Author Topic: I Need ALL the Keyboard Shortcuts! - Especially This One  (Read 1338 times)
Offline Bludude4
« on: Thu, 21 August 2014, 05:24:12 »
So I got a QFR (with blues) a few months ago, (and custom keycaps from WASD and all that noise) but recently, Ctrl+A has not been working for me.  Is this maybe a bad soldering joint? Ctrl and the A key work fine separately, but when combined, they don't highlight text, or move left while crouched in gaming.  Anything I can do short of sending it back? (I, uh, took the warranty seal off and opened the case out of...curiosity :P)
All hail Hall Effect keyboards!
I'm a QFR Blues noob.
WASD keycaps are terrible.
Offline madik
Re: I Need ALL the Keyboard Shortcuts! - Especially This One
« Reply #1 on: Thu, 21 August 2014, 05:34:53 »
Plug-in another keyboard and try the shortcut. If it wont work then some program might stole the CTRL-A shortcut from you! Its possible that you recently created this shortcut in some application and forget about it. And it now prevents the CTRL-A to work in other instances.
Offline Bludude4
« Reply #2 on: Thu, 21 August 2014, 06:09:21 »
Yea, I was thinking that.  Okay, I'll get out my old IBM RD (*Sigh) and test it out.  haha
Thanks for the help!
