Author Topic: hello!  (Read 2276 times)
Offline ahshwebah
hello!
« on: Fri, 08 August 2014, 18:34:07 »
i've had a mechanical keyboard in my rotation for years now, first the CM Quickfire and now the Razer Blackwidow. looking to get away from mx blues and build a collection of keycaps. great to have found this site.  :cool:
Offline Grim Fandango
Re: hello!
« Reply #1 on: Fri, 08 August 2014, 18:37:04 »
Welcome ! If those are your objectives, no doubt you are in the right place.
Re: hello!
« Reply #2 on: Fri, 08 August 2014, 21:56:29 »
Welcome to Geekhack!
Any idea what you want to move towards, if you are getting away from MX blues?  I went to blacks, and reds.  And greens.  And buckling spring.  And Topre.  Too many choices!
Offline ahshwebah
Re: hello!
« Reply #3 on: Fri, 08 August 2014, 22:00:35 »
thanks!
i've messed with reds, but never had a chance to fully test them. they feel fine, but not sure about how many typos i'd get out of them. since i'm so used to blues, i think maybe transitioning to clears or brown might be my best bet, but i definitely want something quieter.
Re: hello!
« Reply #4 on: Fri, 08 August 2014, 22:07:22 »
thanks!
Heh yeah, blues can be a bit clicky!
There is a lot of people liking clears - if you can find a keyboard with clears!
However browns are probably closer to reds in that red and brown are both fairly light switches.  Clears are somewhat heavier.
Offline ahshwebah
Re: hello!
« Reply #5 on: Fri, 08 August 2014, 22:16:16 »
thanks!
i've found one, the WASD Code keyboard, in clears. i'm going to try and borrow a friend's board with Reds before i completely rule them out just to be sure.
