Author Topic: Duck Viper and Eagle Group Buy  (Read 1137724 times)
Offline Synjin
Re: Duck Viper and Eagle Group Buy
« Reply #850 on: Sun, 19 October 2014, 22:11:01 »
Are you sure about that demik? It sounds like rocket science to me. Not everyone is smart in GH ^_^
I'm crying with tears of sarcasm now T_T
Offline paobit
« Reply #851 on: Sun, 19 October 2014, 22:12:48 »
so if there's no tracking number next to your name on the sheet, you're on the 2nd batch right?
did you even bother to go through the thread? it has been said multiple times already.
the second batch starts with analogblu
if there is no tracking next to your name BEFORE analogblu then it's because elton hasnt gotten it yet. holy **** it's not hard to figure out.
lol woops. Didn't bother reading the past posts. I just kept seeing "mine is arriving xxx" and got sad lol
« Reply #852 on: Sun, 19 October 2014, 22:18:46 »
and ladies and gentlemen, the biggest problem on internet forums.
Offline Synjin
« Reply #853 on: Sun, 19 October 2014, 22:23:39 »
In his defense, sometimes there might be too many pages for someone to read over everything :P
« Reply #854 on: Sun, 19 October 2014, 22:24:55 »
that's not an excuse
Offline phatdood9
« Reply #855 on: Sun, 19 October 2014, 22:39:13 »
i read that as if your avatar's hairy dude with a tank top said it  :))
9998 posts damn  :eek:
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #856 on: Sun, 19 October 2014, 22:45:52 »
Carl.  His name is Carl.  He has a *****en ride and an outdoor pool
« Reply #857 on: Sun, 19 October 2014, 22:47:46 »
what do you want?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #858 on: Sun, 19 October 2014, 22:50:07 »
this is a post
Offline ceflame
« Reply #859 on: Mon, 20 October 2014, 03:09:35 »
Man, I give up trying to fix my PCB, might just be cheaper/less hassle to get a new one, since I don't want this alu case to go to waste.
I'm under the impression that the Nerd 60 PCB should be compatible with the Eagle case/plate, anyone know if this is for sure? I checked on GON's website and they do look like the have the same holes for the PCB/case.
Offline feizor
« Reply #860 on: Mon, 20 October 2014, 03:53:33 »
Well, just as a warning, if you do winkeyless layout, the 3 keys on the bottom left (ctrl, win, alt) change orientation for LED, didn't notice that as I was just putting in all the LEDs. Just a result of me being careless and not double checking.
Ended up trying and failing to desolder the LED's with the worst possible desoldering pump, and ended up burning off the pads/traces due to frustration.
It actually did still work after those steps, but maybe it shorted after I cleaned it with alcohol or something? Not exactly sure, and currently I have no idea what to do with this. When it's plugged in, it says device is not recognized.
Hey dude, this could be a long shot but you might wanna try clipping all the LED legs off with a flush cutter. I noticed you left the legs pretty long and they could be shorting out by touching the case.
I don't see how having the leds in the wrong way or lifting a pad or two could stop the board from working, since the LED's are optional in the first place.
Might wanna try this before wasting the awesome duck PCB.
Offline xybre
  • clickityclackclickityclack
    • Music and Stuff
« Reply #861 on: Mon, 20 October 2014, 08:40:53 »
I have my lightsaver currently programmed with the 02d keymapper. Which version are you using?
I heard there was a bug with the current one on duck's website, so I just downloaded the most recent looking one I could find from KBDlab.kr.
Firstly, it may help to read this:
http://geekhack.org/index.php?topic=53942.0
If that doesn't help, please feel free to ask questions. it can be a little hard to figure out at first, but once you've got it, it's pretty good.
I am using v1.3.240 I think, but I also have 1.3.244 and 1.4.288
Note that the above is for the lightsaver, but I think they work with viper/eagle as well. If not 02d is sure to add support for them soon.
The latest one from the official page (not Duck's page) supports the Eagle/Viper explicitly. That's not the problem, I was just trying to figure out what it can and can't do. The interface is terrible and the documentation is all in Korean (And seems to be organized poorly even so). I translated enough to get a general idea. But it doesn't look like the 02D firmware can do even half of what I want. So I'm setting up the TMK firmware on one of my dev VMs and I'm going to try building a suitable layout with that instead.
Unless you know how to get 02D to supply arbitrary HID scan codes that is (so I can support things like proper media keys).
