Author Topic: Wheelwriter 3 Typewriter Question  (Read 2123 times)
Offline kalrand
« on: Wed, 20 August 2014, 23:55:37 »
I have the keyboard from a (dirty) wheelwriter 3 typewriter, and aside from harvesting the caps, is there anything to do with the husk, or otherwise worth harvesting?
Bonus: I have about 0 soldering ability, so this isn't going to be one of those situations where I make a custom controller for it. And it's quite heavy, so shipping it to someone is probably out too.
My 122 key Model M was born on July 25th, 1988.
Re: Wheelwriter 3 Typewriter Question
« Reply #1 on: Thu, 21 August 2014, 01:00:55 »
you can remove the KB and mail it to me. I'll put new keycaps on it, bolt mod it and use it as a "cheap SSK".
More importantly, do you plan to use the "code" key and spacebar? I'm collecting those for an idea I've got.
All levity aside, you can harvest the springs / hammers from it as well. You can practise your bolt modding skills, etc.
ooh, measure the o-rings (or just mail them to me). I want to give them a try.
Offline jacobolus
« Reply #2 on: Thu, 21 August 2014, 01:44:23 »
No no, you should send the "code" key to me. I also have an idea for something to do with them. :-)
Dorkvader can have the spacebar though.
Offline kalrand
« Reply #3 on: Thu, 21 August 2014, 09:25:50 »
I think the Code key will actually fit on my unicomp where the right Alt and menu key is on the lower right, if I replace the control key with a 1x wide.
So I think that's going to happen.
« Reply #4 on: Thu, 21 August 2014, 11:54:07 »
dangit, all three of us had the same idea.
I was going to keep this secret until I made one work, but you can sack one of the mods and use the WW spacebar and code key instead.
Offline jacobolus
« Reply #5 on: Thu, 21 August 2014, 14:29:49 »
No, I have a different idea. :-)
« Reply #6 on: Thu, 21 August 2014, 14:57:30 »
my idea was to use the code key for something. How is your idea different from that?
Offline kalrand
« Reply #7 on: Thu, 21 August 2014, 15:02:35 »
We should put together a wiki article about this.
Offline kalrand
« Reply #8 on: Thu, 21 August 2014, 22:58:56 »
This is now a thing.
75329-0
