Author Topic: My Kinesis Advantage died, what is the most likely problem? [Solved]  (Read 1156 times)
Offline vatin
Can't believe both my daily driver boards ergodox and kinesis advantage has met with their demise at the same time. Especially the Kinesis which has been serving me for 2 years, today Windows came up with unrecognizable USB warning message. I've tested this with 2 Windows computers both could not recognize my trusty Advantage. The circuit board seems to work fine, the keypad led responds with a press being a tell tale sign. Now I'm back with my pure and Poker II, luckily I haven't sold them. What do you think cause this?
Solution:
Seems to be some loosen up internal connection. Simply opening the board up and squeeze some connectors together seems to fix the issue, at least so far.
« Last Edit: Sun, 10 August 2014, 04:48:02 by vatin »
HHKB Professional Classic
