Author Topic: ASCII shower  (Read 5563 times)
Offline vils
ASCII shower
« on: Wed, 03 June 2009, 05:41:58 »
I found this:
The Ascii Key Show'er (AKS) is a freeware program that MSC has created. While the program is running if you type any of the standard key combinations from your keyboard it will display both the ansi and ascii codes for that key. In the example shown here the letter "a" was pressed. You can also show the codes for SHIFTed and control key (CTRL) combinations. This program will NOT show you ALT key codes.
http://www.neophyre.com/msc/ascii3.html
Very helpful when getting accustomed to a KB designated for a different language than yours.
Something I miss in this program is the possibility to view the result for Alt, AltGr and Fn combinations.
Swedish has 29 letters in the alphabet wich messes up things quite a bit when using KBs with few keys such as the HHKB. I have a hard time finding speciality characters such as ' and ;.
Something that should be posted on the wiki is a ascii-chart.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline vils
ASCII shower
« Reply #1 on: Fri, 05 June 2009, 19:53:20 »
The program worked like a charm, no problems with the AltGr characters.
I made a small pic for my bad memory's sake.
This is how a swedish layout HHKB would look like.
Now I have something to glance at when searching for those odd characters...
Can anyone explain why the "¤" is located so central in the layout? Is it so in all ISO KB's?
Offline IBI
ASCII shower
« Reply #2 on: Fri, 05 June 2009, 20:14:44 »
Quote from: vils;94444
Nope, it's not on the UK keyboard at all.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline chimera15
ASCII shower
« Reply #3 on: Thu, 11 June 2009, 22:21:39 »
Thanks,  I've actually been using sharpkeys to do this, to turn the blank key on siig minitouches into the mukan or henkan key on a Japanese board.  It's interesting it doesn't have alt keycodes either.
« Last Edit: Thu, 11 June 2009, 22:25:27 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
