Author Topic: [IC] KMAC PCB + PLATE (NerD)  (Read 16909 times)
Offline codyeatworld
« on: Thu, 31 July 2014, 03:34:59 »
GON has asked me run an interest check for a PCB and PLATE combo for KMACs.
It would be ~$105 for a PCB and CNC machined PLATE combo for KMACs.
The PCB will be green.
The PLATE will be universal, you can create any layout that the PCB supports! That means ISO, split backspace, short shifts, 1.5x or 1.25x.
The PLATE is required for the PCB to fit inside a KMAC.
The PLATE will be anodized in Glare or Non-Glare in any color that gon provides, however we all have to agree on ONE color.
We can add another plate color at 40 orders, as in: the first 40 plates could be silver, and the next ~40 (or less) could be pink.
Please reply if your interested. :)
Also, [CTRL]ALT will probably run this if we meet MOQ.
« Last Edit: Sat, 09 August 2014, 22:19:57 by codyeatworld »
Offline Chonzer
Re: [IC] NerD PCB + PLATE for KMACs
« Reply #1 on: Thu, 31 July 2014, 05:04:51 »
OOOOHH. Very interested. Would gon charge extra for hard anodizing for colours like grey or black like he does when he hard anodizes keyboard cases?
I know his grey and silver colours are very nice and would suit most keyboards.
Offline LechnerDE
« Reply #2 on: Thu, 31 July 2014, 05:05:39 »
Does the plate allow switch top removal?
Offline Chonzer
« Reply #3 on: Thu, 31 July 2014, 05:07:08 »
If the plates are like gon's plates that he sells on his website, you won't be able to remove the switch tops.  :(
Re: [IC] NerD PCB + ISO/ANSI PLATE for KMACs
« Reply #4 on: Thu, 31 July 2014, 05:58:16 »
Colors and hard anodizing will not be available for this. You may choose no anodizing so you can do it locally, but the price will remain the same.
The plate will not have notches for easy switch removal.
Also updated OP.
Come on everyone, turn your KMACs into ISO KMACS!
Offline lionblinds
« Reply #5 on: Thu, 31 July 2014, 06:41:25 »
Very interested.
Offline YongJK
« Reply #6 on: Thu, 31 July 2014, 06:52:36 »
This plate supports mounting on top frame, right?
The original KMAC plate supports both bottom and top mounting.
I am in for one, strongly suggest the classic red color, semi-glare would be best.  ;D
Keyboard: PLU ML87 Mx Blue
« Reply #7 on: Thu, 31 July 2014, 07:41:15 »
This plate will only support mounting on the bottom for KMAC 1 and 2 compatibility.
I also think red is good choice.
Offline pasph
« Reply #8 on: Sun, 03 August 2014, 17:24:01 »
Interested
« Reply #9 on: Sun, 03 August 2014, 17:35:04 »
Whoa.. Just wanted to say, this is awesome! I had a KMAC Happy before, but ISO would be legit..
« Reply #10 on: Sun, 03 August 2014, 17:41:21 »
AWESOME idea!
« Reply #11 on: Sat, 09 August 2014, 22:19:26 »
Well the moq for this is a bit higher. I'll look into the details and let everyone know.
Offline aj-kun
Re: [IC] KMAC PCB + PLATE (NerD)
« Reply #12 on: Sun, 10 August 2014, 14:40:22 »
Will this work on a KMAC 2? if so I'm interested.
« Reply #13 on: Sun, 10 August 2014, 14:44:03 »
It will.
Offline lightsout714
« Reply #14 on: Sun, 10 August 2014, 14:49:41 »
Curious why anyone would make a custom plate without the ability to remove switch tops. Is there a negative side of doing that?
« Reply #15 on: Sun, 10 August 2014, 14:55:09 »
Cost of the extra cuts maybe and I've heard a few people say they think the cutouts aren't as stable.
