Author Topic: What layout is this keyboard?  (Read 3583 times)
Offline Karura
  • Professional Canadian
  • SKidata life.
« on: Thu, 14 August 2014, 23:05:53 »
I found this intriguing keyboard layout, it's almost revolutionary. Does anyone know what it is called?
Offline ComradeSniper
  • HHKB Pro
Re: What layout is this keyboard?
« Reply #1 on: Thu, 14 August 2014, 23:27:37 »
Those dual esc keys  :))
Offline hoggy
  • * Ergonomics Moderator
« Reply #2 on: Fri, 15 August 2014, 00:43:16 »
If only it had undo where the enter key normally is...
Offline Oobly
« Reply #3 on: Fri, 15 August 2014, 01:19:51 »
That's called "Crayola ultimate ergonomic matrix layout for small hands"....  - NOT.
Actually it's a travesty to be teaching kids nowadays to use QWERTY as it's such a bad layout in terms of ergonomics.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #4 on: Fri, 15 August 2014, 06:01:43 »
Crayolabeit :))
Offline Data
« Reply #5 on: Fri, 15 August 2014, 09:58:52 »
Ah yes, that is the Crayola EZ Type 1300 layout.  I believe this particular model shipped with stock MX Red switches.  Keycaps are doubleshot ABS using the Comic Sans font.  There were only 3000 manufactured in this configuration from April to July 2013 exclusively for engineering programs at MIT and NASA Dryden.
« Reply #6 on: Fri, 15 August 2014, 10:01:22 »
****, guess I'm adding another board to my wish list...
« Reply #8 on: Fri, 15 August 2014, 10:11:18 »
Ugh, there's no way it's mechanical for that price...Gotta message that eBay seller I guess. Thanks ray
« Reply #9 on: Fri, 15 August 2014, 10:11:49 »
There's a few more crayola offerings that are a little out there as well.
one example
http://www.ebay.com/itm/Crayola-USB-Computer-Keyboard-BIG-KEYS-Tested-works-Children-kids-Wired-/181323598745
« Reply #10 on: Fri, 15 August 2014, 10:13:23 »
I just want that Dino board that Filco put out since I *know* that's mechanical. But anything fun like this and I'm all over as long as it's mechanical.
Offline berserkfan
« Reply #11 on: Fri, 15 August 2014, 10:25:22 »
MIT engineers use this keyboard?
Begging your pardon, but today isn't April 1.
« Reply #12 on: Fri, 15 August 2014, 10:26:26 »
Or it's for the summer programs they run at MIT and NASA where they have younger kids come in to learn about STEM. Beginning your pardon, but today isn't April 1.
Offline Data
« Reply #13 on: Fri, 15 August 2014, 10:30:02 »
Consider the spirit in which this thread was created.  ;)
  • HHKB Pro
« Reply #14 on: Fri, 15 August 2014, 12:17:30 »
The Filco Dino is my endgame keyboard.  :p
Looks like one sold on eBay in May, so there is hope.
« Reply #15 on: Fri, 15 August 2014, 12:18:19 »
HOLY ****. AND I MISSED IT.
* CPTBadAss wants to cry on ComradeSniper's shoulder.
« Reply #16 on: Fri, 15 August 2014, 12:23:29 »
Wow it went so cheap to.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #17 on: Fri, 15 August 2014, 14:53:34 »
You planning to replace the original Alps clone switches with Matias switches? Or has someone found a Cherry version?
Bore Awards
Offline halfkiller
« Reply #18 on: Fri, 15 August 2014, 15:00:38 »
Is it strange that I actually kind of want this ... since the Filco Dino boards are so hard to come by.
