Author Topic: [IC] Granite Round 2  (Read 365086 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: [IC] Granite Round 2
« Reply #400 on: Tue, 19 August 2014, 13:32:53 »
this is the only update so far
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #401 on: Tue, 19 August 2014, 13:47:33 »
I have some questions.
What does the DT stand for on the neerdom key?
What does the U stand for in the  1u, 1.25 u, 1,75u and so on
What is the Mono Legend for?
What is the difference between standard and pro modifiers?
What is Extra homing for?
Is the Icon modifiers your design? is there any logic? they look great! :)
Everything looks awesome! just new on the keycaps world, Sorry for extremely stupid questions ;)
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #402 on: Tue, 19 August 2014, 13:52:04 »
In for the new mono legend.
Need that gde \ badly.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline Data
« Reply #403 on: Tue, 19 August 2014, 13:54:11 »
The u is for units.  It indicates the size of the key cap.
The typical key cap is 1u.  These are your alpha keys.  Other sizes are usually a factor of 1u.  So a Win/OS key in a Tenkeyless (TKL) layout is said to be 1.5u, or 1.5x the horizontal length of an alpha key.  The spacebar is - I believe - 6.25u.  This is a rough standard used in the keyboard enthusiast community.  You'll notice some keyboards (especially something like the MS Natural Keyboard line) don't adhere to any particular standard.
Edit: For your other questions...
DT is Deskthority, a web site similar to geekhack (/ducks).  http://deskthority.net/
Monolegend is just for people who don't want top & bottom legends printed on their keys.  They know that the $ sign is on the #4 key, so they don't need to see a "4" and a "$" printed on the same key.  It's a personal preference.
Pro modifiers are for people with special boards like HHKB and Pure -- I don't have sufficient knowledge of these to give you an accurate list.
Extra home row is for people who use a non-QWERTY alpha key layout like Dvorak.  The F and J keys are typically made with a homing "bump" or a deep dish -- the key cap is different so your fingers can find the home row easier.  So guys with a Dvorak layout need different homing keys because F and J are not on their home row!
I can't really answer your last question.   ;)
« Last Edit: Tue, 19 August 2014, 14:05:58 by Data »
Offline Vitaly
« Reply #404 on: Tue, 19 August 2014, 14:06:25 »
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #405 on: Tue, 19 August 2014, 14:16:48 »
Thank you so much! Then i know that i wont get Pro modifiers, Mono legend,Extra homing kits and spacebar kit! :)
Offline DanielT
« Reply #406 on: Tue, 19 August 2014, 14:24:22 »
Actualy Pro Mods is the next generation of Tsangan in GH language :D but is more complex and contains caps to cover custom keyboards. Very nice kit a must have I would say if you like custom boards.
  • Keyboard Hipstar
« Reply #407 on: Tue, 19 August 2014, 14:30:59 »
Always get the Pro Mods.
You'll kick yourself if you want migrate the set to another board, only to find that you don't have all the mods necessary.
Offline Project22a
« Reply #408 on: Tue, 19 August 2014, 14:33:39 »
Pro mods helps to cover non-standard and custom layouts. In my particular case I have my caps lock binded as ctrl, so it would cover that. And I also have a separate numpad that contains tab, backspace, and function keys, so it would help to cover that as well.
Offline Data
« Reply #409 on: Tue, 19 August 2014, 15:10:44 »
Thanks, I may have oversimplified it a little.
I guess this applies to Mono Legends too.  If you want to be fancy (and have a fancy keyboard) you could have an & key that was separate from your 7 key in the number row, etc.
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #410 on: Tue, 19 August 2014, 15:29:11 »
so Normal and Pro mods is recommended to get then? :)
Offline Pep
« Reply #411 on: Tue, 19 August 2014, 15:45:10 »
Halp!
My numpad has esc, tab, backspace, and fn.  The Icon Pro Modifiers Set would cover all except the esc.
Also thanks for the responses to my other questions everyone.
Offline Project22a
« Reply #412 on: Tue, 19 August 2014, 15:50:27 »
Assuming you're also picking up a common kit, you could substitute one of the GH/reddit/DT keys. That would probably be the most cost effective solution.
Offline Pep
« Reply #413 on: Tue, 19 August 2014, 16:04:38 »
Yeah I will definitely pick up the common kit as well.  I suppose I could use one of the community keys, I just really like the esc icon.  I might want to get the Multimedia set, and then I could use the power icon as well, but I was trying to go no RGB.
Edit: nevermind I just realized that the Mono Legends Set has a grey ~ key, and I was going to get that set anyways for replacing the top row on my 60% with just symbols (!@# etc), so the esc icon can go to the numpad.  Brilliant!
« Last Edit: Tue, 19 August 2014, 16:21:09 by Pep »
Offline ddot
  • Master of Suspense
« Reply #414 on: Tue, 19 August 2014, 16:27:17 »
A bunch of the Icon Modifiers are specified in ISO 9995-7.
http://commons.wikimedia.org/wiki/Category:ISO_9995-7_symbols
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #415 on: Tue, 19 August 2014, 17:00:09 »
I believe the only not standard is pause/break
Offline vimx
  • ENHANCE
« Reply #416 on: Tue, 19 August 2014, 19:09:33 »
Invaders, hearts and Nerv!?  This may be my first keycap set.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #417 on: Tue, 19 August 2014, 19:40:59 »
Itching for this to hit Massdrop!
I tip my hat to you, Matt3o. I think I would have lost my mind trying to cater to so many small requests on what is already a niche product  :)
Offline jessa
« Reply #418 on: Tue, 19 August 2014, 20:20:08 »
If you're referring to the mockup from Keyzus, that's just a wish from another user (who has been hurling abuse at my inbox for having a different opinion), not the real deal.
