Author Topic: [IC] Granite Round 2  (Read 365061 times)
Offline taylordcraig
Re: [IC] Granite Round 2
« Reply #150 on: Tue, 12 August 2014, 23:59:34 »
Oh crap I thought there was a 40% kit. What kits do I need for a jd40? I probably won't have money for more then 1 kit.. Dang.. Also no Cyrillic?
dated info
Dressing a JD40% with Granite Round 2
There is no cheap way. A Pro Modifier kit is short by two 1.25u keys. A blank kit has no 1.75 key (you need two).
You'd need a common kit, modifier kit [icon, text or RGB] and Lost & Found. (for enter and tab and pn)
With those three kits (common, mods, lost and found) you could cover your whole board.
You'd have wacky legends on two 1u keys in the bottom row and backspace, which would be found in a pro modifier pack.
« Reply #151 on: Wed, 13 August 2014, 00:16:16 »
If you just go common and pro you'll have wacky legends.
There is no cheap way. A Pro Modifier kit is short by one 1.25u key. A blank kit has no 1.75 key.
You'd need a common kit, modifier kit [icon, text or RGB] and Lost & Found. (for enter and tab)
  • NOTE: With icon mods you can use the delete icon as back space.
Sweet thanks man!
Offline Heliosphere
« Reply #152 on: Wed, 13 August 2014, 01:35:45 »
If this GB is going to go through, about when can we expect it to start? There's a lot of keyset group buys going on and I have to be very picky now or else I will have little money left for living expenses.   :rolleyes:
The Granite is a sure buy for me since it looks nice but is not too flashy or gaudy.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #153 on: Wed, 13 August 2014, 02:11:04 »
It seems we will have a Granite R2 sooner than expected. For those who don't know it, this is what we are talking about http://geekhack.org/index.php?topic=56354.0
I'm finalizing this second round that won't be a copycat of the original. If you have requests and suggestions please speak up. Also ideas for the new Nerdom kit are welcome.
Later I'll post the updated kits.
Matt3o will you be making this Granite R2 in ABS or PBT?  Please say ABS it's vastly preferred due it's lack of deformity which was common on your first version set.
Would genuinely like an all ABS set done because I feel for SP because it will go faster with manufacturing and result in far less returns.  Please let us know soon.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #154 on: Wed, 13 August 2014, 02:12:07 »
hopefully a couple of weeks
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #155 on: Wed, 13 August 2014, 02:17:43 »
Sounds good! :D
One question, will it be a gray/white iso enter key kit?
Offline coreXeon
« Reply #156 on: Wed, 13 August 2014, 07:46:25 »
I believe the ergodoxian set is missing a spacebar.
Filco Majestouch 2 Ninja - Cherry MX Black | Blackwidow 2012 - Cherry MX Blue | Steelseries 6GV2 - Cherry MX Black | Ergodox - 62g Ergo-Clears (WIP)
Offline McWilloughby
« Reply #157 on: Wed, 13 August 2014, 08:20:16 »
I don't suppose extras to fully equip a RACE I/II would be possible? I don't really know how many people are using them except me so it probably wouldn't be a popular suggestion. The most major difference would be 1.5x keys for escape and delete, everything else is reasonably easy to get around with a DSA keyset just from spares...
(picture from mechanicalkeyboards.com)
Offline strict
  • TKL Zealot
« Reply #158 on: Wed, 13 August 2014, 08:28:12 »
  • NOTE2: Fn keys are in Pro Modifiers.
Damn, that's depressing. It would be nice if there was a JD40 pack. Even if we just added the one missing 1.25 key to the Pro Mods that would be fine.
Offline Data
« Reply #159 on: Wed, 13 August 2014, 08:30:22 »
You're in luck!  1.5u Escape and Delete are both in the Ergodoxian kit.
Offline Mooby
  • Funployee
« Reply #160 on: Wed, 13 August 2014, 08:45:57 »
I think I found an error: The Lost+Found kit is missing it's yellow and orange mods  :-*
Offline LechnerDE
« Reply #161 on: Wed, 13 August 2014, 09:01:23 »
The kits look good to me  :thumb:
But could you please move the text enter key from the numpad to the red enter kit?
It's the only difference to the R1 numpad kit and I don't wanna buy the whole kit again for a single key...
Matt3o, can you please comment on that  :thumb:
« Last Edit: Wed, 13 August 2014, 09:13:19 by LechnerDE »
Offline abjr
    • abjr.org
« Reply #162 on: Wed, 13 August 2014, 09:44:35 »
There is no cheap way. A Pro Modifier kit is short by one two 1.25u keys.
You need 5x1.25u and 2x1.75u ... so aren't the Pro Modifier kits short by 2 1.25u keys? (Even tho the keys it does contain have legends that don't make sense for how they'd be used!)
Note: Edited as requested.
