Author Topic: Alps Switches vs Cherry Switches - Which are more durable?  (Read 21990 times)
Offline iggysaps
« on: Wed, 10 June 2009, 04:27:04 »
Considering that alps switches are usually rated at 20M actuations, case in point, Filco Zero, while cherry switches are usually rated at 50M actuations, case in point Filco's with any cherry switches.  Anybody actually feel that the alps were less durable than cherry switches?
A 30M difference in the number of actuations is a lot...
Cherry G84-4100 cherry ML switches
Cherry G80-3000 blue cherries
Dell AT101W (2)
Solidtek ASK-6600
Unicomp Spacesaver buckling spring
Key tronic designer P2
Offline lowpoly
« Reply #1 on: Wed, 10 June 2009, 04:33:40 »
Only linear Cherrys are 50M. Blues and browns are less.
Offline ironcoder
« Reply #2 on: Wed, 10 June 2009, 05:04:23 »
is that 20 thousand or 20 million?
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline ch_123
« Reply #3 on: Wed, 10 June 2009, 05:11:00 »
Million. You'd be in a pretty bad way if your keyboard could only withstand 20,000 keypresses...
Offline huha
« Reply #4 on: Wed, 10 June 2009, 06:01:39 »
Even 20 Million is a lot. If you really need a durable keyboard, you have to go for capacitive, optical or reed switches.
Debating on the durability of a $100 keyboard is somewhat pointless. 20 Million keypresses is a lot, and should your keyboard fail due to reaching this number of keypresses, you can always just buy a new one, since it will long have payed for itself.
Durability should only be a concern if you want to install the stuff somewhere extremely inaccessible, where it is often used and should last a long time.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline cchan
« Reply #5 on: Wed, 10 June 2009, 06:40:31 »
Quote from: lowpoly;95128
I believe that the latest spec for Cherry MX switches quotes every type (linear, tactile, ergo tactile, or clicky) to have a 50 million actuations rating. The non-linear ones used to be 20M though.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline itlnstln
« Reply #6 on: Wed, 10 June 2009, 08:10:50 »
Quote from: cchan;95138
Seconded.  This is correct.
Offline IBI
« Reply #7 on: Wed, 10 June 2009, 08:35:37 »
Has anyone seen any cherry/alps switches that are worn out?
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline itlnstln
« Reply #8 on: Wed, 10 June 2009, 08:45:58 »
Quote from: IBI;95155
I've seen them worn in, but never worn out.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #9 on: Wed, 10 June 2009, 08:57:27 »
Well, I have a board with two Cherry blues not clicking properly... but I guess that's dust/dirt inside (which can enter during actuation), since things got better for one of them at least after an attempt at blowing it out with lungpower. Should get a can of compressed air one of those days. One would assume the tactile switches to be more susceptible to dirt than the linear ones.
Cherry blacks seem to be very tough. They do get somewhat lighter (which is quite nice actually), but that's about it. The lasered lettering on PBT keycaps fares less well...
Offline itlnstln
« Reply #10 on: Wed, 10 June 2009, 09:09:52 »
Quote from: keyb_gr;95162
Wow, really?  I have never had any problems with lasered lettering before.
Offline keyb_gr
  • Cherrified user
« Reply #11 on: Wed, 10 June 2009, 09:39:40 »
Quote from: itlnstln;95164
Nor do I - but on my newer G80 with blacks the lettering on the numpad enter is worn very thin in part, not to mention the number of shiny keys and the shiny spots on the case. Yes, this one was used a lot in its former life (which only was 7 years max). It also needed a complete teardown badly, as there was this black dust/dirt (toner?) everywhere. Works like a champ though...
So it's not like the lasered lettering would be bad, but like I said those blacks are tough...
Offline itlnstln
« Reply #12 on: Wed, 10 June 2009, 09:43:26 »
Quote from: keyb_gr;95169
The G80 I have doesn't quite have the polish of the Filco, but I find that I type a little faster on it.  It seems that they use a lighter plastic on the G80 than Costar uses on their 'boards, and that gives the keys a little lighter feel, IMO.  I have a hard time choosing which one I like better.
Offline ironcoder
« Reply #13 on: Wed, 10 June 2009, 14:04:53 »
Quote from: ch_123;95133
Agreed, but a lot of stuff made today is ****e. Case in point, I got some freebie Chicony keyboards with some somewhat expensive new boxes and 2 out of 4 of them went bad in less than a week. I would have been happy if they would have lasted 2,000 keypresses.
« Last Edit: Wed, 10 June 2009, 14:13:40 by ironcoder »
Offline watduzhkstand4
« Reply #14 on: Wed, 10 June 2009, 14:13:05 »
The alps feel more durable to me but I think Cherry lasts longer
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline itlnstln
« Reply #15 on: Wed, 10 June 2009, 14:17:19 »
IMO, Alps switches, real or fake, don't feel as refined as Cherrys.  I don't think either one is more durable than the other, though.  Alps feel more industrial and brute-force where Cherrys feel more like butter.  Kinda like a GMC Yukon vs. a Cadillac Escalade.  Same size, durability, performance, etc., but one is more refined than the other.
Offline talis
« Reply #16 on: Wed, 10 June 2009, 14:28:05 »
Someone may have done this calculation before but :
If you assume English, e is the most common character at 12.702% (ignoring the space bar, capitols and all that).
That means a key rated at 20,000,000 activations will fail after a total of 157,355,518 total key presses (if 12.7% of them are on a single key).
Using the standard definition of "word" at 5 characters that's a total of 31,491,103 words.
If you can type at a constant 80wpm, the most use key will hit its life after 393,639min (273 days) of constant typing.  A key rated at 50M key presses should last 2.5x as long.
