Author Topic: My Design, the Lunar Set, is on SP as an IC!  (Read 12028 times)
Offline Dvoryke
Offline taylordcraig
Re: My Design, the Lunar Set, is on SP as an IC!
« Reply #1 on: Mon, 18 August 2014, 23:33:43 »
what will the profile be?
Offline Dvoryke
« Reply #2 on: Tue, 19 August 2014, 10:15:20 »
DSA, but Vortex will be making doubleshot PBT versions most likely in Cherry profile.
« Reply #3 on: Wed, 20 August 2014, 00:26:06 »
i thought all of vortex stuff is oem?
Offline Pliny
  • has 1800 fever
« Reply #4 on: Fri, 22 August 2014, 18:03:07 »
Except for the alpha keys, the legends look way too big. Sort of out of proportion. Just sayin'
Also not feeling the star on the meta keys. Is a crescent moon glyph available? That would be cool...
"He will never, ever give you up. And, most importantly, he will never, ever let you down.”
- Melania T.
« Reply #5 on: Sat, 23 August 2014, 01:20:46 »
Looks great! I like your colors.
I have a couple changes that you should consider making.
Please add a modifier color `~ key as well as an alpha color \| key.
A modifier color ESC key please.
Also, consider text for pg up/pg down/menu so you don't have a mix of icon/text.
I think the star on win key is okay because it has to be neutral.
You need a 1u + [plus sign] key for numpad for 1800 layout.
That's all I can pull off the top of my head. Just got off work!
glwb  :-*
Offline Dvoryke
« Reply #6 on: Sat, 23 August 2014, 01:25:35 »
glwb  :-*
Will have to add some of the suggestions you made, but I have already done some of them but just haven't posted, here they are
http://imgur.com/a/GUdiR
« Reply #7 on: Sat, 23 August 2014, 23:05:33 »
Maybe a dark space bar too!
Offline FrostyToast
  • Litshoard
« Reply #8 on: Sat, 23 August 2014, 23:41:58 »
I personally don't like the star on the os key.
A bit of an odd shape that sticks out too much probably due to complexity in the shape.
Extra blanks would be cool as a replacement
Quote from: elton5354
Offline Dvoryke
« Reply #9 on: Sat, 23 August 2014, 23:46:11 »
If you click the link I put in response to Taylord's comment you can see the Tsangan kit includes 3x 1u blank keys :)
« Reply #10 on: Sun, 24 August 2014, 03:17:06 »
make sure to include 2x 1.25u blanks for regular layout keyboards.
[also is there gonna be that esc pack like on PMK page? looks good imo]
Offline Dvoryke
« Reply #11 on: Sun, 24 August 2014, 03:22:32 »
Yep! The Esc. pack will be available :)
« Reply #12 on: Sun, 24 August 2014, 03:40:00 »
awesome thanks!
any chance you can squeeze in the 2x 1.25 blanks to replace stars on regular layouts?
Offline Dvoryke
« Reply #13 on: Sun, 24 August 2014, 03:42:57 »
awesome thanks!
Gonna work on a "Suggested Pack" including alllllllll this **** being suggested, so yeah anything that anybody wants will be in there.
« Reply #14 on: Sun, 24 August 2014, 03:43:38 »
hah, works for me. I always just grab 1 of each pack. :P
Offline TheMoonUnderWater
« Reply #15 on: Wed, 24 September 2014, 03:07:36 »
I may just be being blind but I couldn't read the colors anywhere. Is that a black or dark blue for the non-alpha keys? Thanks
Offline bazh
« Reply #16 on: Wed, 24 September 2014, 03:14:26 »
They do have cherry profile but I doubt they had molds for double shot pbt in cherry profile
HHKB Pro2 white
Newbie again
Offline Dvoryke
« Reply #17 on: Wed, 24 September 2014, 05:46:01 »
http://www.pimpmykeyboard.com/wp-content/uploads/2014/01/absgray.jpg
On that page it is the "GSZ" chip.
