Author Topic: HHKB Pro "A" key vibrates after each keystroke -- normal?  (Read 1400 times)
Offline vultureparade
« on: Wed, 10 June 2009, 21:00:49 »
The "A" on my HHKB Pro v2 is vibrating under my pinky after each keystroke.  None of the other keys seem to do this, at least to the noticeable degree that the "A" key does.  Is this normal?  Can I make it stop?
The keyboard is great otherwise. The key-feel is like nothing else.
Offline tamasrepus
    • http://blog.samat.org/
« Reply #1 on: Wed, 10 June 2009, 21:40:24 »
Some of my keys vibrate occasionally, but it's not something that happens consistently, nor can I reproduce it.
Noppoo Choc Mini w/ Cherry MX Brown
Happy Hacking Keyboard Professional 2, Black w/labels
Topre Realforce 87U, 55g
ABS M1
Happy Hacking Keyboard Lite 2
Logitech diNovo Edge
Sun Type 6 USB
Offline ch_123
« Reply #2 on: Thu, 11 June 2009, 13:27:09 »
Maybe it's some undocumented haptic feedback feature? :p
Seriously though, there seems to be some weird issues with some of the HHKB's keys (eg. the sticky thing some have mentioned)... Kinda puts me off spending €180 on one...
« Last Edit: Thu, 11 June 2009, 13:34:09 by ch_123 »
Offline wellington1869
« Reply #3 on: Thu, 11 June 2009, 13:35:49 »
Quote from: vultureparade;95328
did you try opening it up? Maybe  the spring is wonky.
using: ms 7000/Das 3
