Author Topic: Piecing together a keycap set  (Read 1895 times)
Offline epicepee
« on: Mon, 18 August 2014, 17:12:24 »
I am building a keyboard.  I designed a layout, and I don't believe it matches any keyboards out there.  A USA-standard (ANSI?) 104-key set would fill most of my needs, but I still need a few other keys, most notably a pair of 2.75x or 3x keys for the bottom row (instead of a spacebar).
So, how easy would it be to find spares that would match a set I get elsewhere?  I see cheap 104-key sets on eBay for ~$30, would I be able to find two more 2.75x or 3x keys?
Offline taylordcraig
Re: Piecing together a keycap set
« Reply #1 on: Tue, 19 August 2014, 00:09:35 »
for 3x the only one i know of is SP does a 3x DSA profile key.
you'd need a DSA set [cheapest is their blank PBT that I know of]
for 2.75 you could steal extra shift keys
Offline Oobly
« Reply #2 on: Tue, 19 August 2014, 01:53:51 »
You can order individual keycaps from here:
DCS profile you can get extra right shift keys (2.75x), DSA profile you can get 3x keys.
You can get matching complete keysets from here: http://keyshop.pimpmykeyboard.com/
They have blank DSA sets in a few colours and Black / White DCS sets. You could also join a Group Buy if there is one that catches your eye. Pay attention to the profile, though.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
