Author Topic: Duck Viper and Eagle Group Buy  (Read 1137766 times)
Offline Fnzzy
Re: Duck Viper and Eagle Group Buy
« Reply #1000 on: Thu, 06 November 2014, 05:49:50 »
Probably a dumb question but where are you guys getting your side LED's from?  I looked around and found a lot of places selling strips but not the individual ones, at least, not in the color I want.  :confused:
I have the same problem. I live in germany and I can't find a shop that sells single LEDs in that size. Only mouser carries 3 colors that I don't want. Dark red, yellow and yellow-green.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #1001 on: Thu, 06 November 2014, 14:35:58 »
Yuuuup.  I found a place in Australia that sells the pink I want but shipping to me is 20 bucks. >:D
Offline feizor
« Reply #1002 on: Thu, 06 November 2014, 15:04:41 »
Link please :)
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #1003 on: Thu, 06 November 2014, 15:23:40 »
Link please :)
http://www.ledsales.com.au/shop/index.php?main_page=advanced_search_result&search_in_description=1&keyword=3528
If someone can confirm these are the correct ones, that'd be swell.  And maybe...an Aussie can proxy?  Cause...seriously, **** that shipping price.
Offline elton5354
« Reply #1004 on: Thu, 06 November 2014, 15:47:54 »
Offline Fnzzy
« Reply #1005 on: Thu, 06 November 2014, 16:45:24 »
I ACTUALLY found some blue ones in germany. 3528 SMD LED, 3,5 x 2,8 x 1,9mm.
http://www.ebay.de/itm/10-blaue-SMD-LEDs-PLCC2-3528-mini-Led-smds-BLAU-blue-/370395591815?pt=LH_DefaultDomain_77&hash=item563d4c3487
10 pieces for 2.09€ + 1€ shipping. Not a great price compared to those from china but still 3€ for more LEDs than I need AND they will most likely arrive next week. Probably going to order these!
« Last Edit: Thu, 06 November 2014, 16:58:00 by Fnzzy »
« Reply #1006 on: Thu, 06 November 2014, 17:00:12 »
elton whats the word on 2nd batch shipping
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #1007 on: Thu, 06 November 2014, 17:11:46 »
What about these ones?
http://www.ebay.com/itm/100pcs-POWER-TOP-SMD-SMT-Multicolor-PLCC-2-3528-1210-Bright-LED-Light-/191324593528?pt=US_Light_Bulbs&var=&hash=item7231509bf4
As for acrylic inserts, I think I'll be getting them next week.
No pink. :(  Might just have to go with white.
Edit: Looks like they have pink but it's not one of the options in the drop down.  Time to message them. :rolleyes:
Edit 2: Or I'm just blind and a quick search in their store turned up what I was looking for.  Dunno how I missed it before.  Thanks, Elton.
« Last Edit: Thu, 06 November 2014, 17:16:14 by Sent »
Offline jorgenslee
« Reply #1008 on: Fri, 07 November 2014, 03:20:03 »
Hopefully someone kind enough would share their build log on this. That would be much appreciated.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #1009 on: Fri, 07 November 2014, 03:23:56 »
here ya go: http://geekhack.org/index.php?topic=61027.msg1519382#msg1519382
Offline jorgenslee
« Reply #1010 on: Fri, 07 November 2014, 03:48:28 »
Cool. Thanks. Didn't see that before.
Offline Sygaldry
  • Edema Ruh
« Reply #1011 on: Fri, 07 November 2014, 11:49:57 »
So here's my last ditch attempt to get one of these.
Anyone have an unbuilt Viper they are willing to part with?
I offer moneys and my eternal gratitude.
Help a brother out!
null
Offline tjweir
« Reply #1012 on: Fri, 07 November 2014, 12:03:14 »
Awesome!
Offline elton5354
« Reply #1013 on: Fri, 07 November 2014, 14:11:50 »
All is shipped now even 2nd batch. I'll update the tracking when I get them.
« Reply #1014 on: Fri, 07 November 2014, 15:34:54 »
Help a brother out!
$600
jk
Offline ComradeSniper
  • HHKB Pro
« Reply #1015 on: Fri, 07 November 2014, 16:58:42 »
Awwwww yeah
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #1016 on: Fri, 07 November 2014, 19:44:14 »
I'm doing the happy dance.  Too bad I'm still waiting on other parts. :rolleyes:
Offline Sygaldry
  • Edema Ruh
« Reply #1017 on: Fri, 07 November 2014, 20:00:25 »
Help a brother out!
$600
jk
This made me sad.
I am a sad panda.
null
Offline deci
« Reply #1018 on: Fri, 07 November 2014, 21:25:59 »
All stabs and switches acquired and modded and soldering station already set up...
I set it up on the kitchen table though so don't think my gf is too happy about that part  :D
Offline minho
  • i'm kind of back
« Reply #1019 on: Sat, 08 November 2014, 01:50:46 »
Would anyone happen to know the default control or caps lock key on the viper? I used autohotkey to rebind capslock to control, but now I don't have a capslock anymore. Not the most crucial thing, but it would be nice if there was a way to easily rebind fn+tab to caps lock, especially considering default HHKB fn layer is there already. (I tried out that software on Duck's website, but it was quite confusing, and I'm not sure a caps lock key is worth that much time to me :p )
Offline feizor
« Reply #1020 on: Sat, 08 November 2014, 02:35:45 »
+Capslock::Capslock
The above autohotkey script line will make shift+caplock act as the caplock
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #1021 on: Sat, 08 November 2014, 14:20:40 »
So, I'm building my viper today and I noticed the small fn key position next to the right shift position has no slot on the plate so it has to sit directly on the PCB. This means it will sit a few millimeters below the rest of the switches mounted in the plate. Did anyone else notice that? Has anyone done anything to level out that switch with the rest of them?