The most recent version of the gamer kit from Matt3o is at http://geekhack.org/index.php?topic=61612.msg1439994#msg1439994 and it does have an invader and a heart but no Nerv (and is better than Keysuz suggestion imho).
I believe the Nerv cap was part of R1 though so you might be able to get it from the classifieds.
Offline taylordcraig
« Reply #419 on: Wed, 20 August 2014, 00:23:56 »
Yeah. I think we need a rule that people can't make their own ****ty mockups that look almost identical to the actual ones, it made this thread very confusing. [I'm following it super close but I bet some people aren't and are confused.]
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #420 on: Wed, 20 August 2014, 01:43:09 »
SP won't print android logo, we have to remove that.
  • Keyboard Hipstar
« Reply #421 on: Wed, 20 August 2014, 01:47:33 »
Replace it with 1u and 1.25u Xorg keys?
Offline DanielT
« Reply #422 on: Wed, 20 August 2014, 01:52:10 »
pfff :( I'm not a big fan of android, but I liked the logo. We need a new OS key now, maybe a Commodore ?
This logo would look wicked :D
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #423 on: Wed, 20 August 2014, 01:55:06 »
hold on I double checked and SP is wrong!
the android logo can be used! it's under creative commons!
Offline DanielT
« Reply #424 on: Wed, 20 August 2014, 02:00:47 »
I knew the same, glad they were wrong :d
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #425 on: Wed, 20 August 2014, 02:35:59 »
Omg, you made my heart stop for a moment there ;)
Offline vimx
  • ENHANCE
« Reply #426 on: Wed, 20 August 2014, 07:12:53 »
Argh.  What a let down. Per your suggestion, I'll cruise the classifieds.  Curses on that mockup!
Offline osi
« Reply #427 on: Wed, 20 August 2014, 07:15:47 »
Is there a perma link that has the latest mockups available?
Offline DanielT
« Reply #428 on: Wed, 20 August 2014, 07:18:20 »
@tyvar1: your avatar is so cool, I just have to say it. It's the first time I see a clown face so expressive
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #430 on: Wed, 20 August 2014, 10:05:38 »
Thank you man! :)here is the picture: https://www.flickr.com/photos/cristinaoterophoto/6674934961/
The girls name is Cristina Otero, more pictures here: https://www.flickr.com/photos/cristinaoterophoto/
« Last Edit: Wed, 20 August 2014, 10:14:35 by tyvar1 »
Offline DanielT
« Reply #431 on: Wed, 20 August 2014, 10:48:18 »
Thanks for the link :) Amazing, in all the photos the eyes are so expressive, love it :)
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #432 on: Wed, 20 August 2014, 11:23:38 »
Yeah I really like her eyes! The cool thing is that she is only 18 years old. She is a really good photographer!
Sorry for off topic.
Offline SL89
« Reply #433 on: Wed, 20 August 2014, 13:34:38 »
Did they say why?
the Android robot is freely availible from what i read
 https://developer.android.com/distribute/tools/promote/brand.html
Offline LechnerDE
« Reply #434 on: Wed, 20 August 2014, 13:51:44 »
Did they say why?
Read a little further...
Offline ideus
  • Björkö.
« Reply #435 on: Wed, 20 August 2014, 18:52:37 »
I did not find a second 2.25u shift key in any of the sets. It was intentional?
Offline barihunk
« Reply #436 on: Wed, 20 August 2014, 23:26:32 »
Just wanted to make a useless post expressing my excitement at R2, and thanking Matt3o for his patience and hard work. I have absolutely no need for any more keycaps (do any of us really) but I'm gonna get me some R2.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #437 on: Thu, 21 August 2014, 02:30:47 »
still waiting for prices, hope to get them today.
Offline vimx
  • ENHANCE
« Reply #438 on: Thu, 21 August 2014, 08:13:08 »
Am I correct in assuming a Poker 2 will be covered by base + modifiers?  And this set does have available a red  esc, blue return, and invader? If so, I'm pumped.
Offline DanielT
« Reply #439 on: Thu, 21 August 2014, 08:33:19 »
Base + mods will cover Poker 2. For red Esc and Enter I think you will need and extra kit.
Offline SL89
« Reply #440 on: Thu, 21 August 2014, 08:39:16 »
Thanks, i didn't see that update on Tapatalk :/
Offline vimx
  • ENHANCE
« Reply #441 on: Thu, 21 August 2014, 09:19:03 »
Thanks, Dan.  Bring on the pricing!
Offline Skuloth
« Reply #442 on: Thu, 21 August 2014, 12:08:39 »
I would love a blue 1.75 enter for a JD40
Planck w/ Zealios
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #443 on: Thu, 21 August 2014, 12:13:29 »
we've got pricing. we should go live shortly!
Offline DanielT
« Reply #444 on: Thu, 21 August 2014, 12:14:07 »
Yesssss! :)
Offline xybre
  • clickityclackclickityclack
    • Music and Stuff
« Reply #445 on: Thu, 21 August 2014, 12:24:21 »
 :thumb:
GON NerD 60 & Duck Eagle & Unicomp Ultra Classic & Das Keyboard Ultimate
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #446 on: Thu, 21 August 2014, 12:54:33 »
Woho!
Offline Mooby
  • Funployee
« Reply #447 on: Thu, 21 August 2014, 13:07:13 »
Are there mockups of the final sets?
Did the orange/yellow extra set make it in?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #448 on: Thu, 21 August 2014, 13:12:01 »
no orange/yellow sorry
but I may run a bonus pack (not from MD)
Offline Xaviz
« Reply #449 on: Thu, 21 August 2014, 13:23:25 »
hell yes can't wait!
