Author Topic: Feet up or feet down.  (Read 11629 times)
Re: Feet up or feet down.
« Reply #50 on: Thu, 07 August 2014, 23:04:39 »
Metal cases don't have feet  ;)
But in terms of having feet, I like 'em down and flat.
Your metal cases are lacking, then.
Offline quake4mhg
« Reply #51 on: Thu, 07 August 2014, 23:47:24 »
Feet up. I need the angle.
Offline hasu
  • @tmk
« Reply #52 on: Fri, 08 August 2014, 03:09:52 »
Never used feet. I usually remove them from my keyboads.
This was totally confusing to me before E TwentyNine clarified. Glad to know I was not alone :D
« Reply #53 on: Fri, 08 August 2014, 06:29:56 »
I like my keyboard's feet how I like women's feet: high up and wide apart
So you have a full size keyboard?
Offline G-Dubs
« Reply #54 on: Fri, 08 August 2014, 08:41:30 »
Another one for no feet. I have this weird habit of leaning in when I type that makes it uncomfortable to use the angle that the feet offer. I am also now aware of something I didn't think about before and now I wonder if anyone else notices. :'(
 Instead of being productive at work today, I am probably just going to practice not shifting around so much when I type.
KUL ES-87 MX Red || KBP V60 Matias Linear || KBP V60 Matias Quiet Click || Varmilo VA87MR Gateron Black || Leopold FC210P MX Black
Offline Daspartic
  • IBM is love IBM is life
« Reply #55 on: Fri, 08 August 2014, 08:58:32 »
For me it depends on whether the keyboard is in my tray or on top of the desk.  No feet if its in the tray and feet out if it's on top of the desk.  Basically, whichever makes my wrists straighter.
IBM Displaywriter (82 key) | IBM Model F 4704 (107 key) |  IBM Model F AT x3 | IBM Model F XT | IBM Model F 3104 x2 | IBM 6112884 (Green Tee mount Alps) | Realforce 87u (55g) | IBM Model M 1390131 x2 | IBM Model M (1391401 '88) | Leopold FC500R (MX Browns) | Wang (725-5971) (Salmon Alps) | Acer 6011 (SKCM Blue Alps) | White Fox (65 g Zealios) | XMIT keyboard (Hall Effect)
Offline Grim Fandango
« Reply #56 on: Fri, 08 August 2014, 09:11:19 »
I do not have a tray, but my wrists are straighter without feet regardless of whether I have the keyboard in a high or a low position.
Offline Hitcha
« Reply #57 on: Sat, 09 August 2014, 20:17:58 »
Feet down. I don't see the point in elevation.
Full Metal Poker II - http://imgur.com/a/xK2Uv
Offline ckar
« Reply #58 on: Sun, 10 August 2014, 09:08:36 »
Flat keyboards are best. It is the way it is suppose to be for comfort.
Companies should not be making keyboards with feet. They serve no purpose.
« Last Edit: Sun, 10 August 2014, 12:11:19 by ckar »
Offline tribade
« Reply #59 on: Sun, 10 August 2014, 11:52:17 »
I prefer keeping the feet in.  If they're flipped out it tends to feel bad on my wrists after a few minutes.
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #60 on: Sun, 10 August 2014, 15:27:30 »
I like to tickle my feet up and down every now and then.
Offline aref
« Reply #61 on: Mon, 11 August 2014, 17:12:17 »
I extend the feet on my keyboards. I prefer the feel of all my keyboards at a slight angle.
« Last Edit: Tue, 12 August 2014, 10:51:56 by aref »
Offline rush340
« Reply #62 on: Mon, 11 August 2014, 20:00:35 »
Feet out.  Unless it's a keyboard with short feet and long feet, then I use the shorties.
Offline Rafen
« Reply #63 on: Mon, 11 August 2014, 20:05:34 »
I always type with my feet down. This give me a better angle for my wrists and then I can spend more time on my computer gaming or typing. Tried using them down when I first started and my wrists would hurt  a lot after longer gaming sessions or typing on the computer.
