Author Topic: Pulled out keycap and Stem on my Ducky 9008  (Read 3170 times)
Offline Owntrolf
« on: Sat, 02 August 2014, 16:22:16 »
I need help putting it back in.
Its the one with LEDs and is platemounted
Offline Xenderwind
Re: Pulled out keycap and Stem on my Ducky 9008
« Reply #1 on: Sat, 02 August 2014, 16:25:26 »
Hope you got a soldering iron.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline Owntrolf
« Reply #2 on: Sat, 02 August 2014, 16:27:08 »
Im probably terribad at soldering. Cant I just like jam the stem/keycap back in
Offline Owntrolf
« Reply #3 on: Sat, 02 August 2014, 16:33:50 »
\o/ I got the stem out of the keycap do I have a better chance now at fixing without soldering
Offline Zeal
    • Zeal Generation Inc.
« Reply #4 on: Sat, 02 August 2014, 16:42:02 »
Unfortunately, you'll have to open the case up and de-solder the broken switch. The stock Ducky plate doesn't allow for switch top removal for easy stem swapping. =/
Offline Owntrolf
« Reply #5 on: Sat, 02 August 2014, 17:01:30 »
I guess I just ruined my own day
Offline Owntrolf
« Reply #6 on: Sat, 02 August 2014, 17:33:26 »
Can I just rip out the LED and take off the top
Offline Zeal
« Reply #7 on: Sat, 02 August 2014, 17:46:55 »
You won't be able to remove the switch top regardless, due to the plate blocking the legs from opening.
If you try and rip the top casing off, you'll just end up doing more damage.
« Reply #8 on: Sat, 02 August 2014, 19:07:12 »
"Rip out the LED" :eek:
You cannot rip out an LED without damaging the PCB.
The LED at least willr rquire resoldering.
To get the clips in properly to hold the top of the switch on you will need to remove the switch, which will also require desoldering.
Offline Owntrolf
« Reply #9 on: Sat, 02 August 2014, 19:45:23 »
Ill probably wait next week to get a real soldering iron because apparently soldering guns get too hot. I just assume I'm bad at soldering  because it never sticks and the iron gets so hot that its starts smoking because I'm using a soldering gun
Its something that looks like this
http://www.canadiantire.ca/en/pdp/mastercraft-30w-pistol-iron-0586310p.html#.U92HWWM-avQ
« Last Edit: Sat, 02 August 2014, 19:52:35 by Owntrolf »
Offline Zeal
« Reply #10 on: Sun, 03 August 2014, 01:34:26 »
Yeah, soldering guns aren't meant for hobbyist precision work.  :p
Offline Owntrolf
« Reply #11 on: Sun, 03 August 2014, 17:43:47 »
So all I have to do is open up the keyboard and desolder the switch and open it up and put back the stem in it?
or do I have to buy a new switch and solder it in
« Reply #12 on: Sun, 03 August 2014, 17:48:22 »
Depends on whether the switch is damaged or not.
If you're not sure, maybe some kind soul here would offer you a replacement switch if you ask nicely :)
