Author Topic: Kmac Screw  (Read 1390 times)
Offline Blackehart
Kmac Screw
« on: Wed, 06 August 2014, 01:51:23 »
Does anyone know what size the kmac case screws are?
I wanted to add  alil more of the rubber shelf liner to quiet it up a tad. a couple of the hex heads stripped...now i have a couple of hex keys sitting on it with some jb weld....
I would like to replace the screws with some that are a lil more...resilient...
Your help is appreciated and thanks in advance!
-Blacke
Re: Kmac Screw
« Reply #1 on: Wed, 06 August 2014, 02:04:57 »
I believe they are pan-head M3.5, but I don't have a KMAC anymore to check.
edit: I was only able to find this resource, claiming M3 and M2
http://geekhack.org/index.php?topic=56065.0
« Last Edit: Wed, 06 August 2014, 02:09:14 by dorkvader »
Offline Blackehart
Re: Kmac Screw
« Reply #2 on: Wed, 06 August 2014, 02:10:55 »
Thanks!!
