Author Topic: Steelseries 6GV2 Spacebar Help  (Read 2509 times)
Offline ajdajd
« on: Sat, 02 August 2014, 17:30:26 »
Hey guys, I'm new around here and am hoping to buy my first set of caps soon. Problem is, I have the dreaded Steelseries 6gv2 and am realizing how much of a pain it is to customize it. I've so far tracked down all the caps i need, except the spacebar.
Can anybody tell me where I can find a blank white spacebar to fit this board?
Any leads are appreciated, thanks!
Offline Lord of Narwhals
  • You can call me NaLo
    • A selection of posts chosen with care, prior to remembering your indifference to them.
Re: Steelseries 6GV2 Spacebar Help
« Reply #1 on: Sat, 02 August 2014, 17:34:20 »
Where did you find a fitting enter key?
In the end.. the keyboard's most grand form of existence is as an ethereal bridge between man and machine..    Each depression of the keys, evanescent.. Our transitory thoughts crashing into the web, carving canyons through the internet wasteland such that life may once again flourish..
HHKB Pro 2 Poker II [MX Red]
Offline ajdajd
« Reply #2 on: Sat, 02 August 2014, 18:05:02 »
I didn't find the big one, plan to use a regular rectangular key probably leaving a hole above it
Offline ComradeSniper
  • HHKB Pro
« Reply #3 on: Sat, 02 August 2014, 18:30:49 »
If at all possible you should probably just get a different keyboard. The Rosewill RK9000 is cheap and has a standard ANSI layout.
Offline ajdajd
« Reply #4 on: Sat, 02 August 2014, 19:51:56 »
This is an option I've considered, but I'd prefer not to if possible..
« Last Edit: Sat, 02 August 2014, 21:16:32 by ajdajd »
Offline GSimon
« Reply #5 on: Sun, 03 August 2014, 18:24:15 »
Needs a universal spacebar, one with 6 stems
The one from this set would work: http://www.geekkeys.com/white-top-printed-pbt-104-keyset/ (see the last pic in the gallery)
Offline BamBooBam
  • Yammy Caps
« Reply #6 on: Sun, 03 August 2014, 23:38:17 »
Is the keycap the same as the one on the 7G? I've seen 7G spacebars on Taobao
Geekhack an alternation of money sink.
