Author Topic: Duck Viper and Eagle Group Buy  (Read 1140377 times)
Offline Fnzzy
Re: Duck Viper and Eagle Group Buy
« Reply #1150 on: Sat, 29 November 2014, 13:25:56 »
Got my inserts today, thanks Elton! Board looks a lot more complete now! Only waiting for cyan LEDs and the courage to replace the side LEDs :x
Are you going to desolder/resolder the whole board to put the LEDs in?
No, I just have to put them through the hole and solder them onto the PCB. Shouldn't take too long.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #1151 on: Tue, 02 December 2014, 17:32:24 »
Awesome! Now I need to decide if I should make one of my sets look frosted.
YES...
No Frosty
Yes Frosty
|||My other keyboards :
x
Offline Razor Lotus
« Reply #1152 on: Wed, 03 December 2014, 13:37:31 »
Got my inserts yesterday! Thanks Elton
YES...
No Frosty
Yes Frosty
Wow man looks good!
Btw, what LEDs are you using? That colour looks really great :)
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #1153 on: Wed, 03 December 2014, 14:24:50 »
Wow man looks good!
Margon assembled mine but they seem like regular red leds. It's the stainless plate with the clear tops that causes this "fire/lava" effect on camera. It is a little bit more reddish IRL.
x
Offline feizor
« Reply #1154 on: Wed, 03 December 2014, 15:02:19 »
Ah I see the clear switch tops!
Offline Synjin
« Reply #1155 on: Thu, 04 December 2014, 20:31:25 »
Can anyone possibly help me program my viper? Btw wher eis the default ctrl key for this?
Offline keyit
« Reply #1156 on: Thu, 04 December 2014, 21:28:15 »
what do you need help with exactly?
boop
Offline nuclearsandwich
« Reply #1157 on: Thu, 04 December 2014, 21:47:06 »
working with synjin via PM.
Offline Sygaldry
  • Edema Ruh
« Reply #1158 on: Sat, 06 December 2014, 20:31:00 »
So what's the general consensus on the preferred keycap profile for these boards?
I'm trying to decide whether I want Granites (DSA) or Classic Beige Otaku (Cherry Profile) on my Viper (which finally touched down Stateside and recently got through customs!).
null
Offline billnye
  • ability man
« Reply #1159 on: Sat, 06 December 2014, 20:33:17 »
Cherry profile is always best profile.
Offline Sygaldry
  • Edema Ruh
« Reply #1160 on: Sat, 06 December 2014, 20:44:08 »
But my only Cherry set (Classic Beige Otaku) is missing a 1.75u Right Shift  :-X
null
Offline billnye
  • ability man
« Reply #1161 on: Sat, 06 December 2014, 20:46:21 »
Gotta get the full right shift fam. fn was meant to be on the bottom row anyway :p
Offline Sygaldry
  • Edema Ruh
« Reply #1162 on: Sat, 06 December 2014, 20:50:54 »
Noooo, with less keys on the bottom row, it's hard to find a place to fit the FN
Plus, I love the HHKB split Shift/FN
Push comes to shove, I'll just wait to score a GMK CYMW kit or something =/
null
« Reply #1163 on: Sat, 06 December 2014, 20:51:32 »
Billnye420 is right.  (what has this world come to)
Cherry is best.  If you're having issues with cap sizes, I'd try to find a CMYK or other set that can flesh out the missing caps.  But that's obviously a lot of work, I don't mean to make it seem easy.  But IMO it's worth it since Cherry profile is best.  :))
Offline billnye
  • ability man
« Reply #1164 on: Sat, 06 December 2014, 20:52:12 »
I might be able to help you with that ;)
Send me a pm if you are interested in a set
« Reply #1165 on: Sat, 06 December 2014, 21:08:48 »
1800 shift master race
Offline Sygaldry
  • Edema Ruh
« Reply #1166 on: Sat, 06 December 2014, 22:40:13 »
Already have a laser printed set. Don't like
null
« Reply #1167 on: Sat, 06 December 2014, 22:41:35 »
don't see what that has to do with the size of the 1800 shift but okay o.O
Offline Sygaldry
  • Edema Ruh
« Reply #1168 on: Sat, 06 December 2014, 23:21:20 »
Its a laser printed 1800 set, I don't like it
I wish it was dye sub
null
« Reply #1169 on: Sat, 06 December 2014, 23:23:16 »
Offline Synjin
« Reply #1170 on: Sat, 06 December 2014, 23:26:11 »
Those vortex thick PBT keycaps being sold on Massdrop occasionally are all cherry profiles aren't they?
Offline Vintage
« Reply #1171 on: Sat, 06 December 2014, 23:40:20 »
I think the doubleshot PBT is OEM
CM QFR w/ MX Reds  | Logitech G900
« Reply #1172 on: Sat, 06 December 2014, 23:58:07 »
I think you're missing the point.  You made a comment about wanting a short right shift, so demik said 1800 layouts have short right shifts.  Then you said that you have a laser printed 1800 set and you don't like it.  That's irrelevant.  If you don't want lasered caps, don't buy lasered caps.
Offline Sygaldry
  • Edema Ruh
« Reply #1173 on: Sun, 07 December 2014, 00:20:31 »
no I didn't miss the point
Just stated that I have a set of 1800 caps and wish they were dye subbed.
