Author Topic: Ebay: VINTAGE IBM 09F4230 SOFT TOUCH DOME SPACE SAVER TERMINAL KEYBOARD  (Read 2891 times)
Offline ed_avis
Not buckling spring but looks cute.
http://ebay.com/itm/291214230199
Offline kalrand
Re: Ebay: VINTAGE IBM 09F4230 SOFT TOUCH DOME SPACE SAVER TERMINAL KEYBOARD
« Reply #1 on: Mon, 18 August 2014, 07:23:16 »
Was there ever a buckling spring version in this form factor?
My 122 key Model M was born on July 25th, 1988.
Offline 1391406
« Reply #2 on: Mon, 18 August 2014, 07:39:48 »
Yes, there's the "Space Unsaver".
Offline Parak
« Reply #3 on: Mon, 18 August 2014, 07:54:19 »
There were several PNs with various differences due to the terminals that they were designed for, and there was even one that is an M type. 1387033 is definitely the one everyone wants though since it can be easily converted via Soarer's and is CapBS.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #4 on: Tue, 19 August 2014, 10:16:53 »
I have one of these. It has a build quality like an F, very solid with a metal barrel plate,  but it is still a rubber dome at heart.
« Reply #5 on: Tue, 19 August 2014, 13:37:25 »
It uses quality honeywell domes, if I recall.
Also plate mounted domes are usually rather nice. I think it's part of why everyone likes topre so much.
I think samwisekoi got one as well and liked it.
I'll have to do some looking, but if you replace the keycaps and dome sheet (with hammers / springs) you can probably make this buckling spring and save a lot of effort cutting the case of a 122-key down to size.
