Author Topic: possibly broken Omnikey 101, bidding starts $25 shipped  (Read 2267 times)
Offline jacobolus
« on: Sun, 03 August 2014, 16:21:14 »
http://www.ebay.com/itm/390901872812
The seller says they can’t test it. My guess is that it still works, but take your chances; it could always be fixed up with a Teensy. For Alps fans, this is a very solid keyboard to swap different switches and keycaps into. Someone had one at Keycon and it was quite nice to type on.
« Last Edit: Sun, 03 August 2014, 16:23:27 by jacobolus »
Re: possibly broken Omnikey 101, bidding starts $25 shipped
« Reply #1 on: Sun, 03 August 2014, 16:43:41 »
This is the bomb. If you are serious about Alps switches, this is the chassis that you want to put your switches into.
These old Northgates are incredibly well-built, even featuring a heavy baked-enamel bottom pan.
Approximately 1-2 years ago, I bought 3 of these in the $60-100 range. Only 1 was significantly nicer than this one, the other 2 displaying varying degrees of yellowing and keycap shininess.
They do break, (and I have a broken one that I will probably sell in the $25-30 + shipping range when I find all the parts) but are sturdy old stock.
*It was my fault, I messed up a few of the pads removing the original switches (white Alps, nice when new but bad when dirty). My soldering iron was dying and I did not realize it, now I realize that it was probably too cold and when I was trying to pry up bent-over pins they were still stuck in the original solder!
- D Trump 2026-10-24
Offline False_Dmitry_II
« Reply #2 on: Mon, 04 August 2014, 00:29:59 »
I like how the 'A' is somehow more yellowed than the rest.
« Reply #3 on: Mon, 04 August 2014, 07:28:44 »
I have gotten these where some 2-20 keys were dramatically more yellowed than the rest, and it had nothing to do with wear.
Offline jacobolus
Re: possibly broken Omnikey 101, bidding starts $30 shipped
« Reply #4 on: Sat, 09 August 2014, 04:17:40 »
It’s back:
http://www.ebay.com/itm/251612156009
Now bidding starts at $30 shipped. Seller says some keys work intermittently, which probably means some of the switches got very dirty inside and/or mistreated.
I’d recommend this as a fixer-upper board. Put new switches and keycaps in (and maybe paint or retrobright the case), and you have pretty much the best full-size ANSI Alps board to be found.
My guess is that the PCB and controller are fine. (But if they’re not, you could always put a Teensy in.)
« Reply #5 on: Mon, 08 September 2014, 02:23:55 »
That went low.
