Author Topic: Any possibility of Translucent Frosted White caps?  (Read 6840 times)
Offline PandaSPUR
« on: Thu, 31 July 2014, 13:17:13 »
As per the title, I would like some translucent frosted caps in white. Is that planned and/or possible at all?
Home:
Das Keyboard - MX Browns - Vortex Grey Side-Printed PBT Caps
Work:
KBT Pure - iKBC Aluminum Case - MX Reds
Vortex Poker II - Frosty on Lime Acrylic Case - MX Clears
Offline Oobly
Re: Any possibility of Translucent Frosted White caps?
« Reply #1 on: Sat, 13 September 2014, 14:52:16 »
You could buy some of these and then sand thm with 600 grit sandpaper followed by valve grinding compound: http://keyshop.pimpmykeyboard.com/products/full-keysets/full-clear-translucent-dcs-keycap-sets
Buying more keycaps,
it really hacks my wallet,
but I must have them.
