Author Topic: Kailh making switches with RGB LEDs built in  (Read 7203 times)
Offline jameslr
« on: Tue, 19 August 2014, 08:12:58 »
From a news article put out in Feb of this year. That switch on the right looks really weird. WTF is it? Looks a little like a "Topre compatible" MX-type switch.
Reference: http://www.kailh.com/en/Newsdetail.asp?Newsid=61
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline BlueBär
Re: Kailh making switches with RGB LEDs built in
« Reply #1 on: Tue, 19 August 2014, 08:21:59 »
Topre sliders are slightly different, I think the problem would be that you could rotate Topre caps on a slider like that because it has nothing that sticks out on the vertical axis on the inside of the slider. It's probably just like that because it is a
Center Full-color Light-emitting Keyboard Switch
which sounds pretty cool.
Offline Oobly
« Reply #2 on: Tue, 19 August 2014, 11:04:02 »
It's amazing what counts for "innovation" nowadays. They have a PATENT for both types of switches. I can understand the second one, but the first one is just a normal Cherry / Kailh switch with a bit cut out to fit the LED. Even the 4 holes are in the same place as on all Cherry MX. Innovation for patent purposes is supposed to be "not obvious to a professional in the same field". Seems pretty obvious to me, and I'm not even a switch designer.
Anyway, seems they're trying to block Cherry from doing the same thing by getting the patent. I think it's better than Cherry's all clear housing with lens that Corsair are using. I think Cherry will be the loser here. Maybe it's about time they had some competition.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline BlueBär
« Reply #3 on: Tue, 19 August 2014, 11:39:05 »
Why?
Agreed.
Offline jameslr
« Reply #4 on: Tue, 19 August 2014, 12:03:16 »
Something I just noticed that is odd is that they decided to use 3 separate LEDs (1 large 3mm and 2 ~1.8mm) instead of a single LED with RGB leads inside the same diode.Maybe the diameter was too large for the standard tri-color RGB LEDs that are out there now. I think they're 5mm which would probably make them too big for the switch housing.
Edit: I think it just looks that way - after looking at it again it seems it must be just the shape of the LED plastic that is confusing me.
« Reply #5 on: Tue, 19 August 2014, 12:12:03 »
gross
i wanna know what plastic they used
Offline qwack
« Reply #6 on: Tue, 19 August 2014, 15:41:07 »
I don't care about their housing, but I'd like to know where to find this kind of RGB LEDs. Looks like they're a bit smaller than 5x5x2 LEDs, and that they could fit Cherry switches with minimal modifications.
Pure Pro w/MX Red - [review]
Offline Grendel
« Reply #7 on: Tue, 19 August 2014, 16:58:50 »
It's a single LED, the Rosewill RGB80 uses these switches:
- I'm game !
Offline jameslr
« Reply #8 on: Tue, 19 August 2014, 18:12:13 »
Nice find!
Offline dante
« Reply #9 on: Tue, 19 August 2014, 18:25:36 »
Noppoo was supposed to have come out with a Capactive keyboard switch but I haven't seen any sign of it.
Offline Oobly
« Reply #10 on: Wed, 20 August 2014, 01:55:11 »
Why?
I prefer the light to be emitted under the keycap rather than the whole switch glowing. I use low profile cases and the switch glow would irritate me.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #11 on: Wed, 20 August 2014, 02:55:41 »
I find that I'm not as bothered by light bleed as I thought, but Matias switches—where the whole switch glows under the keycap—really does look wrong!
Bore Awards
Offline jameslr
« Reply #12 on: Wed, 20 August 2014, 09:15:09 »
Off topic, but It's Noppoo 108 EC Pro.
The user that posted this article on it has an account here on GH and is running a Tai Hao group buy.
http://www.hkepc.com/forum/viewthread.php?tid=2079319
Looks nice.
Offline BlueBär
« Reply #13 on: Wed, 20 August 2014, 09:20:16 »
Looks nice.
Those legends are terribly light.
Offline Oobly
« Reply #14 on: Wed, 20 August 2014, 12:31:53 »
Looks nice.
That's VERY interesting. It has MX compatible sliders, "orings" installed for the upstroke, space for 2 LED's per switch, costar style stabs, thick Cherry-esque profile PBT caps...
Looks very promising.
Not sure I'd like the 35g switches, though.
Offline BlueBär
« Reply #15 on: Wed, 20 August 2014, 13:58:16 »
It has MX compatible sliders...
Looks like they're not compatible to Topre caps though (see the issue I mentioned above), correct me if I'm wrong.
Personally I hated the 35g switches on a RF with variable weights. They're really mushy. Maybe these are better but I kind of doubt it right now.
