Author Topic: pbt caps  (Read 2490 times)
Offline osman99
  • follow the smoke to the riff filled land
pbt caps
« on: Thu, 31 July 2014, 18:00:31 »
Do plain black Black keycaps exist in dcs? If they do are there any in pbt, I always hear that I should buy the blanks from ducky but they are no longer made
Re: pbt caps
« Reply #1 on: Thu, 31 July 2014, 18:04:41 »
not sure if serious or trolling....
Offline osman99
Re: pbt caps
« Reply #2 on: Thu, 31 July 2014, 18:25:54 »
I'm serious. unless the answer is obvious and ive been stupid please tell me...
Offline Smasher816
  • HHKB Master
Offline strict
  • TKL Zealot
Re: pbt caps
« Reply #4 on: Thu, 31 July 2014, 18:33:21 »
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=98
Out of stock.
They aren't true black, but there's a seller on eBay with blank dark Navy Blue Leopold PBT keys. In most of the photos I've seen of them, they look black. He's also selling side printed true-black Leopold keys.
« Last Edit: Thu, 31 July 2014, 18:39:07 by strict »
Offline Smasher816
  • HHKB Master
Re: pbt caps
« Reply #5 on: Thu, 31 July 2014, 18:38:22 »
You could also keep an eye out in the classifieds in the future, since I believe Ivan's buy is nearing the end.
Offline osman99
Re: pbt caps
« Reply #6 on: Thu, 31 July 2014, 18:42:23 »
Ok thanks! hope I get lucky with the Group Buy you mentioned, there may be a chance someone plans on reselling!
Offline tbc
Re: pbt caps
« Reply #7 on: Fri, 01 August 2014, 03:31:37 »
you're going to have to scrounge pieces from SP inventory.
Offline Oobly
Re: pbt caps
« Reply #8 on: Fri, 01 August 2014, 06:41:18 »
Ivan's Group Buy is the closest to black PBT in DCS at the moment. They are thick Cherry profile PBT. Someone may transfer their set to you if you ask in the thread.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