« Reply #16 on: Sun, 10 August 2014, 15:00:25 »
I don't really modify my keyboard after its built. But I think its because you can remove the top housing of the switch when you pull some caps off.
The switches are a really snug with gons design and makes the switch/keyboard feel very solid. I don't have any plates that have the ability to remove the switch tops or I would try to compare it. I wouldn't be surprised if it made no noticeable difference though.
Offline jonathanyu
« Reply #17 on: Sun, 10 August 2014, 16:38:56 »
interested  :) hope the plate could be red or purple
« Reply #18 on: Sun, 10 August 2014, 16:59:02 »
This too!
They will more than likely be red, purple, or silver.
The ideal moq is 50, but if we are close I'm sure we can make it happen.
« Reply #19 on: Sun, 10 August 2014, 20:39:38 »
I see thanks for the info about cut outs.
Offline taylordcraig
« Reply #20 on: Tue, 12 August 2014, 10:26:07 »
But Cody didn't you just sell your Kmac?!
Where do the rest of us get beautiful Kmacs from?  :'(
« Reply #21 on: Tue, 12 August 2014, 10:33:14 »
I did... so I can pay for the Viper. I also really can't stand blacks and didn't want to tear it apart.
You can get a kmac from kbdmod.com :)
« Reply #22 on: Tue, 12 August 2014, 10:41:09 »
Wow somehow I actually didn't know this.
When I have money again I guess I'll be on it. :P
Offline ninjadoc
« Reply #23 on: Tue, 12 August 2014, 10:43:21 »
I would take one set. I'm assuming the KMAC LE has no difference in the plate mounting than the 1 or 2.
Offline Blackehart
« Reply #24 on: Tue, 12 August 2014, 11:30:13 »
Interested in a purple or red if it fits on a LE.
« Reply #25 on: Tue, 12 August 2014, 11:46:31 »
It should work with any kmac, but bottom mount only.
Offline ccc24
  • HHKB , Ergodox
« Reply #26 on: Tue, 12 August 2014, 22:25:03 »
interested....what parts do we have to source ourselves? Do diodes come pre-soldered? And where exactly can we get kmac case?
« Last Edit: Wed, 13 August 2014, 12:49:03 by ccc24 »
Offline yicaoyimu
« Reply #27 on: Mon, 08 September 2014, 16:57:12 »
Any update for this IC? Do we have enough interest?
« Reply #28 on: Mon, 08 September 2014, 17:03:54 »
Yes!
I am working out how to run the GB, but we will need at least 10 orders of the pcb/plate combo.
PCB will be green.
This is a STEAL for kmac owners... :D
« Reply #29 on: Mon, 08 September 2014, 19:40:51 »
I'm in for at least one set.
Offline Soulpyre
« Reply #30 on: Mon, 08 September 2014, 21:41:50 »
Yes, I'm interested as long as the plate will be compatible with a KMAC LE.  :)
TX 1800 - 62g Clears
KMAC LE - GON's Nerd PCB 62g Clears
KPAD - 62g Clears
KBT Race - Browns, Ducky Shine 4 - Browns
Offline esoomenona
  • Gnillort?
« Reply #31 on: Mon, 08 September 2014, 22:14:43 »
AFAIK, the holes for the plate are in different positions from the KMAC 1/LE to the 1.2/2. Are you sure they'll fit all?
Offline cphead
« Reply #32 on: Mon, 08 September 2014, 22:28:30 »
interested if it will fit kmac 2  ;)
Offline GON
  • Skype ID : GonsKeyboardWorks
    • GONsKeyboardWorks
« Reply #33 on: Tue, 09 September 2014, 07:17:32 »
At first, I thought there would be quite many users interested. So I planned to make pairing PolyCarbonate Plate too.
But the qty is so small... that means no room for investing to sample plates and for negotiating the cost with the factory...
In conclusion, I decided to make it a small and limitted GB that PCB only will be offered.