0.0
null
« Reply #1174 on: Sun, 07 December 2014, 00:26:27 »
well i like turtles but i wish they were penguins
Offline Sygaldry
  • Edema Ruh
« Reply #1175 on: Sun, 07 December 2014, 04:01:52 »
If I realized I would be gang raped for posting my thoughts on one particular iteration of a keyset I would have refrained from responding.... nvm.... what was I expecting... this is GH after all... keyboards are our weapon of choice.
You win. Sry for offending you.
TIL: be very careful when responding to demik
« Last Edit: Sun, 07 December 2014, 04:19:45 by Sygaldry »
null
Offline billnye
  • ability man
« Reply #1176 on: Sun, 07 December 2014, 11:53:00 »
Yes they're OEM
Offline Synjin
« Reply #1177 on: Sun, 07 December 2014, 12:31:01 »
oh. I need some cherry profile keys to try on my viper since I found out that the SA3 nuclears do not fit the right way and the sides/edges scrape partially on to the Alu casing.
Offline deci
« Reply #1178 on: Sun, 07 December 2014, 18:42:33 »
the black ones that are blank or laser etched are cherry profile
https://www.massdrop.com/buy/vortex-pbt-keycaps
i have blank ones and they are pretty nice although they are more of a very dark grey than an actual black.
the double shot ones however are oem.
either way the profile should be in the description.
« Reply #1179 on: Sun, 07 December 2014, 20:42:42 »
you didn't offend me. just your reply threw me off since i was agreeing with you on the short right shift then you said you didn't like it o.O
Offline Sygaldry
  • Edema Ruh
« Reply #1180 on: Sun, 07 December 2014, 22:08:36 »
Ah, in that case I was probably just unclear with my initial post. My bad.
All I meant to convey is that even though I am super sure of using a short right shift, I am reluctant to use the one from my own 1800 set which is laser printed and feels completely different to the touch from my Otaku Classic Beige set. I was directing my "dislike" towards my particular 1800 keyset not against the 1800 keyset in general or your post.
null
Offline tjweir
« Reply #1181 on: Mon, 08 December 2014, 08:47:02 »
Nothing is soldered yet, but I finally had some time to get working on my Viper.
It's a motley mix of switches, but it's all part of a plan I swear.
83576-0
Offline DrHubblePhD
  • I am star stuff
« Reply #1182 on: Mon, 08 December 2014, 08:58:19 »
Nice red switch covers!  :thumb:
Offline tjweir
« Reply #1183 on: Mon, 08 December 2014, 09:08:49 »
Thanks, I have white as well, but the white covers and the clear stems look weird together.
Offline Sygaldry
  • Edema Ruh
« Reply #1184 on: Mon, 08 December 2014, 19:15:13 »
Just curious... is anyone building/has anyone built their Vipers/Eagles with Alps/Matias switches?
null
« Reply #1185 on: Mon, 08 December 2014, 19:46:33 »
my viper stayed with me for a total of about 2 weeks (never assembled)
good bye viper.
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #1186 on: Mon, 08 December 2014, 20:15:02 »
good bye viper.
You sold it, or something?
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1187 on: Mon, 08 December 2014, 20:15:35 »
good bye viper.
mfw demik sold another faux hhkb
« Reply #1188 on: Mon, 08 December 2014, 20:50:43 »
good bye viper.
yup.
true hhkb 4 lyfe
Offline jorgenslee
« Reply #1189 on: Tue, 09 December 2014, 09:31:38 »
Here's my unassembled Viper with the insert I got yesterday. Sanded with 260 for the frosted look.
2nd picture is an over exposure though but I kinda like the effect.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #1190 on: Tue, 09 December 2014, 11:40:53 »
That looks great! Seems like a coarser grit gives an even more diffused look.
x
Offline jorgenslee
« Reply #1191 on: Tue, 09 December 2014, 11:48:08 »
Yeah I guess, I think we could use 100 on the side of the LED. Since it is hidden it does not matter.
Offline billnye
  • ability man
« Reply #1192 on: Tue, 09 December 2014, 12:18:11 »
That looks great! Looks like I'm switching grit haha
Offline Fnzzy
« Reply #1193 on: Tue, 09 December 2014, 12:43:00 »
Alright looks like I need to detach my inserts and put them into the freezer because now I want that frosted look as well!
Offline ceflame
« Reply #1194 on: Tue, 09 December 2014, 19:31:06 »
Anyone need a set of acrylic inserts? I'm willing to hand it off at cost + shipping.
Offline billnye
  • ability man
« Reply #1195 on: Tue, 09 December 2014, 19:43:39 »
If anyone wants a viper plate I can send it to you for shipping cost only!
Offline geogga
  • gosh dang GH and their GBs
« Reply #1196 on: Tue, 09 December 2014, 19:49:29 »
someone give me the whole package  ;D
Offline Sygaldry
  • Edema Ruh
« Reply #1197 on: Tue, 09 December 2014, 20:08:09 »
I wonder if it would be possible to mod the case to fit alps switches.  :cool:
null
Offline jorgenslee
« Reply #1198 on: Tue, 09 December 2014, 20:09:55 »
I'm interested. how much shipped to phil?
Offline billnye
  • ability man
« Reply #1199 on: Tue, 09 December 2014, 20:31:45 »
I'll pm you!
