Author Topic: Plastic Feet Underneath the Mouse, What are they Called?  (Read 16332 times)
Offline TotalChaos
  • Indy Game Coder
« on: Sun, 03 August 2014, 04:51:47 »
I bought a mouse that grinds and drags on the table.  Its tiny little mouse feet are too small or too shallow or just made from the wrong material or the bottom of the mouse is shaped a bit wrong so its belly drags.  I donno which.
Can I buy some new thingamajigs to glue under my mouse and save it from a life of living in the closet and never having anyone to play with?
What are the slippery plastic foot slider thingies made out of ?  POM?  Teflon?  Other?
Offline epzy
  • HHKB Fiend
  • ded
Re: Plastic Feet Underneath the Mouse, What are they Called?
« Reply #1 on: Sun, 03 August 2014, 05:31:20 »
I think they are called "mouse skates".
Offline munch
« Reply #2 on: Sun, 03 August 2014, 06:48:01 »
most aftermarket better quality ones are made from teflon, and they tend to be called skates as epzy says. or simply mouse feet.
hyperglide, puretrak and corepad make a lot of these for different mice.
Offline Coreda
« Reply #3 on: Sun, 03 August 2014, 06:57:13 »
"Toes", wearing tiny flip-flops.
Offline MJ45
  • HHKB Pro
« Reply #4 on: Sun, 03 August 2014, 07:06:49 »
Sounds like you need a mouse pad.
Offline ideus
  • Björkö.
« Reply #5 on: Sun, 03 August 2014, 08:27:31 »
Here is a link to a search in ebay for mouse feet.
Offline iLLucionist
  • Topre is Love.
« Reply #6 on: Sun, 03 August 2014, 14:48:10 »
Mionix calls them 'glides', see here:
http://mionix.net/accessories/
Offline TotalChaos
  • Indy Game Coder
« Reply #7 on: Sun, 03 August 2014, 16:00:47 »
I always use mousepads.  I bought a bunch of mice and this one mouse, the "Manhattan Mouse" is defective.
@Everyone else:
Thanx guyz!  Now that I know the topsecret lingo of the Brotherhood of Competitive Mouse Scientists, I can now find whatever I need!
Offline GL1TCH3D
« Reply #8 on: Wed, 20 August 2014, 22:52:42 »
I called them glide pads o.o
« Reply #9 on: Wed, 20 August 2014, 23:13:17 »
I had no idea you can get these separately!
One of mine invariably falls off, so I take the other one off (most of my mouses seem to have two small ones either side, then a long curved one at the other end).
I tried taking all 3 off, but the mouse completely stopped working - I guess it was too close to the desk surface or something?
Offline GL1TCH3D
« Reply #10 on: Wed, 20 August 2014, 23:31:51 »
Some mice are more sensitive to others in change of distance of the sensor to the mousepad =(
Offline mauri
« Reply #11 on: Thu, 21 August 2014, 14:30:30 »
"feetsies"
I AM BABAR KING OF THE ELEPHANTS
Offline divito
« Reply #12 on: Fri, 22 August 2014, 16:17:20 »
This.
And, many options here.
Given my obsession with my IE 3.0, along with having spare mice, I also bought a 40-pack of extra mouse skates for them as well. And as you can see by the link above, there are many for different mice.
« Last Edit: Fri, 22 August 2014, 16:19:12 by divito »
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
