Author Topic: [Software] NerDy GUI for NerD Controller  (Read 10137 times)
Offline GON
  • Skype ID : GonsKeyboardWorks
    • GONsKeyboardWorks
« on: Wed, 30 July 2014, 23:46:43 »
Hi,
Now the most advanced and easy to use GUI has been released.
NerDy GUI
Here are video manuals for it. ;)
You can see how gorgeous it is!
Video Manual for NerDy GUI #1 - Layout Configuration
Video Manual for NerDy GUI #2 - Keymap Configuration
Video Manual for NerDy GUI #3 - LEDs Configuration
Video Manual for NerDy GUI #4.1. - Macro Record&Recall
Video Manual for NerDy GUI #4.2. - Macro Management
Even though I have made/assembled/tuned HUNDREDs of keyboards for others, I myself don't have a full-tuned Custom Keyboard now.
So Ironical!
Offline pmh1410
Re: [Software] NerDy GUI for NerD Controller
« Reply #1 on: Thu, 31 July 2014, 00:04:41 »
I like Nerd series keyboards ;)
Offline GON
    • GONsKeyboardWorks
« Reply #2 on: Thu, 31 July 2014, 00:11:09 »
Than you. ;)
(I like them, too. lol~)
So Ironical!
Offline Belfong
« Reply #3 on: Thu, 03 May 2018, 09:28:50 »
Would like to ask - I am trying to configure the Side LED such that if I press Fn-Scroll Lock once, it turn it on. And if I press Fn-Scroll Lock another time, it turn off. I just wanted a On/Off state. But the current state is that it cycles across four state - Key Lock, Fn, Dedicated, Always Off. Is there no way to make it two state only?
« Reply #4 on: Thu, 03 May 2018, 14:57:44 »
what a ****ing throwback of a thread
i think it's 4 option only, but i'm not super well versed in GON PCBs
Offline Belfong
« Reply #5 on: Sat, 05 May 2018, 20:56:38 »
Anyone with experience in Nerdy GUI? Care to explain what these 4 choices really do?
195124-0
Offline HotRoderX
« Reply #6 on: Sun, 06 May 2018, 03:00:15 »
take this with a grain of salt I am only guessing.. but I think it has to do with the led's activation on certain key's. Like if you enabled the cap lock's key button. Then it would cause the LED on the programmed key to turn off and on depending on the state of the caps lock key.
I have a NerD board and thats what figured it was for but never tested it directly.
Offline Puree
« Reply #7 on: Sun, 06 May 2018, 15:40:48 »
It is for how you want the side led react.
ex : when select -> Keylock to CAPSLOCK, when capslock is on, the side leds are on.
etc...
Offline ideus
  • Björkö.
« Reply #8 on: Sun, 06 May 2018, 17:48:15 »
Side LEDs are the ones installed at the back of the PCB, top and bottom rows. The options allow to select if they will turn off/on along with Caps Lock, FN or if they will be always on.