Seems like the new best thing will come along long before either 20M or 50M activation keys will wear out =P.
Offline itlnstln
« Reply #17 on: Wed, 10 June 2009, 14:28:09 »
Quote from: ripster;95236
Please do. I'm curious to see if that fixes it or if you have to disassemble the key and then see wear points.
First actual Cherry Key (or buckling spring for that matter) that I've seen that may be worn out.
My kid tears through Logitechs but that's partly because he's a slob at the keyboard and games constantly. Wonder where he inherited that from?
This issue used to pop up on brand new Das IIIs.  There would be some dust or something that would keep the little white piece on the switch from popping up or sliding down.  Once the user would press the switch rapidly several times or take the cap off, press the switch down (so the internals were accessible), and blow it out with compressed air, it would click again.
Offline IBI
« Reply #18 on: Wed, 10 June 2009, 14:31:28 »
Quote from: watduzhkstand4;95233
Based on what?
Perhaps you should use that as an excuse to get the spillproof cymotion expert.
« Last Edit: Wed, 10 June 2009, 14:34:30 by IBI »
« Reply #19 on: Wed, 10 June 2009, 14:52:03 »
Quote from: IBI;95239
Based on what?
it says it on the site that it lasts 50 million operations.
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline itlnstln
« Reply #20 on: Wed, 10 June 2009, 15:10:03 »
Quote from: watduzhkstand4;95245
So are Cherrys.  The 20 million is an old number; it has since been updated.  Really, once you get over 15-20 million or so, the number is just a SWAG, IMO.  Honestly, you'll buy another keyboard before you wear a switch out.
Offline chimera15
« Reply #21 on: Wed, 10 June 2009, 19:52:24 »
Bob from Northgate keyboard repair sent me a bag of about 100 alps switches that had gone bad.  Eventually the spring that actuates against the switch to actually produce the contact gets bent out of position and fails.  They also, at about half-3/4ths their lifespan get really sloppy, stiff, or aberrant in their behavior in one way or another, especially the simplified fakes.   Alps switches are *super* easy to fix or replace though.
  I would say that the comparison was different depending on the alps switch.  If you're talking alps complicated, I think they have a much longer lifespan than simplified fakes will, especially in their consistency of feel over their lifespan.
« Last Edit: Wed, 10 June 2009, 20:19:06 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline ch_123
« Reply #22 on: Thu, 11 June 2009, 13:55:50 »
Quote from: talis;95237
Considering that most of us are typing on keyboards whose key-switch technology has remained unchanged since the 1980s, I'm not sure about that one...
Just to throw it out there - Unicomp's old websites give a 25 million figure for their buckling spring keyboards, and something like 4 million for their M4s.
« Last Edit: Thu, 11 June 2009, 14:06:36 by ch_123 »
Offline keyb_gr
  • Cherrified user
« Reply #23 on: Fri, 24 July 2009, 16:38:09 »
So, digging up this eldely thread... anyone found any worn-out MX blacks yet?
I bet that would make a good PR gag for Cherry - send us your board with one or more really worn-out (failed due to normal usage) switches and get a new equivalent type in return, or something like that. I don't think they'd lose a lot of money...
Offline ch_123
« Reply #24 on: Fri, 24 July 2009, 17:17:37 »
I should point out that after using more than one worn out AT102W, Alps don't last forever. I have never used any Cherry board other than my brand new Filco so I can't really give a comparison there.
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« Reply #25 on: Sat, 25 July 2009, 00:48:02 »
I don't think you can ignore the other keys.  I suspect that the switches most likely to go first would be those associated with the space bar, enter and/or delete, and the modifier keys (shift/command/control, etc.)
It would be interesting to see what some real-world metrics come out to.  Hey, that sounds like an actual non-mischievous use for a keystroke recorder!
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline namelessguy
« Reply #26 on: Sat, 25 July 2009, 04:02:26 »
Quote from: megarat;104245
Well, this is what I heard;
Topre keyboards in banks (they are renouned for their quality and durability, and are the de-facto standard among Japanese bank staffs now) are known to fail after a year or two of sustained heavy use.
Usually the space bar is the first one to break, sometimes the enter key, though I don't have information on how they are getting broken.
Looks like 30,000,000 keypresses are far from enough in these places.
Offline keyb_gr
  • Cherrified user
« Reply #27 on: Sat, 25 July 2009, 05:39:53 »
Assuming an 8 hour work day with an average of 50 wpm (at that point I'd be more worried about wear on humans rather than keyboards) and a 15% space bar duty cycle, you "only" get about 13 million keypresses in 2 years. Hmm.
Anyone got some figures for medical transcriptionists?
Offline ch_123
« Reply #28 on: Sat, 25 July 2009, 11:09:33 »
Quote from: ripster;104294
Also not good since I guess it's the official keyboard of the "Japanese Data Center" whatever that is.
Wiki
IIRC, the exact quote was "National data centers", so I assume those would be the data centers belonging to the various agencies of the Japanese government?
Offline BucklingSpring
« Reply #29 on: Fri, 31 July 2009, 23:25:47 »
Nope... All Cherry MX's are good for 50M including tactile as well.
I know because I had an argument not long agao with a Deck rep claiming their new tactile board will use 50M Cherry switches. But when I looked at CherryCorp.com, MX taciles were rated 20M.
So I wrote to Cherry support and got a reply back from them confirming that all MX's are 50M.
To:  me
Date:  Wed, 17 Dec 2008 10:38:47 -0400
Hello,
I apologize but our website has not been updated yet. All MX series
switches are rated at 50 million actuations.
Best regards,
Ed Ferraton
Senior CID Technical Services
Cherry Electrical Products
They finally updated their site with the correct information:
Click here to see for yourself
Boards I own, click ->
