16:03:35 »
I love everything about this board except the key mapping software.
I keep hoping someone will add TMK support for it but no luck.
I'm wondering if there are any other PCB's that might fit this case (like Gon 60%).
Something that is already TMK supported.
That or get un lazy and work on the TMK support my self. (I have no idea how to figure out the matrix though)
Offline tjweir
« Reply #1330 on: Tue, 19 May 2015, 17:38:24 »
I feel the same way.
I mapped the matrix using my multimeter and I have a fork of tmk building but I get nothing from the board.
I haven't had time to finish.
Offline appleonama
  • Trollo en USA
« Reply #1331 on: Tue, 19 May 2015, 20:56:22 »
Can someone help me out with the 02D software. I can't figure this thing out. The arrow keys are just question marks and the function layer is not working as programmed.
Offline tjweir
« Reply #1332 on: Tue, 19 May 2015, 21:07:31 »
I answered the same thing in the Octagon thread, try this: https://geekhack.org/index.php?topic=65036.msg1710404#msg1710404
Offline appleonama
  • Trollo en USA
Offline aznairjordan
TGR Jane CE|FC660C|Orion V2
GMK Hyperfuse|GMK Olivetti|GMK Red Alert|Soulfree's Teal|GMK Cyan
« Reply #1335 on: Wed, 10 June 2015, 15:47:05 »
viper v2
http://kbdlab.co.kr/index.php?mid=board_Lsno50&search_target=nick_name&search_keyword=duck0113&document_srl=2713321
That recess must before the huge cojones this board will have.  My fingers are crossed that it will be alps compatible.
Offline Vintage
« Reply #1336 on: Wed, 10 June 2015, 16:23:54 »
What is the purpose of the cutout on the bottom?
Offline trizkut
« Reply #1337 on: Wed, 10 June 2015, 16:30:04 »
Trackpoint module  I think.
Offline Vintage
« Reply #1338 on: Wed, 10 June 2015, 16:31:29 »
wow.... interesting design.
Offline Sed8op8
  • Keyboard Padawan
« Reply #1339 on: Wed, 10 June 2015, 16:47:50 »
that's  different I missed the first viper I really want one of these if they ever go live
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1340 on: Fri, 03 July 2015, 16:13:58 »
This is a long shot since this ended a long time ago, but if anyone has a kit they haven't built yet/don't want I am more than happy to buy it off of you :) and sorry for necro
Offline wlhlm
« Reply #1341 on: Fri, 03 July 2015, 16:16:23 »
Good luck! ;)
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1342 on: Fri, 03 July 2015, 16:18:38 »
Good luck! ;)
Yeah, I have always had it in my head that I would like one, and then after getting my octagon I realized how awesome duck's boards were
Offline ViệtNV
    • VNMK
« Reply #1343 on: Fri, 03 July 2015, 23:41:12 »
when we have a new GB for this keyboard?
Offline koyo
« Reply #1344 on: Thu, 16 July 2015, 16:33:03 »
I just got this board and it's awesome  ;D
  • Chinchillin'
« Reply #1345 on: Thu, 16 July 2015, 18:09:05 »
Damn right it is.
Offline GL1TCH3D
« Reply #1346 on: Fri, 17 July 2015, 06:04:33 »
Just curious, is the plate alps compatible as well? I know the PCB is... Wondering if I need to have a new plate made
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1347 on: Fri, 17 July 2015, 07:57:41 »
Any new info on r2?  I'm really interested in a Eagle.
Would also like to know if there will be ALPS plates offered.
WTB/WTS/WTT ---->
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #1348 on: Fri, 17 July 2015, 08:20:54 »
Hoping to get in on a Viper possibly.
Offline ideus
  • Björkö.
« Reply #1349 on: Fri, 17 July 2015, 09:32:40 »
What is the programming system for the viper?