EDIT: I just figured it out. I had to wiggle the plate to allow it to settle on the stabs which brought all the switches level.
« Last Edit: Sat, 08 November 2014, 14:23:18 by cooldiscretion »
Offline Fnzzy
« Reply #1022 on: Sat, 08 November 2014, 14:50:31 »
How are you guys that are going to replace the side LEDs doing it? Are you going to use hot air or very carefully use the normal soldering iron?
« Reply #1023 on: Sat, 08 November 2014, 17:49:49 »
Does anyone have a copy of the pdf tutorial for using the 02D keymapping software? I found a link to a PDF file in the lightsaver thread, but it no longer works.
Offline elton5354
« Reply #1024 on: Sat, 08 November 2014, 18:01:16 »
here it is
« Reply #1025 on: Sat, 08 November 2014, 18:09:53 »
Offline feizor
« Reply #1026 on: Sat, 08 November 2014, 18:21:06 »
« Reply #1027 on: Sat, 08 November 2014, 19:38:48 »
Has anyone had issues programming the arrows on the viper/eagle?  In the 02D Firmware they show as question marks and when I mapped those they displayed as empty.
Everything else worked for me, but for some reason this arrow issue...
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #1028 on: Sat, 08 November 2014, 19:51:42 »
Change your locale to Korean.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline trizkut
« Reply #1029 on: Sat, 08 November 2014, 19:51:51 »
You need to change your locale to Korean.  You can use AppLocale (http://www.microsoft.com/en-us/download/details.aspx?id=13209) to open 02D with Korean language locale without having to restart every time you want to change something.
« Reply #1030 on: Sat, 08 November 2014, 20:12:11 »
Thanks so much, guys! I would have never figured that out. Finally finished the board. True HHKB style with 65g lubed & stickered MX blacks.
Offline Fnzzy
« Reply #1031 on: Sat, 08 November 2014, 20:41:42 »
Oh wow, while I was waiting for the last parts I made a layout today and already accepted that I won't have arrow keys. Thanks everyone!
« Reply #1032 on: Sat, 08 November 2014, 22:21:13 »
After a full day of assembly, here is my Viper.  I decided to use 65g lubed and stickered Mx blacks with the exception of the spacebar which is a 75g grey.
For anyone interested here is a link to some pictures.
http://imgur.com/a/e4QMo
Offline byker
  • Literally Canada
« Reply #1033 on: Sat, 08 November 2014, 22:22:55 »
That looks amazing! Well done.  :thumb:
Offline loud_asian
« Reply #1034 on: Sun, 09 November 2014, 00:31:35 »
well this sucks, anyone know where I can source a 7x spacebar?
« Reply #1035 on: Sun, 09 November 2014, 00:36:43 »
Ivan had a GMK GB, you might be able to score one from someone willing to sell one.  Otherwise, you'll have to try and find a G80 set from a board with a 7x spacebar.  Some might be affordable from Taobao.
  • HHKB Pro
« Reply #1036 on: Sun, 09 November 2014, 00:39:18 »
Depending on how quickly you want one, you could buy the "winkeyless mods" kit from Originative's GMK Cyrillic set which comes with a 7x spacebar.
« Reply #1037 on: Sun, 09 November 2014, 00:40:35 »
Then hope and pray it gets shipped.
  • HHKB Pro
« Reply #1038 on: Sun, 09 November 2014, 00:50:52 »
I've had good experiences with their shipping and communication lately. Some people are still missing caps from age old orders though, so who knows.
Offline jorgenslee
« Reply #1039 on: Sun, 09 November 2014, 09:07:04 »
If you don't mind me asking, can you take a photo with all LEDs on and your room's light off?
Offline billnye
  • ability man
« Reply #1040 on: Sun, 09 November 2014, 09:08:15 »
SP has a ton of them
http://keyshop.pimpmykeyboard.com/products/inventory/spacebar-inventory
Offline DrHubblePhD
  • I am star stuff
« Reply #1041 on: Sun, 09 November 2014, 09:37:36 »
Quick question, Duck Eagle or Octagon?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #1042 on: Sun, 09 November 2014, 09:42:00 »
60% vs 75%...
Offline Zeal
    • Zeal Generation Inc.
« Reply #1043 on: Sun, 09 November 2014, 09:42:06 »
Considering the Eagle GB is now over... Your answer should be obvious! :p
Offline Synjin
« Reply #1044 on: Sun, 09 November 2014, 09:54:53 »
they are complrtely different from each other so it is up to personal preference. Octagon is a great choice if you want a 75% and you absolutely need those extra buttons but eagle is the one you should get if you want portability as well as being compact while having full key remapping while still having all the features of a full board if you can use Fn ( they both have this feature)
Zeal is right lol. Eagle GB just ended so only way to get an eagle is if someone was Willi g to let theirs go at such an early time. The second round just started shipping
« Last Edit: Sun, 09 November 2014, 10:26:13 by Synjin »
« Reply #1045 on: Sun, 09 November 2014, 17:16:50 »
Thanks man!
« Reply #1046 on: Sun, 09 November 2014, 17:17:13 »
I'll take a pic this evening and upload it.
Offline tribade
« Reply #1047 on: Mon, 10 November 2014, 00:13:43 »
Beautiful!  Great job!
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
Offline elton5354
« Reply #1048 on: Mon, 10 November 2014, 00:52:28 »
Tracking #s are up.
« Reply #1049 on: Mon, 10 November 2014, 01:01:06 »
Here ya go. Phone cam quality but it seemed to turn out alright.
http://imgur.com/69noc40