GON NerD 60 & Duck Eagle & Unicomp Ultra Classic & Das Keyboard Ultimate
Offline Gh05tx
« Reply #862 on: Mon, 20 October 2014, 09:25:55 »
If it says device not recognized dont you just have to install the firmware?
Offline ceflame
« Reply #863 on: Mon, 20 October 2014, 09:56:07 »
I guess I could try that as my last shot. I just don't think that's the issue since it was working before.
Offline Fnzzy
« Reply #864 on: Mon, 20 October 2014, 12:21:02 »
That's unfortunate. I heard that the PCBs weren't very high quality and pads can lift easily when you desolder something.
Where did you read that? I think the PCBs are of excellent quality and have never had any issue desoldering. They are better than KMAC for sure.
I can't remember where I read it and I couldn't find it since the search engine gives me nothing on Duck PCB but it is great to hear the opposite for sure!
Offline keyit
« Reply #865 on: Mon, 20 October 2014, 14:25:11 »
temporary till GMK DOLCH comes
also just re-iterating what ceflame said, the left ctrl, alt, win LED orientations are reversed compared to the rest of the board. i noticed they weren't turning on and couldn't figure it out until i reversed them. i used sip sockets so that didn't involve any desoldering. but i hope you do resolve your issue ceflame.
boop
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #866 on: Mon, 20 October 2014, 14:30:13 »
Oh, I hope tjcaustin finishes mine up soon...
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline Fnzzy
« Reply #867 on: Mon, 20 October 2014, 16:09:39 »
Apparently mine got out of customs today, I hope I will recieve it in the next few days!
Offline bazh
« Reply #868 on: Mon, 20 October 2014, 16:36:15 »
damn, I got to go to customs to get mine :(
HHKB Pro2 white
Newbie again
Offline billnye
  • ability man
« Reply #869 on: Mon, 20 October 2014, 17:13:13 »
Got my board!
Viper by billnye29, on Flickr
Packaging on this was 10/10, Duck did a great job making sure it stayed safe. I will be building it as soon as my stabs from Ivan's gb come in!
Offline jorgenslee
« Reply #870 on: Mon, 20 October 2014, 21:04:24 »
Does someone know where we can source the SMD side led? I plan to replace it with white.
Offline keyit
« Reply #871 on: Mon, 20 October 2014, 21:09:44 »
I too plan on changing it out. Does anyone know what size they are? 3528? 5050? Something different? Thanks
boop
Offline Fnzzy
« Reply #872 on: Mon, 20 October 2014, 21:20:21 »
The Side LEDs are 3.5mm x 2.8mm in size (3528 or 1411 package size).  If you are changing the side LEDs, please note the orientation of the original LEDs before removing them: it's not symmetric!
All LED resistors appear to be 470 Ohm variety.
Offline pmh1410
« Reply #873 on: Mon, 20 October 2014, 23:36:53 »
Get my Eagles today, Special thanks to Elton, Duck0113 and Byungho Kim.
Offline ceflame
« Reply #874 on: Tue, 21 October 2014, 02:18:00 »
Man, I'm so depressed. Fully built my Nerd TKL today, but managed to destroy the Eagle beforehand. :P
Well, RIP Eagle PCB. Good luck to everyone with their builds. Don't be an idiot like me ;D
  • Keyboard Hipstar
« Reply #875 on: Tue, 21 October 2014, 02:42:18 »
Maybe you can ask one of the nice folks around here to see what they can do to fix it.
You know, pay to ship it to them, or whatever, and see what happens.
Can't hurt to try.
Offline ceflame
« Reply #876 on: Tue, 21 October 2014, 02:59:12 »
Can't hurt to try.
Any suggestions for who to ask?
I know a lot of the service people usually have their hands full with other things.
  • Keyboard Hipstar
« Reply #877 on: Tue, 21 October 2014, 03:09:26 »
Well, there's tjcaustin, who is assembling my Viper, there's Hoffman, I think dorkvader does this sort of thing...
I haven't been here all that loong, but maybe make a thread asking for help, and see what happens.
Offline feizor
« Reply #878 on: Tue, 21 October 2014, 04:48:31 »
Can't hurt to try.
Did you try clipping the LED legs?
Offline pmh1410
« Reply #879 on: Tue, 21 October 2014, 05:28:45 »
Why we do not try with Remouvable Led ?
Offline feizor
« Reply #880 on: Tue, 21 October 2014, 07:39:51 »
He has already soldered all the LED's and upon trying to desolder three, has lifted the pads and now the board is no longer functioning. But I think the LED legs have been left too long and is shorting out with the case.