User should re-assemble his KMAC to apply NerD TKL PCB. And have to mod a little bit to his plate(Spacebar stabilizer holes, it's very easy and simple.)
The Spec of NerD for KMAC will be exactly the same as regular NerD TKL Ver2.0.
Even though I have made/assembled/tuned HUNDREDs of keyboards for others, I myself don't have a full-tuned Custom Keyboard now.
So Ironical!
Offline pasph
« Reply #34 on: Tue, 09 September 2014, 15:37:09 »
If we want ISO the mod isn't so little
Offline GON
    • GONsKeyboardWorks
« Reply #35 on: Tue, 09 September 2014, 21:35:39 »
First offer was, "I will let KMAC users use ISO Layouts /w Full Function of NerD Controller". But interested members were only about 10...
So Ironical!
Offline Dreamre
    • kbdlife
« Reply #36 on: Tue, 09 September 2014, 22:05:40 »
I'll be interested for 2 plates and 2 pcbs if this follows through!
Offline combataran
« Reply #37 on: Tue, 09 September 2014, 22:58:47 »
Would I be able to use the PCB with my original KMAC plate? I'd really appreciate the LED options on the Nerd. So much more that what the original PCB had.
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline GON
    • GONsKeyboardWorks
« Reply #38 on: Wed, 10 September 2014, 08:46:46 »
Of course, you can use Full In-Switch Backlight LEDs. ;)
So Ironical!
Offline Dreamre
    • kbdlife
« Reply #39 on: Thu, 11 September 2014, 11:36:02 »
If we can't get plates, I'm down for 2 PCBs :D.
Offline GON
    • GONsKeyboardWorks
« Reply #40 on: Thu, 11 September 2014, 22:00:37 »
I'm considering to make PolyCarbonate /w Diffuse Finish Plate for KMAC1(compatible to KMAC2).
With this plate, you can use all the supported layouts of NerD TKL including ISO. ;)
The Plate will be 2T and CNC-Machined /w Diffuse Finish
Pricing will be about $50~$55 for a Plate.
This plate will maximize On-PCB Backlight LEDs of NerD TKL 2.0 for KMAC.
So Ironical!
Offline ninjadoc
« Reply #41 on: Sun, 14 September 2014, 19:53:20 »
If we can't get plates, I'm down for 2 PCBs :D .
I would buy at least one of both, maybe two to help you make it worth your while.
Has this been posted on Deskthority? Not sure how many over there would buy it but any little bit would help.
Offline GON
    • GONsKeyboardWorks
« Reply #42 on: Sun, 14 September 2014, 21:54:18 »
If you could help, would you please let members of Deskthority know this too? ;)
So Ironical!
Offline DanielT
« Reply #43 on: Sun, 14 September 2014, 23:26:57 »
I could post it on Deskthority, I did it for NerD60 Black PCB
Offline GON
    • GONsKeyboardWorks
« Reply #44 on: Mon, 15 September 2014, 00:33:56 »
Thank you Daniel. ;)
So Ironical!
Offline DanielT
« Reply #45 on: Mon, 15 September 2014, 03:19:14 »
Posted also on Deskthority hope it helps  :thumb:
Offline SaySo
« Reply #46 on: Wed, 17 September 2014, 13:27:35 »
« Last Edit: Tue, 03 July 2018, 12:48:58 by SaySo »
Offline GON
    • GONsKeyboardWorks
« Reply #47 on: Wed, 17 September 2014, 14:50:04 »
Is it just for the Kmac TKL or Kmac mini also ?
Thanks
Only for KMAC TKL. ;)
So Ironical!
Offline SaySo
« Reply #48 on: Wed, 17 September 2014, 14:55:07 »
« Last Edit: Tue, 03 July 2018, 12:49:17 by SaySo »
« Reply #49 on: Wed, 17 September 2014, 16:07:22 »
http://www.gonskeyboardworks.com/15-group-buys
Get on it guys. GB thread will be up soon but this is the order link
