Author Topic: keypads look inteaesting but need more info  (Read 3629 times)
Offline berserkfan
« on: Fri, 08 August 2014, 14:07:36 »
Re: keypads look inteaesting but need more info
« Reply #1 on: Fri, 08 August 2014, 14:11:18 »
I've got a few of these and another member used one to make a switch tester once.The switches in these aren't good for much of anything but the plates nice to have.
« Reply #2 on: Fri, 08 August 2014, 14:12:00 »
Yup, I have a switch tester made from one of these. Think I bought it off Spamray.
Offline 0100010
  • Not Sure
« Reply #3 on: Mon, 11 August 2014, 20:41:13 »
Plate cutouts will mount MX?
« Reply #4 on: Mon, 11 August 2014, 21:02:29 »
Offline Oobly
« Reply #5 on: Thu, 14 August 2014, 05:30:39 »
Hmmm... 2 of them could be used to make a split matrix keyboard. Not that I like matrix layout, but...
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline berserkfan
« Reply #6 on: Thu, 18 September 2014, 12:28:00 »
Has anyone actually incorporated these into a real working keyboard?
« Reply #7 on: Thu, 18 September 2014, 15:05:34 »
Someone (dustin?) pointed me at something that looked very much like these, so I bought two (4x4).
The switches in mine will accept MX keycaps, although they feel just very slightly tighter than most other MX stems.
« Reply #8 on: Thu, 18 September 2014, 15:09:19 »
Yep I have one for holding MX switches. Switch tester. Got the idea from cptbadass!
« Reply #9 on: Thu, 18 September 2014, 17:42:25 »
I just put my keycaps on the switches that it came with.
Offline berserkfan
« Reply #10 on: Thu, 18 September 2014, 22:43:22 »
holding MX switches or MX keycaps? I thought these weren't cherry MX switches.
« Reply #11 on: Thu, 18 September 2014, 22:45:07 »
These are not Cherry MX switches, but they (mine, at least) have MX-compatible stems.
Mostly.
The standard MX keycaps are a slightly tighter fit than genuine MX switches, but go on and come off ok.
Pic of mine with the switches it came with and some MX keycaps installed: http://geekhack.org/index.php?topic=48073.msg1179499#msg1179499
Pic of dustin's with MX switches replacing the original switches: http://geekhack.org/index.php?topic=48073.msg1369860#msg1369860
« Last Edit: Thu, 18 September 2014, 22:47:34 by rowdy »
