Author Topic: "The manly switch"  (Read 4825 times)
Offline henz
  • What?
"The manly switch"
« on: Mon, 18 August 2014, 05:13:20 »
im thinking of building a manly switch. i have this idea off getting a hold of some cherry mx super black springs and putting them into greys/clears.
Has anyone tried something similar or is this a crazy idea as it seems they are out of production since 2012.
The actuation point would be more than 150 g, hence "the manly" (:
Offline keyton
Re: "The manly switch"
« Reply #1 on: Mon, 18 August 2014, 09:45:36 »
Try BIC pen springs.
« Reply #2 on: Mon, 18 August 2014, 09:47:12 »
Sprit did some heavy custom springs but I think they only went up to 120g but he might have done some higher ones for 'testing'
Offline whiskytango
  • Don't touch the trim
« Reply #3 on: Mon, 18 August 2014, 09:50:53 »
i used 80g springs from originative in blues for a while. I like heavy, but it ended up just being too much. Had to bump it back down to black springs.
I'm 6'3", 225 and have giant hands, and I felt that the blues with 80g springs were fairly manly.
Offline AKmalamute
  • HHKB Scrub
« Reply #4 on: Mon, 18 August 2014, 09:53:36 »
I have some tactile grays in my ergodox, with 100gr springs from Spirit's 1st spring-only GB.
 I have to say I don't like it. Not because it takes too much to actuate ... I have 100gr springs in the nearby clears, but the tactile gray, even natural, is a bit too 'mushy' for the feel I was hoping for. 100gr manlyclears are mighty stiff, but I happen to like them.
 Of course, the pinkies don't have that ... browns, and off-homerow they have 50gr springs (also from Spirit). So, whatever. I believe that for the current run of springs, the 100 & 120gr versions didn't reach MOQ. No surprise they're a bit of a specialty item (and I guess I'm just special that way).
HHKB-lite2, Dvorak user
Offline strict
  • TKL Zealot
« Reply #5 on: Mon, 18 August 2014, 09:57:46 »
I picked up some 150g and 300g springs just for the hell of it awhile back. The 150g is ridiculously heavy, it essentially made a clear steam feel almost linear. The 300g spring was just totally outright, it felt like I was going to break something pressing that key  :))
I really like the spring in the tactile gray (non-clicky) ... I think that one is supposed to be around 120g?
« Reply #6 on: Mon, 18 August 2014, 09:58:10 »
I thought the clear stem and gray stem was identical?
Are you saying the 100g springs feel different when using a clear stem versus a gray stem?
Offline JPG
  • Model F is my new passion!
« Reply #7 on: Mon, 18 August 2014, 10:26:42 »
Get some buckling spring. Not that heavy, but way more manly for sure! You will feel the manliness at first try!
« Reply #8 on: Mon, 18 August 2014, 10:34:47 »
Be sure that it is Model F, it is the multiple layers of steel that gives it such awesome stability.
The Model M is mostly plastic.
- D Trump 2026-10-24
Offline AKmalamute
  • HHKB Scrub
« Reply #9 on: Mon, 18 August 2014, 11:58:34 »
My fingers know which one is the gray, and the clear right next to it has the same spring. So ... yes, I guess I have to say that's what I'm saying.
« Reply #10 on: Mon, 18 August 2014, 12:09:01 »
Some industrial keyboards and public access terminal keyboards are designed to have 200 - 400g actuation forces!
I'm pretty sure clear and grey stems are the same. Photographing clears is really hard for me since the translucent plastic just absorbs the flash and gets that halo effect.
y'all can probably tell that it's a cellphone picture. As soon as someone mails me a better camera, I'll start using it :p
« Last Edit: Mon, 18 August 2014, 12:11:42 by dorkvader »
« Reply #11 on: Mon, 18 August 2014, 12:14:21 »
Interesting...i'll have to experiment.
« Reply #12 on: Mon, 18 August 2014, 12:15:08 »
I do not doubt that my Logic Controls restaurant keyboard (still available!) has that kind of force.
Offline henz
  • What?
« Reply #13 on: Mon, 18 August 2014, 13:18:59 »
where where!?
« Reply #14 on: Mon, 18 August 2014, 13:25:08 »
Not a conventional keyboard, this is intended for commercial and industrial environments.
Offline henz
  • What?
« Reply #15 on: Mon, 18 August 2014, 13:59:02 »
ah! maybe its best i ask spirit. se what he has to offer. =)
Offline ShawnMeg
« Reply #16 on: Mon, 18 August 2014, 15:09:10 »
Damn right.  My testosterone level goes up when I type on my F.
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline henz
  • What?
« Reply #17 on: Mon, 18 August 2014, 16:10:22 »
Ordered som springs from sprit's GB :) wee gonna havet some fun with 120g springs, gotta order som greys also
« Reply #18 on: Mon, 18 August 2014, 16:21:31 »
just get clears: they are the same slider.