« Last Edit: Wed, 13 August 2014, 11:20:04 by abjr »
CM QFR | magicforce 68 (Gateron) | magicforce 68 (Outemu) | Acros 6311-K
« Reply #163 on: Wed, 13 August 2014, 09:54:06 »
You are absolutely correct. Please change my quoted text in your post. [on my jd40 I use "nm,./" down in that corner so there's a little gap and no 1.25  :rolleyes:]
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #164 on: Wed, 13 August 2014, 10:40:25 »
I'm waiting for pricing from Massdrop (possibly today), if we can do this via Massdrop I have to make bigger aggregated kits (which will be probably cheaper than the sum of the subsets).
Otherwise we are a bit more free to do what we want with the kits.
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #165 on: Wed, 13 August 2014, 12:57:02 »
Awesome! :D
« Reply #166 on: Wed, 13 August 2014, 13:37:47 »
Ah great :D The rest of the keys should be relatively easy to source..
« Reply #167 on: Wed, 13 August 2014, 13:39:11 »
This in every group buy :D :P
Offline eMps
« Reply #168 on: Wed, 13 August 2014, 14:24:04 »
Are you adding a Korean kit? Surely I can't be the only one who's interested :)
Colemak since Jan. 10, 2011
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #169 on: Wed, 13 August 2014, 14:28:31 »
I would much rather see a Japanese set, personally.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline teuf
« Reply #170 on: Wed, 13 August 2014, 14:34:17 »
Aren't the big cursor key/end key going to be an issue as well? I also have a Race which I might try to get Granite on..
Offline drrtyrokka
« Reply #171 on: Wed, 13 August 2014, 15:43:20 »
Flask go, Flask go!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #172 on: Wed, 13 August 2014, 16:22:57 »
for korean or japanese kits I'd need the full list of unicode characters, if anyone is interested...
« Reply #173 on: Wed, 13 August 2014, 17:02:40 »
If you want the correct legends yes, if not it'll be pretty easy to get loads of 1.25x keys with this set. If I join this GB I just plan to use some of the spares that haven't gone elsewhere.
« Reply #174 on: Wed, 13 August 2014, 17:05:05 »
you wont find printed 1.25 arrows, but you can buy a blank set and you should be good.
wonder what'll happen with massdrop, very excited to see.
Offline MythicalWagyu
  • Poor Impulse Control
« Reply #175 on: Wed, 13 August 2014, 17:57:47 »
There's a few of them:
Korean Hangul (2,028 characters)
Code Table Japanese Hiragana and Katakana (172 characters)
Full (I think) Unicode Kanji Table: http://www.rikai.com/library/kanjitables/kanji_codes.unicode.shtml
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline sakai4eva
« Reply #176 on: Wed, 13 August 2014, 23:14:51 »
in 1.5x:
Tab, backspace
in 1.75x:
Control, shift.
Nothing else I want :)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #177 on: Thu, 14 August 2014, 01:15:40 »
and the way they are lied out on the keyboard of course :)
a nice guy sent me the full list for Korean... so we might do that even though japanese seems nicer :)
in 1.5x:
Tab, backspace
in 1.75x:
Control, shift.
for ergodox I presume?
Offline sakai4eva
« Reply #178 on: Thu, 14 August 2014, 01:26:19 »
in 1.5x:
Tab, backspace
in 1.75x:
Control, shift.
Yeah. I should have gotten the blanks for the ergo's mods, but in the end I decided not to because the colours are also available in the PMK store. You can also include CTRL into the 1.5x list, but I guess it might be a little redundant, but what the heck.
The 1.75x are more for the tsangan/1800 kit.
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #179 on: Thu, 14 August 2014, 02:33:24 »
Sounds good! :D
Still wondering. Will look so much cooler :)
Offline DanielT
« Reply #180 on: Thu, 14 August 2014, 03:46:21 »
Oooo, a set with Korean or Japanese legends, I would buy that :D If they end up like the cyrilic oh boy :D
Offline blockdevice
« Reply #181 on: Thu, 14 August 2014, 04:55:55 »
Willing and able, if they're going to be (thick) PBTs ;) A dark gray or gray ISO Enter
key would also be nice (at least a blank one). Are those ISO Enter keys still
DCS or is DSA now an option with SP?
Also, not a fan of the current "Nerdom" Kit. Personally I'd like to see a
black on gray Flask, Sun Logo and/or Lambda key in there. And I'd prefer f(x)
instead of the normal function key.
Anyway, big thanks for R2 @Matt3o :)
Offline DanielT
« Reply #182 on: Thu, 14 August 2014, 05:06:45 »
I've been nagging matt3o about the SUN logo ever since this started :D
I thought that I'm the only crazy guy who likes that :P I even use Solaris at home and own a couple of SUN machines :D
I wanted a SUN cap soooo bad that I made a custom one just for me :D
My dream is a purple one with white logo, DSA doubleshot .... maybe one day....
74447-0
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #183 on: Thu, 14 August 2014, 07:11:08 »
key would also be nice!
Yeah, that would be a dream for us iso users ;)
Offline Oobly
« Reply #184 on: Thu, 14 August 2014, 07:28:24 »
I for one, would LOVE an old SGI logo (3D cube one) on a cap... Silicon Graphics, yum!
