Author Topic: Can I have just red or blue LED? Ducky Mini  (Read 1319 times)
Offline Aidenknives
« on: Fri, 08 August 2014, 14:22:29 »
So with the new Ducky Mini's coming out sporting "Dual LED's" it seems like the blue/red is mixing in all the photos to make pink/purple colors. Will it be possible to just switch back and forth between red and blue?
Offline jameslr
Re: Can I have just red or blue LED? Ducky Mini
« Reply #1 on: Fri, 08 August 2014, 19:37:29 »
Supposedly since you can dim one or the other to mix colors you could turn the red completely off and leave the blue on - vice versa.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
