Author Topic: Hi there!  (Read 2543 times)
Offline JYJelly
Hi there!
« on: Tue, 05 August 2014, 18:19:11 »
Hi guys!
Glad to join the community. I decided to be more active after taking part in Ivan's group buy for GMK Dolch. I started looking at the novelty keycaps (Click clacks, BroBots and Gasmask) and I can see the appeal...must resist...
Re: Hi there!
« Reply #1 on: Tue, 05 August 2014, 18:58:28 »
Welcome to Geekhack!
Resistance is futile!
Offline Grim Fandango
Re: Hi there!
« Reply #2 on: Tue, 05 August 2014, 19:03:30 »
Welcome!
If I can give a suggestion. Try to avoid spending a lot of money on novelty keycaps and spend them on keyboards instead  :thumb:
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Hi there!
« Reply #3 on: Tue, 05 August 2014, 20:01:52 »
Welcome!
Wish someone had told me this when I joined.
Seriously, more boards, because caps are useless without boards to put them on.
Offline Belfong
Re: Hi there!
« Reply #4 on: Tue, 05 August 2014, 20:18:25 »
I see it differently. Boards takes up a lot of storage space and creates questions from significant others. Caps is subtle, beautiful and takes up less space. Go for caps I say!
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
Re: Hi there!
« Reply #5 on: Tue, 05 August 2014, 20:48:26 »
Don't do it!  Get one cap, and there will be no end to it.  Don't listen to Belfong's syrupy sweet words.
Offline Belfong
Re: Hi there!
« Reply #6 on: Tue, 05 August 2014, 20:49:30 »
So say we all :)
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
Re: Hi there!
« Reply #7 on: Tue, 05 August 2014, 21:02:38 »
Caps or boards...
Welcome to the site, Jelly.
Offline Belfong
Re: Hi there!
« Reply #8 on: Tue, 05 August 2014, 21:59:59 »
Caps or boards...
YOU WIN!