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline neverlast74
« Reply #185 on: Thu, 14 August 2014, 09:40:07 »
Announcement: I will buy one German ISO 105 Keyset ... and maybe 2 :-)
Tour de kübord - Germany Layout:
Original IBM model M (too loud) -> rubber dome IBM Rapid Access II (mediocre) -> Cherry STREAM XT scissor switch (somewhat OK) -> G80 with clear (too hard for me) -> Zowie Celeritas with brown (good but dirty)-> Filco Majestouch 2 Brown (great) -> CM NovaTouch + Filco Doubleshots (best)
Offline Mooby
  • Funployee
« Reply #186 on: Thu, 14 August 2014, 09:47:56 »
I want some unicorn vomit options. I need more colors for my keyboard at work.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #187 on: Thu, 14 August 2014, 10:43:00 »
still waiting for pricing...
« Reply #188 on: Thu, 14 August 2014, 10:58:42 »
*holds breath*
Offline neverlast74
« Reply #189 on: Thu, 14 August 2014, 11:10:26 »
quick question - what will the inside/bottom of the cap look like? Can someone who has received his/her caps already from round1 send me a pic? (like the one below?)
Background: I just bought the double shots from Filco for my Majestouch2 Filco and realized I can not silence & O-ring them (easily) because their female cap stem has no cross inside of the cap. Which means I need 4-5 rings per cap to which makes the O-ring mod a bit uuaaaargg - if you need 400 rings.
Like this...
« Last Edit: Thu, 14 August 2014, 11:13:35 by neverlast74 »
Offline geniekid
« Reply #190 on: Thu, 14 August 2014, 11:22:51 »
SP DSA caps don't come with cross bars so you will need to stack O-rings.  It's possible to buy much thicker O-rings.
Offline Oobly
« Reply #191 on: Thu, 14 August 2014, 13:40:58 »
Or do the trampoline mod <- Oobly starts to sound like a stuck record...
IMSTO sells some little silicon balls you can stick inside the little tube in the switch (or you can make your own "trampolines" by cutting orings into pieces or using a 2mm hole punch on a rubber sheet). Does pretty much the same job as properly sized orings, but since it's inside the switch you can use any keycaps without worry. Feels better, IMHO, too. Also can be adjusted to taste (thickness, length and hardness of the rubber piece).
« Reply #192 on: Thu, 14 August 2014, 14:22:37 »
DSA caps are very short, though.
With 4 small soft red orings from WASD I can't even depress a cap.
With 3 the cap feels very hard. 2 produces a softer feel and silences the clack of the keys quite a bit.
It feels softer to bottom out on just 1 oring, but the sound and actuation feel is very similar.
I personally don't like the feel of orings on DSA, but might use them if sound was an issue.
Offline drrtyrokka
« Reply #193 on: Thu, 14 August 2014, 15:22:06 »
I tried to dampen the sound and had to stack  2 of the softest red ones. But in the end it decreased the feel to much for me and i removed them again, although i liked using orings on ducky pbt oem caps before...
Now I'm modding the whole keyboard to ergo / panda clears to bottom out less and get a better feel than with browns (and got totally crazy after desoldering all switches, now I want to get me a custom plate with cutouts lasered and a wooden case made with cnc :D :geek ).
I kept the double orings on every key except the alphas  to remove the clack because I often bottom them out for shortcuts and stuff.
« Last Edit: Thu, 14 August 2014, 15:38:28 by drrtyrokka »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #194 on: Thu, 14 August 2014, 16:57:53 »
ok some news. this will most likely go through MassDrop. To me this is a great news since: a) at the monent Massdrop GB system is better than PMK; b) pricing will be probably better than R2 (but please bear in mind that we will hardly reach the 380 tier of the first GB).
Tomorrow I will be posting an updated set of kits, we will have the weekend to make few updates, Monday I'll get the final pricing and hopefully somewhen next week we could start.
Offline Mercury7
« Reply #195 on: Thu, 14 August 2014, 17:29:30 »
How many total kits will these all be merged into since its going through Massdrop? Also do you mean that pricing will be better than R1?
Offline frebib
« Reply #196 on: Thu, 14 August 2014, 18:01:31 »
Count me in. Want want want!
Das Keyboard 4 [Blues] | Poker 2 [Browns] w/ Granite R2
« Reply #197 on: Thu, 14 August 2014, 18:20:53 »
I believe you underestimate yourself. I know I'll be buying a R2 even though I participated in R1, and with MD we have an even larger audience.
Since MD doesn't have a vendor sub forum, AND with Nuclear Green being in the GB thread, I find it entirely appropriate that Granite R2 also appears in the group buy sub forum.
Offline codymaust
« Reply #198 on: Thu, 14 August 2014, 18:34:03 »
I'm in for sure!
Offline osi
« Reply #199 on: Thu, 14 August 2014, 18:40:02 »
Very cool. Congrats on the massdrop partnership and wishing success!