Offline mousesony
« Reply #881 on: Tue, 21 October 2014, 08:42:56 »
How do you turn the leds off on an winkeyless eagle?
Offline mousesony
« Reply #882 on: Tue, 21 October 2014, 09:52:27 »
Never mind, I flashed it and got everything working.
It doesn't seem like there was a way to toggle them off without flashing it.
Offline ceflame
« Reply #883 on: Tue, 21 October 2014, 11:17:54 »
Can't hurt to try.
I forgot to mention that it doesn't work even when not in the case, so I don't think it's a matter of shorting out when touching the case, sadly
Offline nuclearsandwich
« Reply #884 on: Tue, 21 October 2014, 11:38:27 »
Can't hurt to try.
If you're ever up in the SF bay area there's a handful of us who can take a look at it. I don't have dedicated time right now to say you can ship it and I'll take a look. But if you were coming north for some other reason and I don't have anything planned for that time, I'll happily make some time to take a look.
Offline Zeal
    • Zeal Generation Inc.
« Reply #885 on: Tue, 21 October 2014, 13:03:19 »
Vipers arrived, mailman woke me up while I was still in bed -- didn't have tracking so I didn't know :p Was part of the second wave of R1.
Offline Synjin
« Reply #886 on: Tue, 21 October 2014, 14:09:57 »
It had tracking and was probably sent as express most likely just
Ike mine. It arrived yesterday  and was taken back to the PO even if I wasn't given the tracking info by elton
I was not home yesterday so I had to pick it up today but the pickup slipleft on my mailbox yesterday had a tracking info.
Offline Zeal
« Reply #887 on: Tue, 21 October 2014, 14:15:50 »
Yeah, I know it was sent via EMS, just second wave of shipments didn't get their tracking info forwarded. So for those in the second wave of R1, expect to receive a box soon!
« Reply #888 on: Tue, 21 October 2014, 14:55:15 »
As soon as yesterday!  :eek:
  • Keyboard Hipstar
« Reply #889 on: Tue, 21 October 2014, 15:04:01 »
So I'm gonna need people to post more pictures, that I might soothe this impatience itch as I wait for mine.
Offline tjweir
« Reply #890 on: Tue, 21 October 2014, 16:02:12 »
Mine arrived, thanks Elton and Duck!
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #891 on: Tue, 21 October 2014, 17:09:03 »
I received mine.  Should be building it as soon as Ivan's Dolch keyset and Stabilizers arrive.
I have some vintage Cherry stabilizers laying around, but there is no sense in not being patient now that the Dolch set will be shipping so soon.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #892 on: Tue, 21 October 2014, 17:20:30 »
I demand more build logs/pics of Vipers.
Glad to see that R1 is pretty much taken care of.  Hopefully, this means that R2 is almost there.
Offline Fnzzy
« Reply #893 on: Tue, 21 October 2014, 18:04:47 »
My Viper arrived in germany on wednesday last week. Today it arrived at my towns post office. Hopefully I get notified that I can pick it up tomorrow. Then I will post some pictures and do a build log when I have all my parts ready  ;)
Offline Synjin
« Reply #894 on: Tue, 21 October 2014, 19:45:57 »
Do people here want me to post some of the photos I've taken of the ALU cases? I haven't opened the rest yet.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #895 on: Tue, 21 October 2014, 19:47:21 »
sure, why not :p
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #896 on: Tue, 21 October 2014, 19:48:54 »
I'll never say no to photos.
  • Keyboard Hipstar
« Reply #897 on: Tue, 21 October 2014, 19:51:27 »
Yes.
Yeeeesss.
Offline elton5354
« Reply #898 on: Tue, 21 October 2014, 20:51:47 »
I've updated all the 1st batch tracking on the spreadsheet except for Hoffman's order as they were waiting for the Light Pad's PCB.  Duck will have it by tomorrow and will be shipped right after.  Sorry to Hoffman and those in his  order.
I'm not taking any more payments for the acrylic inserts as I've already had them ordered and I will get them next week or so.
Here's the link to the inserts spreadsheet
https://docs.google.com/spreadsheets/d/1mlGWvNuk5QabOohBKYSD2rcQFcjALC0BZWs1RB1lV1E/pubhtml
« Last Edit: Tue, 21 October 2014, 21:19:11 by elton5354 »
Offline keyit
« Reply #899 on: Tue, 21 October 2014, 21:24:35 »
awesome. thanks for running this gb along with the inserts elton!
boop
