Author Topic: How many different kind on connectors are there for a keyboard?  (Read 6008 times)
Offline watduzhkstand4
I know PS2 and USB. But I've seen listings say like 5 pin, 6 pin, AT, RJ-25 etc...
Can someone please list them out?
I don't want to get confused because I'm newbie =P
Also, are there adapters to change them into a USB or PS2?
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline Manyak
« Reply #1 on: Wed, 10 June 2009, 10:49:29 »
For PC keyboards there are four: AT, 5-pin PS/2, 6-pin PS/2, and USB
As for the really old non-x86 computers, I have no idea how many different ones there are. Each manufacturer used a different proprietary connection back then.
Currently Owned:
Filco FKBN104MC/EB - Model M 1390131 \'86 - Model M 1391401 NIB - Unicomp Endurapro NIB - iRocks KR-6230 - Compaq MX-11800 - Cherry G80-8113HRBUS-2 - Cherry ML-4100 - Cherry MY-8000-something - Dell AT101W (Black) - ABS M1 - Siig Minitouch - Chicony KB-5181 w/ SMK Montereys - Chicony KB-5181 w/ SMK Montereys NIB - Cherry G80-3494LYCUS-2 - Deck Legend
« Reply #2 on: Wed, 10 June 2009, 10:53:34 »
Quote from: Manyak;95189
wait so the 5 pin and the 6 pin will work on our computer's ps2 connector?
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline itlnstln
« Reply #3 on: Wed, 10 June 2009, 10:57:14 »
Quote from: watduzhkstand4;95191
The 5-pin is the same protocol as the PS2, so it's easily adaptable.  The 6-pin is PS2.  Both can be adapted to USB (AT to PS2 to USB).
Offline itlnstln
« Reply #4 on: Wed, 10 June 2009, 11:00:09 »
You should be OK with anything that says AT, PS2 or USB.  AT and PS2 are easily adpatable to USB.  With AT, you will have to adapt to PS2 first, but since it's the same protocol as PS2, adapting is trivial.
« Reply #5 on: Wed, 10 June 2009, 11:03:09 »
Quote from: itlnstln;95194
the AT connector looks just like a bigger PS2 connector right?
Something like this should work fine?
http://cgi.ebay.com/PS-2-Male-to-AT-Female-Keyboard-Converter-Adapter_W0QQitemZ350201047696QQcmdZViewItemQQptZVideo_Games_Accessories?hash=item51899bea90&_trksid=p3286.c0.m14&_trkparms=65%3A15|66%3A4|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A200
« Last Edit: Wed, 10 June 2009, 11:06:42 by watduzhkstand4 »
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline Manyak
« Reply #6 on: Wed, 10 June 2009, 11:07:25 »
Technically only the 6 pin, but really both will. The 5-pin plug won't fit because the little plastic piece in the middle isn't positioned the same, and the wires are switched around. But you can use a passive adapter for it just like with an AT plug.
Currently Owned:
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline IBI
« Reply #8 on: Wed, 10 June 2009, 11:18:30 »
Quote from: watduzhkstand4;95198
I can't seem to find the 5 pin female to 6 pin male. I found this though but I don't think it will help. =(
http://cgi.ebay.com/PS-2-6-Pin-Mini-DIN-Female-to-5-Pin-DIN-Male-Adapter_W0QQitemZ220380681421QQcmdZViewItemQQptZPCA_Cables_Adapters?hash=item334fb654cd&_trksid=p3286.c0.m14&_trkparms=65%3A15|66%3A4|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A200
Try a normal shop.
AT is also called DIN and PS/2 is also called Mini-DIN.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline ch_123
« Reply #9 on: Wed, 10 June 2009, 11:19:53 »
The RJ jacks and serial cables were popular on old terminal keyboards and the like. There are a bunch of proprietary designs around as well, the most common being ADB (old apple mouse+keyboard) and the Sun one, both of which look like PS/2 connectors but are incompatible (although there are ADB to USB adaptors available)
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
« Reply #11 on: Wed, 10 June 2009, 11:30:57 »
Quote from: ch_123;95200
I guess I'm gonna just stay with the 5 pin, 6 pin, and usb lol
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline D-EJ915
« Reply #12 on: Wed, 10 June 2009, 15:37:57 »
if it doesn't fit in a PS/2 it's not a PS/2 connector lol
Offline Hak Foo
  • Make America Clicky Again!
« Reply #13 on: Fri, 12 June 2009, 00:10:19 »
The ADB and Sun cables are mini-DIN plugs, but different pin counts.  ADB  is 4-pin, I think, and Sun is like 8 or 9 pins.
Overton130, Box Pale Blues.
Offline Manyak
« Reply #14 on: Fri, 12 June 2009, 00:14:46 »
Quote from: D-EJ915;95262
But there are two PS/2 connectors. At a glance they look the same, but one has 5 pins (the bottom-right one is missing) and the plastic tab in the middle is more centered - and therefore won't fit on today's PS/2 ports.
The wires are also arranged differently, so even if you broke off the plastic tab to fit it it still won't work - you'd have to strip the insulation off the cable and rewire it.
Currently Owned:
Offline ricercar
  • mostly abides
« Reply #15 on: Fri, 12 June 2009, 00:35:54 »
My AT connector Kinesis Contour came with both of these PS/2 adapters. I had one bad afternoon before I determined what was going on.
Offline D-EJ915
« Reply #16 on: Fri, 12 June 2009, 13:35:55 »
Quote from: Manyak;95636
uhh that means it's not a PS/2 connector...don't see how you're missing this fact
Quote from: Hak Foo;95635
Yep sun is 8 pins and ADB is s-video
Offline Manyak
« Reply #17 on: Fri, 12 June 2009, 17:53:16 »
Quote from: D-EJ915;95738
Then what is it?
Currently Owned:
Offline D-EJ915
« Reply #18 on: Fri, 12 June 2009, 21:32:05 »
Quote from: Manyak;95834
Then what is it?
mini-din unless they want to call it something special. the only reason the 'PS/2 connector' is the 'PS/2 connector' is because it specifies what the pins do, otherwise it's just a mini-din connector.
Offline Manyak
« Reply #19 on: Fri, 12 June 2009, 21:42:44 »
Quote from: D-EJ915;95879
Even the PS/2 connector is called a mini-din.
But what would a 5 pin DIN to 5 pin mini-DIN adapter be used for?
Currently Owned:
