Author Topic: Hammered QFR with Doubleshot & Zinc Keys  (Read 25178 times)
Offline nowsharing
  • Swoop
« on: Thu, 14 August 2014, 14:58:11 »
74491-0 74495-1 74493-2
74497-3 74499-4
CM Storm QuickFire Rapid - Blue Cherry Switches
Doubleshot Cherry G80-8100H keycaps
Clear G80 Function keycaps
Zinc Esc & Arrow keys from geek_feng
Reflective Cherry Logo Sticker from geek_feng
Blank, tactile F & J keycaps from WASD Keyboards
Case paint: Rustoleum Hammered Enamel 7215 Black: $5 at Home Depot.
Pre-Hammered photos here.
A huge thank-you to mkawa for the case! ;D
« Last Edit: Thu, 14 August 2014, 15:00:53 by nowsharing »
Offline jalaj
Re: Hammered QFR with Doubleshot & Zinc Keys
« Reply #1 on: Thu, 14 August 2014, 15:05:24 »
This looks beautiful.
Love how you incorporated all the differently sourced parts and it comes together so well.
Thanks for sharing.
Offline nowsharing
  • Swoop
« Reply #2 on: Thu, 14 August 2014, 22:22:16 »
74532-0 74534-1
Here it is with my ITAC Systems Mouse-Trak Industrial. I chose the hammered finish so they would match, and it came pretty close.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Fri, 15 August 2014, 17:07:30 »
your case looks pretty awesome.............good job!
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline nowsharing
  • Swoop
« Reply #4 on: Fri, 22 August 2014, 13:37:03 »
Thanks guys. I love the feel of the cherry blue switches, and the zinc arrows keys are a joy to use.
Offline nowsharing
  • Swoop
« Reply #5 on: Tue, 24 November 2015, 00:18:01 »
I ended up refinishing the frame because the decal was starting to lift. I stripped it down and gave it several fresh coats of the same Rustoleum Hammered black, and then reapplied a new Cherry decal and clear coated over it. It looks a lot better now, and I shouldn't run in to any decal issues going forward.
I also installed an aluminum spacebar (thanks Armagedda!) after giving it a hand-polishing up to 12,000 with micro-mesh pads. The spacebar sounds pretty close to my Model F AT now, which I'm liking.
118202-0118204-1118206-2
Offline cryptokey
  • [°°▄°] luser-friendly
« Reply #6 on: Tue, 24 November 2015, 00:28:10 »
That hammered finish looks beautiful!  Excellent photos as well, the leather goes perfectly with it as well as the zinc keys.  It's hard to believe that it was a can of spray paint from home depot...  ITAC Trackball too? Take my +1!!!!
[WTB] HHKB Black
Offline sintklaas73
« Reply #7 on: Fri, 04 December 2015, 15:44:32 »
great keycaps. where did you find 1.25 mods doubleshot from cherry?
Offline nowsharing
  • Swoop
« Reply #8 on: Sat, 05 December 2015, 20:34:08 »
Thanks, all of the doubleshots and crystal caps are from a G80-8113H.
