Author Topic: I messed up, help!  (Read 1408 times)
Offline Protato_Tubby
  • people enthusiast
I messed up, help!
« on: Wed, 13 August 2014, 15:42:52 »
I was trying to put some O-rings on my keyboard, and I’ve messed up. I’ve broken a stabaliser, dislodged one and now I don’t know how to fix it. I’ve tried my best to take a photo but the best I have is my laptop webcam; I’m not much of a photographer.
DELL AT102W Black Alps | IBM Model M 122 | Matias Tactile Pro 4
Re: I messed up, help!
« Reply #1 on: Wed, 13 August 2014, 15:57:53 »
Assuming your talking about pulling out the stabilizers on the number pad area. They just go right back in, one side has a leg that goes in the hole the other side snaps into the pcb. The wire just snaps back in as well.
And it might be easier if your remove the other keys around it to work on it.
Next time be gentler removing caps  :))
« Reply #2 on: Wed, 13 August 2014, 16:06:53 »
Yep those are cherry PCB mount stabilizers in your G80-3000 (I think?) there. Notch the one side in and clip the other side into the PCB: should work fine.
It's not too uncommon to happen while removing keycaps: just have to be careful.
« Reply #3 on: Wed, 13 August 2014, 16:10:22 »
REKT
  • people enthusiast
« Reply #4 on: Wed, 13 August 2014, 16:24:31 »
Thanks
Thanks
REKT
xD
