Author Topic: Keycaps and Dying - 122 Key IBM Model M  (Read 3967 times)
Offline ZefyrPyon
    • YouTube: ZefyrPyon
« on: Wed, 13 August 2014, 15:28:23 »
So, basically, I'm looking into buying a 122 key model m and customizing it heavily. I want to dye the case black, as well as some of the keycaps, and either purchase gray keycaps or find a successful way to dye them gray. Here's the trouble. I want to label the black keycaps. Any advice? Like, how can I label blank keycaps at home?
Pink fluffy unicorns dancing on rainbows.
Offline JinDesu
Re: Keycaps and Dying - 122 Key IBM Model M
« Reply #1 on: Wed, 13 August 2014, 15:43:14 »
Slightly confused. You want to get keycaps to dye them grey, but you want to label black keycaps? Or blank keycaps?
Also, it's dyeing - dying is slightly different.
Someday somebody will best me, but it won't be today, and it won't be you.
Proud owner of a Filco Majestouch Cherry MX Blue Tenkeyless, KBT Race S, & Realforce 101
« Reply #2 on: Wed, 13 August 2014, 16:53:28 »
White stickers?
« Reply #3 on: Wed, 13 August 2014, 17:05:49 »
You will not be happy with the results if you do what you describe.
Unicomp is your best source for most accessories.
« Last Edit: Thu, 14 August 2014, 08:40:59 by fohat.digs »
- D Trump 2026-10-24
Offline ZefyrPyon
« Reply #4 on: Sat, 16 August 2014, 19:12:00 »
White stickers?
Any recommended source?
I'm probably gonna crap the plan and go DAS Keyboards style, RIT Dying everything black. I've also heard mixed reviews about Uni...
« Reply #5 on: Sat, 16 August 2014, 19:32:23 »
Post #14 here is very helpful.
http://geekhack.org/index.php?topic=35444.msg658453#msg658453
Cases are ABS plastic which softens and deforms at about the same temperature that dye requires to "take" properly.
Unicomp is a great company and their customer service is excellent.
I have had good results with "Dupli-Color" from Auto Stores.
Offline ZefyrPyon
« Reply #6 on: Sat, 16 August 2014, 21:56:59 »
*scrap. Wow. Bad typo. D:
I actually planned on using Duplicolor myself. XD Just finished paying for the keyboard. It should ship this week.
Offline wcass
« Reply #7 on: Sun, 17 August 2014, 10:50:01 »
If you want white legends on black keys, Unicomp made them many years ago but they were pad printed not dye-sub. The print sits on top of the cap and is a lot softer than the PBT cap. Unicomp discontinued them because they were the first thing to fail. Dyes on the other hand actually become part of the substrate. You have to wear away the cap to wear away the color. But you can't actually dye something a lighter color than it already is. Dyes absorb some wavelengths of light; the substrate absorbs some wavelengths; with the end result of less light (darker) than you started with.
You could get "black on dark gray" by using weaker dye or shorter time, but the color might be more susceptible to wear as the dye would not penetrate as deeply. The keys in my signature were in a boiling bath for an hour and have changed very little in 3 years.
If you know anyone with a laser engraver, you could engrave legends on caps that were dyed black. You could then dye those caps again any color to get black caps with colored text.
By the way, RIT changed their formula and it does not work on PBT anymore. Use iDye Poly (available online and at some art/fabric stores). I think it works even better than the old RIT ever did.
Offline ZefyrPyon
« Reply #8 on: Sun, 17 August 2014, 11:59:45 »
Calling my local Joann's now to see if they have iDye Poly as I post this. :D
