Author Topic: Any info about this Viglen ?  (Read 6014 times)
Offline Lenny_Nero
« on: Thu, 04 June 2009, 21:21:29 »
I have been using this Viglen for quite a few years and have yet to see another with the close set (but standard layout) keys, any help.
It has white Alps which I think are the bigfoot type, its a while since I pulled the one that fly's apart when doing so and got a good look inside as I rebuilt it.
Model Number DFK2020UKF104
Filco Zero, Viglen DFK 2020UKF104, DTK SPK-102a, Panasonic Biz 500
Ducky 1087,  Chicony KB-5191, G80-1856HQMGB Cherry G80-1000HFD and others
 G80-11908HRMIT, Tipro MID-KM128a, Access AKEOXPB312/2 (20x7), Access AKEOCTI635/1(15x6)
Offline watduzhkstand4
« Reply #1 on: Thu, 04 June 2009, 23:14:14 »
that looks like it's a tight fit with the numpad
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline chimera15
« Reply #2 on: Fri, 05 June 2009, 02:58:42 »
Pretty cool.  Looks like it has the same size enter and secondary keys as a siig minitouch, but full size. huh.  Also has a place for a buzzer and other stuff, really cool.
« Last Edit: Fri, 05 June 2009, 03:06:29 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline lowpoly
« Reply #3 on: Fri, 05 June 2009, 04:56:36 »
Acer/Viglen 'boards have used mechanical on membrane switches in the past that looked like Alps switches but weren't:
http://geekhack.org/showwiki.php?t=4411
Yours look different though. Maybe open the board and see what you find (pcb or membrane).
Offline chimera15
« Reply #4 on: Fri, 05 June 2009, 06:07:03 »
Quote from: lowpoly;94307
Acers have the same stem, but the body of the switch is completely different, you can tell what they are right off.  That photo is pretty dim, but looks like alps as far as I can see...  Of course the only way to be sure is to pull one apart, which he should do to see what kind of alps switch it is anyway.
Alps boards:
Offline Lenny_Nero
« Reply #5 on: Mon, 08 June 2009, 07:59:32 »
Cheers for all the swift replies, while reading and switching between computers I lost my monitor :(  It took me two day looking round the loft to find this one, but dropping down to 1600 x 1200 is hard work. But as I am one of the few that still use CRT I hope to get something from ebay soon.
Thanks for all of the info, IIRC there is a printed board not membrane, the switches have ALPS and 24b and checking with some sites they are this type...alps bigfoot.
It needs more of a clean so I will get a few more photos when its next open, I also have some other old mechanical boards some DTK's which I think are just rubber dome, a very large IBM style board that is branded Panasonic which is either buckling-spring or Alps.
I am also looking for a new board with Cherry blues for work, if I can get away with them.
Thanks for all the help.
Offline IBI
« Reply #6 on: Mon, 08 June 2009, 09:41:26 »
There's a Viglen board that's just come up on ebay UK with those types of switches: http://geekhack.org/showthread.php?t=6167
Yours looks like a nice keyboard, I'd be interested to know how long it is.
EDIT: It looks like the model is DFK2020 and an updated version was shown by Datacomp Electronics at Computex 2008: http://www.iqmore.idv.tw/archives/194/1
« Last Edit: Mon, 08 June 2009, 10:01:45 by IBI »
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline Lenny_Nero
« Reply #7 on: Mon, 08 June 2009, 15:00:37 »
That DFK2020 does look to have the same Key layout the first one I have seen, but it is just the upgraded model from what I can see as this also has part of the serial number 2020 in it, and can also be seen on the PCB.
As for the size 16 and a half inches or 42 cm/422 mm length by 6 inches, 153 mm.
Offline IBI
« Reply #8 on: Mon, 13 July 2009, 15:19:10 »
One of these has just come up on ebay UK here.
Offline Lenny_Nero
« Reply #9 on: Fri, 07 August 2009, 14:35:57 »
Quote from: IBI;102406
Gutted, that I did not see this before, I would jump at the chance to get another  :-\
Even though I have quite a few ALPS boards this is the one I like the best and keep going back to.
