Author Topic: request: es-87 w/ pbt keycaps sound demonstration  (Read 2550 times)
Offline anowt
  • "I want you to buckle my spring" ♪♪~
« on: Fri, 15 August 2014, 15:41:14 »
I've been trying to find out more about the es-87 TKL, since I'm thinking about getting one w/  mx clears. the only thing is, I can't find a typing demonstration video on YouTube that fits one of these with pbt caps. does anyone own one of these (browns, clears, blacks, reds ) with a set of pbt caps and would you be willing to make a quick typing sound demo? are they practically identitical in sound to a QFR with those caps and switches?
« Last Edit: Fri, 15 August 2014, 16:07:11 by anowt »
Front Line: IBM Model M SSK
Tactical Team: QFR TKL (MX Blue)
Recon: KUL ES-87 (MX Red)
Special Operations: RF 87U 55g
Offline cruzin
Re: request: es-87 w/ pbt keycaps sound demonstration
« Reply #1 on: Fri, 15 August 2014, 16:02:51 »
I own one with clears, but my PBT caps won't get here for another few weeks.  :(
I imagine someone here's already got PBTs on theirs. I'm interested in the sound myself.
Current: Ergodox (Ergo-clears) | Kinesis Advantage (Browns) -- Colemak
Future: HHKB Pro 2 | Maltron L90 | µtron | Axios
« Reply #2 on: Fri, 15 August 2014, 16:05:10 »
thin PBT ok?
Offline anowt
« Reply #3 on: Fri, 15 August 2014, 16:08:45 »
yeah. that would be helpful. thanks!
« Reply #4 on: Fri, 15 August 2014, 16:15:00 »
alright give me a minute
« Reply #5 on: Fri, 15 August 2014, 16:29:02 »
it's quiet and still uploading but here, should be good in like 20 minutes
my upload speed is really trash
Offline anowt
« Reply #6 on: Fri, 15 August 2014, 16:49:23 »
wow. this adds some more perspective to this keyboard, imo. I love how mellow the sound, and how there's also the definite crunch. that's kind of what I was looking for.
thanks for the help. ^··^
« Reply #7 on: Fri, 15 August 2014, 16:59:40 »
i do my best
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #8 on: Fri, 15 August 2014, 20:19:36 »
Wow that is indeed mellow.
Watching/hearing that makes me want to get one.
Can you do a similar one with a Filco (if you've got thin pbt caps on it) or I guess even your Realforce (for baseline purposes)
« Reply #9 on: Fri, 15 August 2014, 21:55:20 »
yeah ill do them in the morning
Offline Hucifer
« Reply #10 on: Sat, 16 August 2014, 08:23:16 »
I've got thick PBT Leopolds on my KUL and did a quick sound test for you.
Disclaimer: I thwack the space bar like the end of the world is coming and I don't care who knows it!
Here you go!
              Waiting on / GMK LED Keycaps
Offline anowt
« Reply #11 on: Sat, 16 August 2014, 13:10:01 »
Here you go!
thanks hucifer.  this thread was really informative.  i just ordered a set of thick PBTs.
now I'm tempted to get a kul es-87 with mx clears.  hucifer, is it difficult to avoid bottoming out on the es-87?
« Reply #12 on: Sat, 16 August 2014, 13:11:41 »
it's MX clears so it's harder, but you could always just get some o-rings or soft landing pads.
The board is much quieter than most other boards, so noise isn't much of a concern with it.
EDIT: I'm making a bunch of typing videos right now, so if you keep checking my channel this afternoon you should see a few pop up.
Offline Hucifer
« Reply #13 on: Sat, 16 August 2014, 13:26:34 »
I would say they're on a par with Blues but I can't be 100% sure as I bottom out no matter what keys I use.
I can definitely say that they're quietest mx switches for me, although I haven't tried whites or greys, and that they feel just lovely with thick keycaps!
« Last Edit: Sat, 16 August 2014, 14:24:39 by Hucifer »
« Reply #14 on: Sat, 16 August 2014, 14:29:49 »
whites are clicky and greys are just heavy clears/blacks (depends on which grey)
« Reply #15 on: Sat, 16 August 2014, 15:08:59 »
http://www.youtube.com/playlist?list=PLiIDOCXT0oe2hc9yADqcK3OqBIHPQgZrP
here's this afternoon's work
might make some more if you guys want something else i have
Offline anowt
« Reply #16 on: Sun, 17 August 2014, 07:23:32 »
good effort, TS. the QFRs with mx blacks sound pretty good, too. and I'd like to try my hand (literally ) at some 55g topre someday.
tthanks for advising o-rings. I bought two kinds: thin silicon and A50 rubber.
« Last Edit: Sun, 17 August 2014, 07:57:30 by anowt »
