Author Topic: Having trouble adding Print Screen to ErgoDox layout..  (Read 3558 times)
Offline GSimon
« on: Thu, 07 August 2014, 20:54:53 »
Everytime I press the Print Screen button on my keyboard (TKL) it doesn't register the keystroke, it simply takes a screen cap.
How do others add it to their ErgoDox layout??
Also, could someone just add it for me incase I can't figure it out? I want to replace the LCtrl on the Thumb Cluster with Print Screen (Layers 0 and 1) https://www.massdrop.com/ext/ergodox/?referer=AKUB8D&hash=cc0bc64eeb2bb5c89dddce978458f404
Would be nice to know how it's done though, might want to change it again later.
Re: Having trouble adding Print Screen to ErgoDox layout..
« Reply #1 on: Thu, 07 August 2014, 21:17:10 »
Same thing happens to me o-O weird
Offline GSimon
« Reply #2 on: Thu, 07 August 2014, 21:20:38 »
Offline Igthorn
« Reply #3 on: Thu, 07 August 2014, 21:37:45 »
Use right-click to select it from the menu.  Right-click > misc > KEY_PrintScreen
Offline GSimon
« Reply #4 on: Thu, 07 August 2014, 21:41:52 »
Ohh...that was painfully obvious, in a way, I tried right-clicking before after selecting the key and it doesn't work if the key is selected. Thanks sir.
« Last Edit: Thu, 07 August 2014, 21:43:28 by GSimon »
